Old 06-20-2004, 11:26 PM   #1
Default Have a Quick Question
Hey will these Ballbearings fit on my electric traxxas wanna save some money...Ball Bearings
Plz Help me out thx
coreo2k4 is offline   Reply With Quote
Old 06-21-2004, 02:36 PM   #2
Thumbs up bearings
well you just have to make sure the bearing spec's are a match to yours .. that info is in your manuel , if so your set ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 06-21-2004, 07:31 PM   #3
Charlie O's Avatar
If you are buying them in person take your car with you, a pair of calipers, (they probably have them at your hobby shop you can use them free) check all the tolerances against your stock bearings, Id, OD, thickness, just cause the package says they are the same dimensions is no guarantee they are. I had this happen, in a pinch with my TC-3 they were out of associated bearings, so they sold me XTM 's all the packaging said they were the same size, but they would bind on the axle, not much, and when you tightened the lug nuts, even more. so check them if you can, if not make sure you can return them, good luck.
Charlie O is offline   Reply With Quote
One quick question. WingZero Nitro On-Road 13 07-15-2007 11:32 AM
Quick 18t/mt/b question fig865 Micro and Mini Scales 4 11-13-2006 07:49 AM
a quick question benraldo the ho Electric On-Road 7 03-29-2004 10:46 AM
quick question seaball Electric On-Road 2 06-09-2002 04:05 PM
SEO by vBSEO 3.5.0
