Like Tree1Likes
Old 04-23-2011, 09:59 AM   #1321
Originally Posted by mwoods View Post
Can someone tell me the spring ratings for these springs
http://demonpowerproducts.co.uk/prod...oducts_id=3856
Anyone?
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 04-23-2011, 10:07 AM   #1322
Tron's Avatar
Trader Rating: 16 (100%+)
Anyone?
http://www.petitrc.com/reglages/1-10...pringChart.pdf
This has it all bro.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 04-23-2011, 10:11 AM   #1323
Originally Posted by Tron View Post
Old 04-23-2011, 10:19 AM   #1324
Tron's Avatar
Does anyone run anything other than kit sway bars on their 417? I can't seem to find any option sway bars that are specifically made for this car. I see TA05 ones but they are rainbow colors.
Any suggestions?
Elliot if you are still watching this thread I think it would be cool to see some of your comments on setup and things you do to your car to achieve different handling. As you can see there is lots of talk about how narrow the setup window is, etc.
"Slow Sportsman"
Old 04-23-2011, 10:33 AM   #1325
Hi,
yes no problem, in answer to your first question, i've never actually tried any other sway bars other than Tamiya so i'm not sure...
As for the setup, I normally like to try and find a good basic setup that works well at most tracks. I do this by testing at home and then when we go to the big races and nationals, the car should always work well to start with. I find that changes such as springs, shock oil, roll centres and shock positions are good to test with to find a basic setup that works for you. From there, at the race you can just change these by small amounts to fine tune the setup.
Hope this helps?
Elliott
Team Durango, ORCA, MuchMore, Sanwa, Protoform, Tonisport, MR33, Roche, Custom Blitz Bodyshells
Elliott Harper is offline   Reply With Quote
Old 04-23-2011, 04:24 PM   #1326
crabboy's Avatar
Trader Rating: 58 (98%+)
Do you play around with roll centres much or mainly oils and springs, Thanks.
Rhys
Originally Posted by Elliott Harper View Post
Hi,
Hope this helps?
Elliott
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 04-23-2011, 08:30 PM   #1327
AWK
AWK's Avatar
How are you guys cleaning the TRF flourine sealed bearings? The same as the traditional metal shielded bearings?
AWK is offline   Reply With Quote
Old 04-23-2011, 08:44 PM   #1328
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Whenever I clean bearings out I pull the seals off and blast them out with motor spray until they spin free and smooth, once they dry I give them a drop of bearing oil and good to go. If I can't get them smooth, I replace them.
Old 04-24-2011, 04:02 AM   #1329
I've been checking out my car today and managed to get rid of a lot of the slop in the steering. For the steering bridge I kept the 0.1 and 0.7mm shims but also added a STD tamiya washer on the top and bottom of the screw. This took out loads of the slop and it's still smooth.
On the steering posts I just added 0.2mm under each to stop the lift. The steering is nice and smooth and a lots less sloppy.
(updated here is a link to my bog with pics)
http://thercracer.blogspot.com/2011/...-slop-fix.html
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 04-24-2011, 04:42 AM   #1330
RL.2002's Avatar
Originally Posted by Qatmix View Post
I've been checking out my cat today and managed to get rid of a lot of the slop in the steering. For the steering bridge I kept the 0.1 and 0.7mm shims but also added a STD tamiya washer on the top and bottom of the screw. This took out loads of the slop and it's still smooth.
got any picture of it??
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 04-24-2011, 04:49 AM   #1331
TRF Forever! I've been testing a front gear diff with ofna diff lock. Works amazing!!!
Turillo is offline   Reply With Quote
Old 04-24-2011, 06:52 AM   #1332
Rhys
Hi,
I think both are really important to have a good handling car
On carpet, I use 450 to 550 oil with White and Blue Tamiya springs.
For the roll centre I use 5mm under the front and 4mm under the rear link. Under the blocks I always use 0.5mm at the rear. For the front, anti dive 0 and 0.5 or flat 0.5 0.5.
On Asphalt, I use 400-500 shock oil with HPI silver springs (sometimes blue but silver 90% of the time)
Under the blocks, again I always use 0.5 under the rear, but at the front I change between 0 and anti-dive 0 and 0.5
With the shims under the links, I change this a little more on asphalt between 3.5-5 at the front and 3-4 at the rear. (I always keep at least a 0.5 difference between the front and rear)
Hope this helps
Elliott
Old 04-24-2011, 07:40 AM   #1333
Yup, check my blog
Old 04-24-2011, 09:03 AM   #1334
crabboy's Avatar
Cheers budddy thanks.
Rhys
Hi,
Hope this helps
Elliott
Rhys Marshall.
Old 04-24-2011, 09:42 AM   #1335
RL.2002's Avatar
Thankz mate. Gonna try it later
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
