EPIC "D3" Duo 3
#436
#437
HI
I want to buy a motor d3, orion vortex or lrp 12x 13.5t, I wanted to know if therm in performance and reliability (heating) the trinity duo 3 was well over the two other engines
regards olivier
regards olivier
#438
Loving them so far!
Paul
#439
A tekin rs pro
#441
D3 not working from new
Hi all..
Has there been any issues with these motors?
My motor is dead on arrival? wont work on any esc I have..
Searched the thread and cant find any thing..
Bought a 17.5 express motosports version..
Not esc as duo 2 no problems..Its the motor.
#442
help
Hello, someone uses the D3 engine speed controllers with passion??
tell me how??
thanks
tell me how??
thanks
#443
What are you running, stock spec or boosted 17.5? What ESC? If you are running Tekin, I can send you my setup to get you started.
#444
Duo and SP
Im using the duo3 10.5 with 1s lipo and the SP esc 120AMP version It runs fine but suffering a bit as getting very hot 91c need some settings and rollout for 1/12th and WGT.
#445
Motor is not working
These motors are excellent. To reinforce what was said earlier, they are much better than the LRP X12 which tends to get hot and lose rip. With proper ESC settings, the D3 has nearly no fade and runs super cool. High recommended. If you liked the Duo2, you will LOVE D3.
What seems weird..I thought that buying an Express, is that they are indavidually checked and ran..If that is true..why is mine dead on arrival?
#446
Team EAM
Using SXX V2 4.4...No problems with the esc..I purchased a new D3 17.5 express..and dead on arrival..I tried it on 3 different esc's..and no good..A friend at the track yesterday said that some D3's had some issues and just wanted to know if there is a fix before I send it back..I have contacted Amains and Express motorsports..
Go on the Team forum section here and there is an Express threat that John Tag (Owner) visits daily. He is a good guy and will be more than happy to help you out and get the problem rectified. Only reason I say post something there is he may not see it here. I know he has been on Vacation in FL last week and maybe this week as well so it may be a few days before you get a reply.
EA
#449
Open for thoughts on this one.
Recently ran at a very LARGE track. Straight is approx 60-70 metres in length.
D3 set to 0 timing
Tekin RS Pro settings -
Turbo - 16
Boost - 55 (Max)
Ramp - 3
Timing - 95
Delay - 0.02
Start - approx 3500
End - 18001 approx
Gearing - 6.82
Car could punch from corners well, but lacked a little top end, not much, just enough though to have cars pull about 1-2 feet by the end of the straight. Motor ended average 80 degrees after 5 minutes, plus 1 warm up lap. Ambient air temp 19 degrees.
Any ideas on how to have got more from the top end ? as mentioned punch was excellent and didnt fade, but top end just wasnt there.
D3 set to 0 timing
Turbo - 16
Boost - 55 (Max)
Ramp - 3
Timing - 95
Delay - 0.02
Start - approx 3500
End - 18001 approx
Gearing - 6.82
#450
D3 set to 0 timing
Turbo - 16
Boost - 55 (Max)
Ramp - 3
Timing - 95
Delay - 0.02
Start - approx 3500
End - 18001 approx
Gearing - 6.82
D3 set to 0 timing
Turbo - 16
Boost - 55 (Max)
Ramp - 3
Timing - 95
Delay - 0.02
Start - approx 3500
End - 18001 approx
Gearing - 6.82
You have too much timing too soon. Dropping your boost to 50 from 55 will also help.
