Xray T3 2011
#1367
#1368
Normally there is a small amount amount of air above the bladder which compresses when the piston moves upwards.
Skiddins
#1370
Has anyone measured the corner weights of their car and what were the results?
Mine was;
272g front left
266g front right
302g rear left
302g rear right
This was with 1mm shim at front wishbones and 2mm at the rear.
Skiddins
Mine was;
272g front left
266g front right
302g rear left
302g rear right
Skiddins
#1371
It's interesting you have the most spread at the front with the left front being the heavier. It's only a 6g difference, but mine was also heavier on the LF with equal rear weight before rechecking for bent screws, equal shock lengths, etc.
#1372
I corner weight my car. I can get you the exact numbers in a few days when I get home, but I'm pretty sure I'm close to 25% on each wheel, total weight at 1380g w/ body.
Skiddins
