Old 04-27-2011, 10:05 AM   #1351
@kiloolli
Have you checked that all of the aluminium parts are not bent? If so, try replacing the screws that secure the aluminium parts to the chassis with new ones. This can get rid of many tweak problems as the screws may have become slightly bent and it can be hard to notice this
Hope this helps
Thanks Elliott,
I have all the screws removed and the tweak is almost gone. I found on Toni (Toni sport) already ordered new screws. I'll report back if I have changed everything.
kiloolli is offline   Reply With Quote
Old 04-27-2011, 01:15 PM   #1352
Originally Posted by VooDooPH View Post
what's the difference between running a softer oil vs a harder oil for the gear diff at the rear? how do you know which way oil to use when tuning the car (i.e. when the car pushes on corner entry use a thicker oil?)
Hi,
I find that a softer oil in the diff makes the car change direction faster and become more aggressive.
Harder oil gives more on power steering, but less turn in, in my opinion
Hope this helps
@kiloolli
Good to hear, let me know if the new screws help
Team Durango, ORCA, MuchMore, Sanwa, Protoform, Tonisport, MR33, Roche, Custom Blitz Bodyshells
Elliott Harper is offline   Reply With Quote
Old 04-27-2011, 02:39 PM   #1353
I found on our track which is a tight track\ technical the gear diff in the rear would push on coner exit, so I use gear diff in front and ball diff in rear. If I run the ball diff a little lose the on power steering is better but I have some slip, should I use 800 instead of 1000 in the rear or more somthing on the suspention like less rear toe???? Is my experience with the gear diff correct?? Thanks.
charl mac is offline   Reply With Quote
Old 04-27-2011, 08:48 PM   #1354
Default Shimming of suspension arms - binding?
Is it common for the suspension arms to bind with the recommended shims from the manual?
The rear suspension arms from my kit was spot on, but the front suspension arms were binding. I removed some shims to rectify...
Anybody else experience this? Just wanted to make sure I didn't do screw up something else during the build.
Thx
mhavlena is offline   Reply With Quote
Old 04-27-2011, 09:54 PM   #1355
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by Elliott Harper View Post
Hi,
Hope this helps
@kiloolli
Helps a heap! Thanks!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 05-02-2011, 09:41 PM   #1356
padailey's Avatar
Anyone know what parts are needed to build a ball diff.... I'm not sure what all comes with the diff halves.
Is the following list correct?
51446 - Diff halves, screw, nut, spring, thrust washers, thrust balls, and blades (I saw a pic that looked like all these parts were included but the description only states the diff joint, screw, nut and Y parts (blades))
51442 - ball diff plate
42142 - 3mm ceramic balls (12) - need 12 total
or 53379 - 3mm balls (10) so would need 2 packs
53988 - 37T pulley
42111 - 850 bearings (2)
9804372 5x1.5mm spacer
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 05-03-2011, 09:55 AM   #1357
EDWARD2003's Avatar
Default Selling my 417
Dearest 417er's, it is with great regret that I will have to sell my 417. For the indoor series is over and also I will be leaving the country in the near future. If anyone is interested pm me.
Cheers,
Edward
EDWARD2003 is offline   Reply With Quote
Old 05-03-2011, 01:27 PM   #1358
Hi, yeah, harder oil in the rear gear diff will give more on power steering but a little less into the corner... I prefer the gear diff as there is no slip compared to the ball diff
You can also try things like less rear toe like you mentioned and a stagger in ride height (little higher rear)
Hope this helps
Old 05-03-2011, 04:44 PM   #1359
Thx
It is common the easiest way to rectify this in my experience is swap the 0.5mm shims with a 0.3mm shim
Bony85 is offline   Reply With Quote
Old 05-04-2011, 01:59 AM   #1360
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
I was looking for silver HPI springs does anyone know what's the part number?
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 05-04-2011, 03:48 AM   #1361
LOL
Old 05-04-2011, 03:43 PM   #1362
mickrcarver's Avatar
Trader Rating: 98 (100%+)
HPI6543
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 05-04-2011, 06:12 PM   #1363
thanks
Old 05-04-2011, 08:53 PM   #1364
cuboi's Avatar
Iv bought the last one.. Last piece in the world
cuboi is offline   Reply With Quote
Old 05-07-2011, 01:26 AM   #1365
Trader Rating: 16 (100%+)
Originally Posted by CraigM View Post
Here are a few of my favourite quotes from Mr "struggled for 4 years with no rear grip"
and probably my favourite
Awesome post Craig!
SANWA / TEAM ORION / PRO-LINE / PRO-SPEC / P1 BRAND / PROTOFORM
I'm not a Business man, but I'm the Bizzness man!!!
Sean Williams is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
