Like Tree1Likes
Old 05-15-2011, 02:19 AM   #1396
kedal's Avatar
Yes HPI spring are little better, especialy during high/medium speed corner, when the car turn it tazke less rolling.
But be carrefull, there is 2 silver spring, same ref : the chrome one, and the black one.
The chrome one is totally round while the black one has a flat contact surface.
A guy on my club has both and he can feel a difference between the black and the chrome ones but dont really know wich one is the best.
I have the black ones.
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 05-15-2011, 03:38 AM   #1397
G-rem's Avatar
Hello everyone,
just a little question about the final ratio on a TRF:
I drive with a SP 10.5R motor and a SP GT2.1 Prostock esc on big track, and people in my club told me I had to have a final ratio of 5.7.
So I look in my gears for this ratio, but I do not have 38 teeth pinion motor.
And as I have the Tamiya original 0.4 module spur gear, I do not know if I can wear this with 64DP gear motor, as RW, for example.
So, can I put 64DP gears with module 0.4 spur gear? Or do I have to find a motor pinion 38 teeth in Tamiya 0.4 module to be compatible?
Thanks for your answers and see you soon,
G-rem
PS: nice to meet you here Kedal ;-)
G-rem is offline   Reply With Quote
Old 05-15-2011, 03:40 AM   #1398
kedal's Avatar
Hey G-Rem, I give a reply on the 416 topic, the same I give you on PetitRC forum
Old 05-15-2011, 04:43 AM   #1399
G-rem's Avatar
Seen it, thanks boy
Finally a clear answer ;-)
See you on PRC,
G-rem
Old 05-15-2011, 08:57 AM   #1400
RC MARKET's Avatar
So Tamiya releasd TRF DAMPER LARGE DIAMETER RETAINER
RC MARKET is offline   Reply With Quote
Old 05-15-2011, 11:08 AM   #1401
RL.2002's Avatar
how much the price of it??
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 05-15-2011, 05:32 PM   #1402
Default Xenon VSS spur not spinning true when attached to the center shaft/pulley holder
I have tried qty 4 Xenon VSS spur gears 100T, when attached to the center holder and installed in the car, the spur wobbles like crazy and interferes with top deck.
when re-installing the stock 111T Tamiya spur, there's no wobbling whatsoever...???
Has anyone experienced this? If so, any fix would be appreciated.
Thanks!!
mhavlena is offline   Reply With Quote
Old 05-15-2011, 07:12 PM   #1403
MikeXray's Avatar
Trader Rating: 73 (100%+)
Is there more than one white 3 hole piston? if not what is the diameter of the holes? 1.1mm?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-16-2011, 06:54 AM   #1404
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Thanks!!
I had the same problem with my spurs Must be a bad batch or something as others have no issues what so ever
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 05-16-2011, 07:45 AM   #1405
zamrioo2
No problem
Yes, you are correct, placing the weight more forward will make the car easier to drive, but it will also have less steering. Therefore, having the weight further forward may not always be faster... I think this is the reason we use the layout we do. Also it is easier to make the electrics layout look neater lol
Team Durango, ORCA, MuchMore, Sanwa, Protoform, Tonisport, MR33, Roche, Custom Blitz Bodyshells
Elliott Harper is offline   Reply With Quote
Old 05-16-2011, 12:05 PM   #1406
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
guys, i hate to barge in, but i have an urgent question regarding the supension pivot blocks. can any of you tell me which block would measure ~ 47.5mm from pin to pin (on center)? i'm assuming it's going to be a rear/rear toe block of some sort.
(fwiw - i was shorted a block on an order for the sakura car, and getting one of these is seemingly a month long project).
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-16-2011, 12:18 PM   #1407
mickrcarver's Avatar
Trader Rating: 97 (99%+)
I'm coming up with the 1F block
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 05-16-2011, 12:33 PM   #1408
Thanks!!
It is ok, there is a difference in the thickness of the spurs.
You should have a thin spacer when you use the Tamiya spur, you'll need to purchase another one -to take up the difference in thickness.
So - 2 spacers and your Zenon spur, and you'll be fine, as long as you place the spacers on each side of the spur.
Hope this helps.
Awesomatix USA, AVID, Serpent USA / Desoto Racing, Team Scream, LRP, Psycho Cells Racing, Sweep Racing, Hurricane Motorsports, Core Creations, Hobbytown USA of K.C., 2mm Design and ProLevel
BSYDOR is offline   Reply With Quote
Old 05-16-2011, 12:36 PM   #1409
seaball's Avatar
yeah, that's about as wide as there is, right? (tam54074)?
Old 05-16-2011, 12:52 PM   #1410
Thats the widest I have found,yes on part number
http://www.thard.co.uk/viewtopic.php?f=49&t=30
www.ovrccc.com
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
