Old 01-18-2013, 12:52 PM   #1621
Originally Posted by Davewhitegt View Post
You'd never know there was 8 ozs of lead under the bumbper.
Attachment 1018989
Attachment 1018990
Attachment 1018991
Are those the same weights that tower carries? Also, did you have to trim the foam?
ducatiti is offline   Reply With Quote
Old 01-18-2013, 08:10 PM   #1622
Davewhitegt's Avatar
Congrats on getting your car. As far as if those are the ones tower carries, I have no idea. I just went to my local gas station and got tire sticky weights. In the second pic you can see how I dremelled a cubby hole in the foam to fit right over the weights. You'd never know they were there if you we're to look at the car cause the foam covered it perfectly. Do yourself a favor and just order the GRP wheels right away if you plan on doing any speed runs. I blew my ofna tires off the rim in minutes.
Davewhitegt is offline   Reply With Quote
Old 01-19-2013, 05:27 AM   #1623
Default Battery Recommendation
Hi;
I am running an GTP2e on a 5 - 8 minutes per heat on road track. I was using two 7.4 30C 5000mah connected by a Castle Creations Y connector. The batteries were fairly used on a 1/10 brushed TC3, but on my second heat on my Ofna one of the batteries "puffed". Is it due to the connection type? I am searching for the appropriate 14.8 pack to buy. I need it to last up to 8 minutes watching temperature so I think over 35C will not be an option. We run on very hot conditions.
ESC: Mamba Monster
Mot: 2,200
Thanks in advance
waldotm is offline   Reply With Quote
Old 01-19-2013, 06:15 AM   #1624
You may have taken the battery down too far in voltage
brushless55 is offline   Reply With Quote
Old 01-19-2013, 11:00 AM   #1625
Thumbs down
I use a battery checker and I remember this pack was 65% after that heat. Don't remember the final voltage.
Old 01-19-2013, 03:49 PM   #1626
Thumbs down
oh man, if that's true then either your pack is used up or the C rating is not up to the demands of this system
Old 01-19-2013, 10:45 PM   #1627
FLoJo's Avatar
I wouldnt think the y splitter wouldnt cause that , but you never know . How thick is the wiring on the batteries compared to the splitter . Since you ran them and they were used before they might have just been its time . Did you have any accidents , how much did it puff ?? pics??
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 01-21-2013, 04:16 AM   #1628
"Y" connector 10AWG
Batteries 12AWG
I can't post pictures yet...
Old 01-21-2013, 06:31 PM   #1629
Made some high speed runs with the car the other day.
+ YouTube Video
Dave Fischer
Team Associated TC 6.1 Worlds Car, Ofna Ultra LX2e
http://www.youtube.com/watch?v=H_ApMtf79ZU
Old 01-21-2013, 06:46 PM   #1630
This is me crashing my LX2e (I know this is a GTP2 thread, but its basically the same exact car just a buggy version) at 85mph. Figured you guys might get a kick out of this.
+ YouTube Video
Dave Fischer
Old 01-22-2013, 02:15 AM   #1631
A little progress with this build. Here are some pictures:
Old 01-22-2013, 05:54 AM   #1632
BillyT.'s Avatar
Got my oval car up and running. Any of you guys that have converted these to on road, any setup insight?
Not really interested in high speed runs, but actual racing.
Its running a Track Star 6 pole 2650 and Track Star 120a ESC and will never see more than 4 cell. It's geared at 18/51
Suspension wise, it really just feels like it might need a softer rear spring. Will make some laps tonight and see what it's doing.
Mocked up with a Blitz body. I'm either doing a truck or buggy body, haven't decided yet....
Hard to deny how good that looks to me... Redcat Racing makes an 1/8 scale truck that has a 325mm wheel base and is 305mm wide. Prolly my best option for the truck body unless anyone else knows differently.
Nemo Racing USA
Agama : Bullitt : Beta
billy@nemoracingusa.com
BillyT. is offline   Reply With Quote
Old 01-22-2013, 11:51 AM   #1633
BillyT.'s Avatar
Already broke the front diff housing/hinge pin holders... Ahh the perils of racing on an old go cart track...
Nemo Racing USA
Old 01-22-2013, 01:31 PM   #1634
Monteman's Avatar
Trader Rating: 16 (100%+)
Take a peek at the specs on the Associated SC8. i run one on my ERBE-gt. Might be able to finesse the wheel wells to work.
Might be a touch too long though.
*** no way will it fit. tried it once i got home. Not a chance. Forget i ever mentioned it ****
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 01-22-2013, 07:18 PM   #1635
