Old 07-19-2013, 08:04 AM   #1891
Monteman's Avatar
Trader Rating: 16 (100%+)
im running the wheels off the Exceed Mad Drifter. So the wheels arent the problem.
Maybe i'll putty up the differential this weekend and just be done with that.
I'll pick up another one to install if i want to run my grips.
On that note, to aid in the eBay search what other ofnas use the same differential, Im hoping to find a complete differential thats ready to go so i can just quick swap them.
More camber up front is easy, can do that no problem.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 07-19-2013, 09:29 AM   #1892
lx2
I usually buy all my Ofna parts from this guy
http://myworld.ebay.com/lumidave35
He parts out new buggies/cars for just the parts cheaper than you can buy the parts you need.
He USUALLY sells the diffs for $35 complete.
He doesn't have any now, you could message him and see if he could make an auction for you.
rob4448585 is offline   Reply With Quote
Old 07-19-2013, 02:15 PM   #1893
Monteman's Avatar
Complete rear LX2 differential and housing from JRC for $24... sold.
Cant buy the ring gear and diff case at the LHS for that price haha, let alone the internals or the drive cups.
Thanks for the help on that one. Wasnt sure if the LX2 was identical or not.
Old 07-20-2013, 12:06 PM   #1894
Originally Posted by rcwck View Post
One point to consider is the lipo temp. I use to do lotsa electric high speed aircraft runs. The fastest passes were always 3rd or 4th after things got warmed up. To be fair, voltages and temps should be the same when running such comparison tests.
I don't see too many people running the DP8 McLaren body at 140+mph. The Warrior body handle like a dream and never flips at high speeds.
johnracerx is offline   Reply With Quote
Old 07-20-2013, 12:20 PM   #1895
Jspeed's Avatar
+ YouTube Video
The way you trimmed off the rear spoilerís center section, while leaving the uprights is ingenious.
Any top speed runners looking for maximum aerodynamic efficiency should seriously consider doing the same to their Warrior bodies too.
Congrats and keep on running hard!
Jspeed is offline   Reply With Quote
Old 07-20-2013, 12:49 PM   #1896
where does one purchase a 'warrior' body? My car flips over 80mph.
Old 07-20-2013, 01:07 PM   #1897
Jspeed's Avatar
Thumbs up
Try contacting:
Bruckner Hobbies
Phone: (718) 863-3434
Winner's Circle RC
Phone: (866)-648-7672
Leisure Hours Hobbies
Phone: (815) 439-1477
Brooklyn Hobbies
Phone: (718) 951- 2500
They should be able to help you, all the best!
Old 07-20-2013, 09:35 PM   #1898
jdearhart's Avatar
Trader Rating: 14 (100%+)
Does anyone make a two piece motor mount for the GTP2E? Something similar to the 8ight electric buggies or the 8.2e?
jdearhart is offline   Reply With Quote
Old 07-21-2013, 03:05 PM   #1899
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
No one make a motor mount for the GTP2e like that. What you can do is cut off the original motor mount and then use the DM1e motor mount and redrill the chassis to get a bigger gear on it.
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 07-21-2013, 06:39 PM   #1900
jdearhart's Avatar
I'm using this on a dirt oval car. I'm just looking for something a little easier to adjust than the stock mount on it now. It's a bitch to change the pinion and get everything tight without stripping the screw heads. Does anyone know of there is a way to use the gt2-ve mount? Thanks!
Old 07-25-2013, 03:04 PM   #1901
Guess no one actually races this chassis onroad asphalt. Not surprising, its cheap and kinda dated. I only got one for racing cuz, well, it was cheap and I'm trying to get a class going.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 07-25-2013, 03:11 PM   #1902
Monteman's Avatar
Would guess more people have moved up to the DM-1e or GT-V2e. Much more refined.
I have had a couple GTP2e now and i recently converted mine to the SnR 360mm chassis.
Old 07-25-2013, 03:24 PM   #1903
Yeah, I figured that most ppl racing are using better chassis's. If the class takes off at the local track, I'll be moving up to a Serpent car. Just can't justify the cost for that yet.
Old 07-31-2013, 02:42 AM   #1904
Jspeed's Avatar
Thumbs up Attention Top-Speed Racers!
Starting September 1st 2013
We’re starting our new Ipanema “Top-Speed Club” promotion.
Rules are basically very simple:
Post your new Top-Speed video runs on YouTube, using your Warrior body.
The Top 5 fastest runners for the month of September win another Warrior body for free!
The video will have to be continuous, no breaks or edits and show top speeds.
GPS or Radar is fine and it has to be 2 Top Speed back to back passes.
That’s it!
If you run the Warrior body and want another one “on the house”, get your Warriors ready for September’s “Top Speed Club” fun!
More contest information & details will be available on the website.
Old 08-04-2013, 04:20 PM   #1905
rcwck's Avatar
That has nothing to do with my suggestion. It was just about testing parameters not any type of body.
Crew chief: "It's suppose to work, if not we'll do the complete opposite".
"Team Medicare"
https://www.facebook.com/#!/hobbystopwest
rcwck is offline   Reply With Quote
SEO by vBSEO 3.5.0
