Xray T3 2011
#1966
Think it will be better to kit out drives then
Skiddins where did u get ur upper clamps from if u can still
Buy them ?
Buy them ?
#1967
Hi there looking for a new servo for my T3 any suggestions and what are u guys using? If savox which is the best one?
#1968
Another shock building question...
I followed the instructions below to build aluminum shocks. One thing I noticed is that after bleeding the shocks, the cap closes to a certain point but once the shock shaft is fully extended, the cap can screw on significantly. Once it's tightened, the shock does not move properly which is obviously undesirable.
Has anyone else found this to happen? Are you leaving it tightened to the initial cinch down (after bleeding while keeping the shock fully compressed) or am I doing something wrong in the building process?
#1971
Does KO 2413 LO Pro servo use front mounting holes
I need room for electronics and was wondering if anyone knows if the KO 2413 Low Profile Servo uses the front mounting holes. I don't want to cut the ear off and do not have room with my futaba servo because it uses the rear hole. If not what servo uses the front holes in the 2011 chassis
#1972
#1974
I only ever used to use those indoor, and now I don't do that either.
Elliot Harper told me that they can also reduce the amount of steering, so I haven't used them since.
They will obviously last better than the kit items, but you will wear out the blades you require to run those.
Skiddins
Skiddins
#1975
Have you read the Litemodz thread!
The company are unreliable, have crap quality control and seem to have trouble sending out any parts.
I also had problems when they were TiR.
Their driveshafts were great, when they weren't falling apart.
#1977
Not sure. The plastic shocks work perfectly fine. They are a little more tricky to build, but when done correctly they aren't bad at all. I'm currently running the Xray aluminum shocks mainly because the threads on the body don't get all screwed up from dirt.
I would start with a spool up front and use either 1-2K diff oil in the rear diff. 1K will make the car rotate harder off power, while 2K will make the car feel smoother and more stable.
-Korey
-Korey
#1978
-Korey
-Korey
#1979
I bought the tamiya black shocks since i always get my plastic ones broken because of my driving and when i decided to hop up the suspension, i chose for the cheaper alternative.
the tamiya shocks work great with the xray springs i must say and no regrets here.
+1 on the 2k oil for the geardiff, it's a good starting point and it runs smooth and has more push compared to the ball diff.
#1980
-DC-
