Old 05-23-2011, 08:39 PM   #1441
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Originally Posted by chrisk View Post
just building my new 417 and have been told that cutting the motor mount is the way to go.
I see some say Yes and No to this, what are your thoughts???
running med grip asphalt track, 21.5 non-timed
thanks for nay feedback
I haven't gotten my kit yet, so still haven't run the car. From what I've been told, cutting the motor mount is the way to go for asphalt tracks as it makes the car much easier to drive. I've ordered a spare motor mount as well though, so when my kit and parts arrive I'll be able to give more hands-on feedback.
Old 05-23-2011, 08:57 PM   #1442
Tron's Avatar
Trader Rating: 16 (100%+)
You have to try it to see if it suits the track you're on and your driving style.
Do you run on one track or multiple? Do you like to tune your car all day or drive it?
I run mostly on high grip asphalt and did not like the cut mount, I felt the car had more overall stability with it uncut and more mid corner speed.
Randy where are you going to run mostly? WCRC?
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 05-23-2011, 09:37 PM   #1443
chrisk's Avatar
Trader Rating: 32 (100%+)
Thanks Randy, Tron
only run at the one track so i will purchase another mount and try them to see how it feels back to back,
cut v non-cut v my ultra reliable smokem 416
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 05-23-2011, 11:37 PM   #1444
Most likely will be running at WCRC and TQ Raceway. Tamiya USA's track for practice if a bigger outdoor event is coming up.
Old 05-23-2011, 11:37 PM   #1445
Thanks Randy, Tron
That's the best way to do it
Old 05-24-2011, 02:01 AM   #1446
I would run the uncut mount first and see how that goes.
Then I would try the rubber o-ring trick under the motor mount.
Then try a cut mount.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-24-2011, 02:40 AM   #1447
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
That o-ring trick have you tried it ?
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 05-24-2011, 04:29 AM   #1448
chrisk's Avatar
Rubber oring trick???
Can you explain please
smaracing.org
Old 05-24-2011, 07:30 AM   #1449
TryHard's Avatar
eh? Unless your happy to machine away a load of material, no way your gonna get an o-ring under the mount.
Now, if you mean rubber o-rings under the top deck screws, then I follow
Old 05-24-2011, 08:48 AM   #1450
Chrissy C's Avatar
Hi, quick question (hopefully)...
What are the differences between the 416WE and 417 front and rear bulkheads? Is it the height the top decks are mounted - if so any idea on the height difference?
Despite the new bulkheads on the 417 am i right in thinking that they are spaced the same so that diffs etc can be transferred from model to model?
Thanks for your help
Chris
Chrissy C is offline   Reply With Quote
Old 05-24-2011, 09:32 AM   #1451
hana166's Avatar
Chris
The bulkheads are not spaced the same, they are closer together, but the 416 diffs still fit
hana166 is offline   Reply With Quote
Old 05-24-2011, 01:23 PM   #1452
I used to do it on my Ta05ms to get grip outside (the chassis is very stiff).
Two ways to do it.
1) You can fit std o-rings between the top deck and the aluminium parts (bulkheads + motormount) and screw it down. This gives you more flex. You will need 12 soft O-Rings.
Simple more flex solution, costs pennies.
2) you need 13 O-rings. Firstly put 5 o-rings under the motor mount, between the mount and the chassis and screw them in. Then on the top deck fit the 8 o-rings between the top deck and the bulkheads. The 4 remaining screws attach the top deck to the motor mount without o-Rings (to offset the bottom O-rings underneath).
It raises the centre transmission up by 0.5-1mm depending on what o-rings you use, but allows the centre to twist more.
You have to take care that each screw is squeezing the 0-Rings the same amount, also use the same type of O-rings or you will have different tolerances.
I Dont race Mod only 10.5t and don't profess to be a pro, but it worked a treat on my MS on Tarmac. I have fitted it on my 417 as a test but not had a reason to race this set-up yet.
Oh and don't use aluminium screws as they will strip as you need to use a fair bit of pressure.
Old 05-24-2011, 05:31 PM   #1453
Default Rookie 417 setup sheet question
Guys:
For the shimming of the FR suspension mount (reversed), all setup sheets that I've seen thus far state using between 0 and 0.5 mm shims in this area.
When looking at the instruction manual, there are two shims used, one 3mm and another 0.5 mm. Does this not equate to 3.5 mm? or it the 3mm considered a spacer and not shim?
Appreciate your responses.
Thx!!
mhavlena is offline   Reply With Quote
Old 05-25-2011, 02:21 PM   #1454
YmeBP's Avatar
Hey guys new to the 417, couple questions:
Top 2 things i need to do out of the box?
Are gear diffs needed both front and rear or just one side of the car to run 8.5t mod?
Thanks again!
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 05-25-2011, 02:30 PM   #1455
RC MARKET's Avatar
HK Peoples Front Gear Diff. used 500000 Kyosho
RC MARKET is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
