Like Tree1Likes
Old 05-17-2011, 08:36 PM   #1426
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by the greek View Post
scales can be affected by droop and/or preload settings.
You're absolutely correct and that's why scales are the "Best Method"
Why would anyone go out on the track with different droop, shock lengths, and/or preloads on your car and expect it to handle or be balanced You also need to use setup wheels to ensure even positioning and weight.
Therefore, the only variance from the scales to the track are wheels, inserts & tires...
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-17-2011, 10:35 PM   #1427
kedal's Avatar
Originally Posted by mhavlena View Post
lipo = protek 5000 mah
speedo = Tekin RS pro
Rx = Spektrum SR3001 (good thing i'm not using the SR3500)
big fan on motor
With body + clips + tires... = 1350g.
Allowed weight = 1440g.
I need to find place for 90g worth of weight. Going to be messy
Oh, you need to add weight to reach the minimal weight ?
It's not 1350gr everywhere ?
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 05-17-2011, 10:46 PM   #1428
defcone's Avatar
Trader Rating: 15 (100%+)
1425 in aus as well shove weight down the center line, bumper infront of servo and other side infront of battery and behind motor these places shoul keep your car fairly balanced
defcone is offline   Reply With Quote
Old 05-18-2011, 03:25 PM   #1429
Which lead weights are recommended? Especially if one wants to put some down the center, if they are too high, they may interfere with the belt.
Recommendations are appreciated.
Thx!
mhavlena is offline   Reply With Quote
Old 05-18-2011, 09:24 PM   #1430
defcone's Avatar
Thx!
I have the 3racing ones which are covered with carbon fibre sticker, but any lead weight strips you find in rc stores will be fine. You could also buy a strip which xray or yokomo make which is 30grams and is sloped so that it avoids the belt.
Hope this helps.
Old 05-18-2011, 09:51 PM   #1431
kanslide's Avatar
this thread helped!
Built not bought!
kanslide is offline   Reply With Quote
Old 05-19-2011, 06:11 AM   #1432
Hi,
Don't know if this has been asked before but can you convert a 416 too a 417 ? and does alot of the parts from a 416 fit the 417 ? as I was thinking of getting a used 416 with spares and later on converting it to a 417 and/or using the 416 for spares etc.
Thanks.
S.A.W is offline   Reply With Quote
Old 05-19-2011, 07:52 AM   #1433
Nope, it would cost more tO buy the parts than it would to buy a new kit.
Some parts are the same (suspension blocks, arms, diffs would fit in the bulkheads) but all the rest of it is different.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-19-2011, 03:35 PM   #1434
Hope this helps.
Are the holes for the Xray 30g center weight distanced perfectly for the 417 chassis such that the screws can be used to bolt it down? or do we have to use double sided tape?
Thanks!!
Old 05-19-2011, 03:59 PM   #1435
I raced my 417 tonight on a very tight indoor carpet circuit on foams.
I am amazed how fantastic the car handled! I didn't run additive (burns my skin) I made a few changes based on my old settings but the consistency, grip and rotation of the car just helped me steam straight up to the front of the field.
Sorry if it's a bit of a pointless post, just really pleased how well it drove!
Old 05-19-2011, 09:08 PM   #1436
defcone's Avatar
Thanks!!
i am not sure what you could do is use one screw and double sided tape the.rest in
Old 05-19-2011, 10:46 PM   #1437
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm sure 1 screw would hold the weight down well enough without double sided tape. Use loctite if you want to be sure though.
Old 05-23-2011, 12:47 PM   #1438
kedal's Avatar
If I want to use the separate suspension mount of the TA05, I need to use the 1C-1XC for the front, and the 1A-1XA for the rear, right ?
Old 05-23-2011, 07:21 PM   #1439
chrisk's Avatar
Trader Rating: 32 (100%+)
yep
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 05-23-2011, 07:24 PM   #1440
chrisk's Avatar
Default Cutting the motor mount
just building my new 417 and have been told that cutting the motor mount is the way to go.
I see some say Yes and No to this, what are your thoughts???
running med grip asphalt track, 21.5 non-timed
thanks for nay feedback
smaracing.org
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
