Old 06-29-2013, 03:49 PM   #1876
FLoJo's Avatar
Originally Posted by Stealth_RT View Post
Just ordered one of these from nitrohouse, as they just showed up in stock. Local track has started running some asphalt onroad every few weeks, and I'd like to build some interest in the class. Went with this only cuz it's the cheapest way to get started. Going to try running an orion 2800 kv 1/8th scale motor on 4S, and hope that my hw sct pro esc can handle it, lol. Trying to not spend a lot on this project for now, and use what I have laying around. How good is the box stock setup on unprepared, probably dusty asphalt?
For bashing use themsupplied tires , for racing on track get some grp soft . Don't think that Orion 2800 gonna last to long , get 2200 or 2650 castle or even the hpi flux version which u can sometimes score on eBay cheap and new . Got my gtp for 170 shipped new so there cheap . But when u add carbon fiber chassis , shock towers , and different other cf bits its not cheap anymore lol
Get a good servo I always put,my spare traxxas 2075 but u need a good one if racing
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 06-29-2013, 07:40 PM   #1877
Got the motor today, and it's actually a 2400. Should work good on 4S, and if it's too fast for this track, I'll run 3S. I always use good servos in my cars. What's a good starting point for shock oils and diff oils?
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 07-09-2013, 08:29 PM   #1878
Monteman's Avatar
Trader Rating: 16 (100%+)
And now for something completely different...
Take 1 part OfnaGTP2e,
Add 1 Part SnR Carbon 360mm Wheelbase Chassis,
Cover with a creatively trimmed Associated SC8 Truck body,
Add 1 Ofna DM1 1/7 Wing
Just debating on what style of paint i want to go for on this one.
May mount some Xceed Drift Tires on here that i have on the way...
Ofna Ultra GTP2e-20130708_213833.jpg   Ofna Ultra GTP2e-20130708_213840.jpg   Ofna Ultra GTP2e-20130708_213855.jpg
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 07-10-2013, 01:35 PM   #1879
Default gtp2e
i recently got one myself and could not be happier.im running mamba 2200kv on 6s and its awesome.with the size and weight of these cars i have foung they perform best with 1800-2200kv motors on 5 or 6s.i installed the rc monster single speed adapter and am running 40 spur and 29 pinion for speed runs.my dm1e has 2650kv motor on 4s and it runs hotter and does not have the torque to efficiently get it up to speed.im new to forum and just wanted to offer my 2 cents worth on this awesome car.
rlinds is offline   Reply With Quote
Old 07-11-2013, 01:06 PM   #1880
Jspeed's Avatar
Thumbs up
Here's some interesting info for you top speed racers.
http://www.youtube.com/watch?NR=1&fe...&v=V6zrb3fRphU
Here are the real numbers......
+ YouTube Video
All the best!
Jspeed is offline   Reply With Quote
Old 07-15-2013, 07:46 PM   #1881
Monteman's Avatar
Got my wing. Crazy fast shipping from nitro-house this time around.
Usually wait a couple weeks or more.
Now the wait for paint. My painter is all sorts of backed up right now.
Ofna Ultra GTP2e-20130715_193100.jpg   Ofna Ultra GTP2e-20130715_193106.jpg   Ofna Ultra GTP2e-20130715_193115.jpg
Old 07-15-2013, 09:45 PM   #1882
Last high speed run I did, the Foam tires exploded.
I have now fitted some Xo1s belted tires on the GTP2e.
I need to trim the body a little bit to clear, but hoping for over 110mph next time out!
rob4448585 is offline   Reply With Quote
Old 07-16-2013, 08:57 PM   #1883
Monteman's Avatar
Does anyone make a rear locker for the differential?
Thinking about having a drift differential handy for mine.
Just wondering if there's a spool or anything made by anyone that i can drop in an empty housing. Or should i just buy a new setup and go heavy on the fluid?
I dont know what weight is in my current rear diff but it is very light compared to the fronts. AFAIK its stock. Works great on road though.
Old 07-17-2013, 04:47 PM   #1884
rcwck's Avatar
Most just use putty in the rear diff to lock it up.
Crew chief: "It's suppose to work, if not we'll do the complete opposite".
"Team Medicare"
https://www.facebook.com/#!/hobbystopwest
rcwck is offline   Reply With Quote
Old 07-17-2013, 05:09 PM   #1885
rcwck's Avatar
+ YouTube Video
All the best!
One point to consider is the lipo temp. I use to do lotsa electric high speed aircraft runs. The fastest passes were always 3rd or 4th after things got warmed up. To be fair, voltages and temps should be the same when running such comparison tests.
"Team Medicare"
Old 07-18-2013, 08:09 AM   #1886
Monteman's Avatar
Rear diff had nothing but grease in it. and very little at that.
Didnt want to lock it right up as i still drive it with grip tires as well.
Had some Traxxas 50k diff lube at the house still so i went with that.
Already feels way better. May still go a bit thicker though.
Old 07-18-2013, 11:49 AM   #1887
C@T
C@T's Avatar
The 1/10 scale guys do use "cleaning gum" to lock up a diff.
It would also be possible to fill it completely with a two component epoxy.
This will lock it up for ever and has same function as a spool but it is much cheaper.
If it does not work, buy a new one. Most probably still much cheaper as any spool.
C@T is offline   Reply With Quote
Old 07-18-2013, 12:02 PM   #1888
Monteman's Avatar
i have some cleaning gum from exceed, if the 50k doesnt get me where im hoping to be i may just use that.
Old 07-18-2013, 08:21 PM   #1889
Monteman's Avatar
ok so with the 50k in there this thing pushes like mad. Thinking camber and toe might lend a hand to correcting this? What should i be looking at for a basic drift setup on the GTP2e?
Old 07-19-2013, 06:37 AM   #1890
rcwck's Avatar
You were on the correct path when asking about a rear spool. 50k is nothing. You need 300-500k or putty like was mentioned. There is rc locking putty for that purpose or use window glazing compound/plumber's putty.
A spool in the rear and lotsa camber up front with one-ways is the drifting method with rock hard tires all around.
You cannot have both worlds of road racing and drifting in one car unless you can find a hard tire. Then just change tires. Tires are the #1 thing when drifting or road racing. PVC pipe tires works well on my micro RS4 for drifting!
"Team Medicare"
SEO by vBSEO 3.5.0
