Like Tree1Likes
Old 05-16-2011, 01:01 PM   #1411
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
nice. that's quick work.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-16-2011, 01:33 PM   #1412
TryHard's Avatar
1F comes in just under 48mm pin to pin I think (haven't got one to hand), and the 1E is the next one down at about 47mm. Hope that helps... I know 3Racing do some
BTW Seaball, that avatar is waaaaaaaay too creepy!
| THard.co.uk | Xray | MuchMore |
Old 05-16-2011, 02:01 PM   #1413
seaball's Avatar
i can't disagree with that.
say, would you tell me the screw spacing of these blocks (c-c)? i figure i'm going to be hacking my chassus up, but it wouldn't hurt to know ahead of time by how much.
thanks again for the quick answers, gents. every now and again i forget to hate this forum.
Old 05-16-2011, 02:15 PM   #1414
mickrcarver's Avatar
Trader Rating: 98 (99%+)
right around 28.5mm
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 05-16-2011, 03:47 PM   #1415
Vicko's Avatar
Trader Rating: 14 (100%+)
seaball the Teacher may have extra toe block for the Pink car
Vicko is offline   Reply With Quote
Old 05-16-2011, 04:10 PM   #1416
Default Where does everyone put their weights/leads to meets min regs?
Pics would be nice...
Seems like not too much place to put weights.....little bit on each corner, perhaps in the center of the chassis between electronics and batt? Do people stack the weights? It's looking like I have to add 90grams of weight!!!..Help!!!
mhavlena is offline   Reply With Quote
Old 05-16-2011, 10:33 PM   #1417
kedal's Avatar
90gr is a lot !
What lipo and speedo do you use ?
If you want to add weight on the lipo's side, try to move the lipo more outside, it's works very well to have a good balance.
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 05-17-2011, 03:19 AM   #1418
where can I get some chassis balance pins to balance my 417? I see it has holes on the chassis for them.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-17-2011, 06:44 AM   #1419
hudy make them
Smartypants is offline   Reply With Quote
Old 05-17-2011, 07:04 AM   #1420
crabboy's Avatar
Trader Rating: 58 (98%+)
There is another way of balancing the chassis instead of using balance pins, if you look at the front and rear shock towers you will see a small nick on the under side of both towers almost in the middle of the shock mounts, you use two small allen drivers one each end in the small nicks and lift the chassis, it will fall towards the heavy side.
Hope it make sence have a look at the towers and im sure you will get the idea.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 05-17-2011, 07:08 AM   #1421
cheers guys
I never noticed the little nicks on the shock towers!
Old 05-17-2011, 07:28 AM   #1422
2-Bad's Avatar
Trader Rating: 24 (100%+)
Or buy yourself a set of these Scales....
Perfect for the job. My 417 with it's electrics & lipo are well matched (as I assume most will be too) and only needed to throw some weights down the center of the chassis to get it up to legal....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-17-2011, 08:43 AM   #1423
kedal's Avatar
I noticed this nicks, but wonderring what it was for !
Thanks for the tips !
Old 05-17-2011, 04:34 PM   #1424
scales can be affected by droop and/or preload settings. the shock tower method is best.
the greek is offline   Reply With Quote
Old 05-17-2011, 06:29 PM   #1425
Originally Posted by kedal View Post
90gr is a lot !
lipo = protek 5000 mah
speedo = Tekin RS pro
Rx = Spektrum SR3001 (good thing i'm not using the SR3500)
big fan on motor
With body + clips + tires... = 1350g.
Allowed weight = 1440g.
I need to find place for 90g worth of weight. Going to be messy
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
