How do you program the LRP sphere tc Esc?
turn the esc on and then you have to press "mode" for a few seconds. now you are in mode#1.
if you press "mode" again you are in mode#2
On the case of the LRP Sphere, the names Mode and Set are molded into the plastic. Mode is the 1st hole from the left, Set is the 3rd hole from the left, while the other 2-holes are for the LEDs.
To enter programming mode, turn the ESC on, then press and hold the Mode button for about 3-seconds, until the LEDs start blinking.
