Old 05-03-2013, 04:16 PM   #1831
ok.. GTP2e will be under going Rally-formation in a bit and thinking bout getting the LX2e shocks and shock towers. Are these direct bolt on for more suspension travel? Thinking those are the only things I really need besides cosmetics stuff.
quadtro is offline   Reply With Quote
Old 05-03-2013, 04:38 PM   #1832
From what I can tell, from all the reading I did on the car before I got it should work. I believe the car is based off the Ultra LX platform anyway which is a buggy so you should be good. Probably can run a taller tire also for a little more clearance too.
I don't want to double post so I'll ask my question here as well. I started with the stock 14T gearing and went to a 17T, HK120A w/ Turnigy 2560kv motor. At first all was good( I wasn't really pushing it/Maiden runs) then on 17T esc would go into safe/overheat mode if I held it WOT/multiple passes for a bit or did donuts I'm assuming it was the esc and not the motor since the motor was only 130-140f. So I geared down back to 14T and the temp went up to motor186f esc145f, so I was like wtf. I then went to 20T which I ordered a few days ago and now the motor temp is 120-130f and I can blast up and down the street for 5-10min without it going into safe mode. So I'm confused now, should I try a 22-23 and see if it goes down some more? I thought gearing down would cool it but obviously not in this case. I guess since the motor couldn't put that down it turned it into heat is this correct? I'm thinking it was severely under geared. I was a nitro 1/10 then gas 1/5 guy before so I'm teaching myself with brushless as I go. Here are the specs if needed
2650kv turnigy 129A max
HKesc 120A cont 780A burst(10 sec)
batts 5000mah turnigy 25-35c = 125-175A, turnigy 4000mah 30-40c = 120-160A
Also do you guys run the front bumper foam on yours? I had to trim it down some to let air flow in and the temps dropped another 10-15f.
Antny is offline   Reply With Quote
Old 05-03-2013, 09:46 PM   #1833
I think you just need to replace the shafts in the shocks. That would save you a lot of mulah
boostem is offline   Reply With Quote
Old 05-03-2013, 09:49 PM   #1834
FLoJo's Avatar
added a couple decals that I had laying around think it give it a nice touch , been messin with other bodies also so once complete will post if I dont mess it up before hand
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 05-04-2013, 11:27 PM   #1835
rsgonza's Avatar
Trader Rating: 30 (97%+)
Ofna GTPE2 with Hop ups Like New
Anyone Intrested...
TEAM ASSOCIATED!-----------www.rchqonline.com
RC8.2E TEKIN POWERED
B4.2 VIPER SOLUTIONS
TC6.1 BLINKY 17.5
TLR SCTE TEKIN.
rsgonza is offline   Reply With Quote
Old 05-05-2013, 02:59 PM   #1836
Here is my new roller. I am looking to put a Tekin speed control/motor in it.
Old 05-05-2013, 08:43 PM   #1837
rsgonza's Avatar
That roller looks familiar.very nice.just dropped price.open to offers.
TC6.1 BLINKY 17.5
TLR SCTE TEKIN.
Old 05-07-2013, 09:45 AM   #1838
Monteman's Avatar
Trader Rating: 16 (100%+)
Got my SNR chassis last night finally Cant wait to do this conversion.
Do i need a linger rear chassis brace? Never even thought to ask that initially.
I bought the longer rear dogbone and DM1 f/r bumpers already.
Just wondering now about the rear chassis brace.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 05-07-2013, 09:45 PM   #1839
Monteman's Avatar
Figured that question out. Should have just looked at it. lol
answered my 2nd question too... nevermind lol
Old 05-07-2013, 11:04 PM   #1840
Monteman's Avatar
Originally Posted by oldnfat View Post
not the greatest pics, I will get better ones...these we with my phone.
and I have my corvette tc5 in the last one as a ref. for scale.
this thing seems larger than 8th scale for sure.
I bought a 114mm swingshaft and it is certainly not that long.
I ordered a 114mm Ofna Swingshaft over the Kyosho 114mm shaft that SNR mentioned a few pages back (wasnt in stock when i ordered)
Why would it be that much shorter? Or do the measure them different?
It is 114mm from tip to tip.
I'll reorder the Kyosho unit if i need to, just curious.
Little bit more digging the Kyosho is 120mm overall. (114mm to the pins) The ofna is only 114mm overall.
Kyosho swing-shaft ordered. (its in stock now)
Old 05-08-2013, 08:47 AM   #1841
FLoJo's Avatar
she sure looks purty !!! what are u using for wire cover , I had ordered some stuff called flex-tec $5 for 10 ft , but its too heavy duty , need somthing a little more softer and thinner
Old 05-08-2013, 09:43 AM   #1842
Monteman's Avatar
it looks good, but its garbage. paid $4 for 30' on ebay for this stuff. Cutting it is a nightmare lol.
Old 05-08-2013, 08:15 PM   #1843
Monteman's Avatar
Just need my rear swing-shaft, other than that im done
The most nerve-wracking part was popping the new holes in a $130 shell lol.
steady... steady... easy... careful... poke... double check everything... lol
Ofna Ultra GTP2e-20130508_200326.jpg   Ofna Ultra GTP2e-20130508_200339.jpg   Ofna Ultra GTP2e-20130508_200353.jpg   Ofna Ultra GTP2e-20130508_200438.jpg   Ofna Ultra GTP2e-20130508_184441.jpg
Old 05-09-2013, 06:49 AM   #1844
Wow, Im envious! I think it looks amazing. Driving it like that sure would be nerve racking.
I think it would look even better with black wheels
Old 05-09-2013, 06:52 AM   #1845
Did you do an conversion yet?
I am interested in the outcome and how it holds up.
