Old 04-15-2013, 02:56 PM   #1771
Originally Posted by quadtro View Post
Which foam tires/wheels will fit the gtp2e?
So checked Amain for some foam and see that Ofna has some Foam for their GT cars.
http://www.amainhobbies.com/product_...mm-Medium-Soft
This is a pair of optional OFNA Green Dot Medium/Soft Compound (35-39 Shore) Foam Tires,
Specifications:
Diameter: 105mm (4.1")
Width: 40mm (1.6")
Hex Size: 17mm (0.67")
However they also have some that are cheaper with "35 shore", will the below wheels/tires work as well? They don't show the specs so don't wanna gamble and order them.
http://www.amainhobbies.com/product_...Tires-35-Shore
Also, being new to on-road what does these "shore" rating? is that the width?
quadtro is offline   Reply With Quote
Old 04-15-2013, 05:41 PM   #1772
Monteman's Avatar
Trader Rating: 16 (100%+)
those exceed wheels are for 1/8 pan car. I think, but regardless not even close to fitting the GTP2e
I have a set of the Ofna foams, they have held up decently. Side bite is a touch lacking due to how narrow they are. I usually stick to my Kyosho rubbers or Sweeps
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 04-15-2013, 08:06 PM   #1773
FLoJo's Avatar
Has anyone tried running onroad track with the RC monster mod spur gear . I was thinking with the lower tooth spur option wouldnt have to use bigger pinions . just thinking outloud here
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 04-15-2013, 08:29 PM   #1774
Monteman's Avatar
Are you talking the 42 or 46?
I run mine with 21/46 and im more than happy with it.
On the calculator it shows me a TTS of 59.1 mph which is more than enough for me and my driving style.
Haven't ever run into a heat issue with that gearing either.
Old 04-15-2013, 08:41 PM   #1775
TeamSkunkwerks's Avatar
Trader Rating: 92 (100%+)
Is that on a 3.14:1 diff gear ratio?
I am highly paid by my sponsors not to mention their names. They give me stuff so I will go away.
An American is someone who may disapprove of everything you say, but will defend to the death your right to say it.
TeamSkunkwerks is offline   Reply With Quote
Old 04-15-2013, 09:39 PM   #1776
Monteman's Avatar
stock differentials, i have never put it to a radar gun, all i know is i can burn a pack through and it is still decent temps. I just road bash, so it is never really sustained driving, stopping for traffic etc..
My setup on script-asylum for the GTP2e below.
Old 04-15-2013, 10:40 PM   #1777
Originally Posted by sonspit View Post
yea! that's what im talking aboutany links to the videos?
Here is a video of my 2nd outing:
+ YouTube Video
ducatiti is offline   Reply With Quote
Old 04-16-2013, 03:19 PM   #1778
FLoJo's Avatar
Can anyone tell me if the GTP2e and the Ofna Dirt Oval have the same final drive ratios . My GTP2e with a 2650 on 4s seemed alot quicker then my dirt oval running same setup . I thought I had read somwhere that they have the same diffs and final drives but for some reason my dirt oval doesnt seem as quick .
Old 04-16-2013, 03:42 PM   #1779
Yeah, it's setup on a 3.14:1 diff ratio, as you have listed in the chart.
Old 04-16-2013, 03:43 PM   #1780
Monteman's Avatar
The dirt oval uses a smaller diameter tire doesnt it? Would explain the speed difference if this is in fact the case.
Old 04-16-2013, 06:26 PM   #1781
FLoJo's Avatar
no dirt oval came with same tires the dm1 and gtp use , but i was actually using some ofna rims with teamC tires just a hair taller then the tires that come with the car
just cant figure out of the dirt oval and gtp have same diff setups ,
Old 04-17-2013, 08:17 AM   #1782
+ YouTube Video
check this
http://www.youtube.com/watch?v=n63EA...t=HL1366211728
what batteries are you using?
sonspit is offline   Reply With Quote
Old 04-17-2013, 10:35 AM   #1783
+ YouTube Video
do you use timing with your tenshock?
Old 04-18-2013, 03:17 PM   #1784
So ran the GTP2e for the first time and WOW, thing is fast. Tried some speed runs on 4s and had to hit the brakes wayyy early so I don't slam into the curb, (living in a short cul-de-sac sucks). Also blew out the foams on the stock wheels on the first donut attempt, LOL. GRP belted on the way now.
Just wanted to know some folks setup on the ESC/RX8 and shocks are. The thing nose dives hard when getting on the brakes.
Setup:
rx8 esc, vegas/223
tenshock x802L 2200kv
22t pinion/stock spur
everything else stock
Old 04-18-2013, 03:37 PM   #1785
azeroth's Avatar
Trader Rating: 20 (100%+)
Setup:
rx8 esc, vegas/223
on my horse around car red springs 1000 weight and 50% brake max
and then remove end point out of brake side till you get to where you like it
4s rx8 2650
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
