Old 05-09-2013, 07:53 AM   #1846
Monteman's Avatar
Trader Rating: 16 (100%+)
Originally Posted by boostem View Post
Wow, Im envious! I think it looks amazing. Driving it like that sure would be nerve racking.
I think it would look even better with black wheels
I have a couple of black rim options on the shelf right now.
Definitely not gonna be a beat n bang car.
I'll save the beating and banging for the ERBE-gt lol.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 05-09-2013, 12:08 PM   #1847
Trader Rating: 34 (100%+)
Can the GTP2e be converted to buggy? A friend owes me some cash and has a GTP2e, but only offroad tracks here.
www.heatware.com mytime34
http://heatware.com/eval.php?id=706
www.ebay.com mytime341
http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=mytime341&ftab=AllFeedback
mytime34 is offline   Reply With Quote
Old 05-09-2013, 12:28 PM   #1848
liljohn1064's Avatar
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
It is the same basic chassis as the Ultra LX2e. You would need the center diff for sure.
http://www.ofna.com/ultralx2e.php
John Higgins
liljohn1064 is offline   Reply With Quote
Old 05-09-2013, 03:32 PM   #1849
Did you do an conversion yet?
I am interested in the outcome and how it holds up.
Still in the process of sourcing the shocks. Lost a bid on ebay for a set of LX2e.
But after some looking, I'm just gonna get the shocks/towers and keep the center spool. Mainly wanting the clearance and bigger shocks. And of course a rally body.
quadtro is offline   Reply With Quote
Old 05-09-2013, 03:35 PM   #1850
I'm wanting to convert mines to a Rally. But after some looking all u'll need is basically the shocks/towers/center diff/bumpers/wheels/body and u'll have a buggy.
Kinda wish I should've gotten a LX2e roller instead and convert to rally.
Old 05-09-2013, 06:05 PM   #1851
FLoJo's Avatar
Monte, try alpha slicks from brucknerhobbies $50 shipped free cant beat that set of tires for the price and the grip like crazy once broken in
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 05-09-2013, 06:38 PM   #1852
Monteman's Avatar
I have a couple sets of Sweeps and a set from the Kyosho GT2 as well sitting here already.
Old 05-10-2013, 12:39 AM   #1853
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
You going to have to get a LX2e chassis if you going to convert it to a buggy.
The GTP2E don't have a kick up in the front.
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 05-10-2013, 07:27 AM   #1854
Can you explain why a kick up is necessary? I dont understand chassis dynamics all that well. I assume that the kick up would be required for jumping because without one it would be a high seed lawn dart, if you land on the nose. If this is the primary reason for the kick up, would increasing ride height band-aid the issue?
There is a big difference between buggy and rally. I think if your goal was to make a rally it would work great.
Also, I am not planning on converting my GT2, but I am using your carbon chassis. Are carbon chassis even used for off road? Is your chassis thick enough?
boostem is offline   Reply With Quote
Old 05-10-2013, 08:39 AM   #1855
Monteman's Avatar
Pretty much.
The kickup helps prevent the nose from digging into everything. Helps with approach angle, and landing.
Old 05-16-2013, 04:36 PM   #1856
asc6000's Avatar
Trader Rating: 15 (100%+)
A lot more to kick than that.
This is from the JQ guide
"More kick-up on the front makes the car go better through bumps, and makes it jump better, specially on jumps with rough uneven faces. More kick-up also reduces steering, specially steering response, as it calms the car down, and makes it smoother. The car will transfer more weight, as the front will rise when accelerating and lower under braking. This can have the effect of making it easier to brake around hairpins as the weight is transferred to the front, and the rear slides round.
Less kick-up makes the car more responsive, and better for smooth and for high traction tracks. The car will be more stable on high traction tracks due to less weight transfer."
And another source , Scroll down to page 29
http://www.ocrraceway.com/setup%20sh...et-up_Book.pdf
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 05-25-2013, 04:42 PM   #1857
Monteman's Avatar
Here's one that will drive someone with OCD insane...
SC8e body with some Traxxas decals on an OFNA GTP2e with a 360mm WB and Kyosho wheels.
#YOUREDOINGITWRONG!
Decided to position holes for this rig as well as im not totally sure about the future of my Traxxas ERBE-gt.
(I may drill the pearl white Kyosho Corvette shell i had on there as well for the Ofna)
Ofna Ultra GTP2e-20130525_163451.jpg   Ofna Ultra GTP2e-20130525_163502.jpg   Ofna Ultra GTP2e-20130525_163525.jpg
Old 05-26-2013, 12:41 AM   #1858
that looks really good MonteMan!
rob4448585 is offline   Reply With Quote
Old 05-26-2013, 08:05 AM   #1859
#YOUREDOINGITWRONG!
That looks really good
www.snrgraphite.com
Old 05-26-2013, 10:41 AM   #1860
Monteman's Avatar
Thank you
Most likely going to buy a new SC8 shell and redo it, this one was trimmed to work on my ERBE-gt.
Couple measurements are just a bit off. I had originally planned on looking at the Scalpel for a "truck" body, but then i stretched the chassis with Steve's Graphite Conversion.
So that was taken out of the equation.
SEO by vBSEO 3.5.0
