Old 04-16-2011, 12:30 PM   #1246
Trader Rating: 69 (100%+)
Originally Posted by GerwinGood View Post
Hello all,
I recently got my TRF 417 (first tamiya) and so far so good.
Been testing alot with the setup but got a few questions.
The track im running has low grip currently
1. Rear grip problem, on throttle the rear is very loose.
2. Any advice to get more steering in the car?
I've uploaded a setup sheet of my current setup.
http://www.gerwingood.nl/RC/TRF417_16-04-2011.pdf
Thanks all, if need more info just ask.
The setup sheet doesn't state your droop or down travel. I would say try the following, in order:
1. Increase droop both front and rear, with front a bit more than rear.
2. Switch to a grade softer spring at the back.
3. Reduce front toe to 0.5 or 0.
4. Sauce the whole rear tires, and only inner half of front tires if you're using any.
5. If still no improvement, move the rear outer upright hole from outer to inner to increase camber gain at turning.
6. Change to different tires, like Sorex 28R. Lower grip means your tire won't heat up as much to the proper tire temperature range. I ran Sorex 32R at medium grip asphalt only when temperature is above 20 degress Celsius. Lower than 20 I use Sorex 28R.
eComet is offline   Reply With Quote
Old 04-16-2011, 12:41 PM   #1247
Thanks for the feedback and will try it out.
Any more feedback is welcome
GerwinGood is offline   Reply With Quote
Old 04-16-2011, 07:15 PM   #1248
chrisk's Avatar
Trader Rating: 32 (100%+)
thanks for the help
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 04-16-2011, 11:06 PM   #1249
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Originally Posted by chrisk View Post
thanks for the help
No prob post some pics up
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 04-17-2011, 12:50 AM   #1250
chrisk's Avatar
just got the car last week and i have been lucky that it has been raining hard here for two days so i have been able to get it 90% done, will post some pics during the week
what an awsome car to build
smaracing.org
Old 04-18-2011, 05:16 PM   #1251
chrisk's Avatar
what is the smallest Spur you can run so you can still get to the engine mount screw?
i am running non-timed 21.5 so i am down at 3.5 fdr
i have spur 69, pinion 38, but no luck getting to the screw.
the only option i see is to drill a hole towards the outer edge of the spur to give my hex-driver access to the motor mount screw.
what else has anybody else done for this problem?
smaracing.org
Old 04-18-2011, 05:22 PM   #1252
Tron's Avatar
Trader Rating: 16 (100%+)
I run 17.5 and what I do is set the mesh and pin the one motor mount screw you can get to, then lift out the center diff and do the 'hidden' one.
When I change my pinions I always have the top deck off, I find it much easier in 17.5 and 21.5 with the pinion sizes we have to run.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 04-18-2011, 06:49 PM   #1253
chrisk's Avatar
thats a good idea
i only run at the one track so i dont usually change pinion spur much
so thanks heaps
smaracing.org
Old 04-18-2011, 07:33 PM   #1254
TryHard's Avatar
Hello all,
I agree with most of what eComet says, what you describe sounds symptomatic of a general lack of grip (loose on power, no steering).
I would suggest tyres should be the first thing to change, sorex 28's would deffinetly be a good start, otherwise heat up the 32's a lot (say 60+ C on tyre warmers). Tyres are 75% of the setup when in an open tyre formula, get those right and your already be improving
Then try the droop, 5 Front 4 rear seems to work best in low traction.
Spring change should be helpful too (either to Pink front, or Blue rear, depending on how you track is), or maybe try going out on the rear tower one hole.
HiH
Ed
Old 04-18-2011, 09:36 PM   #1255
AWK
AWK's Avatar
Honestly, I have been running my 416WE with the Tamiya lipo chassis in 17.5 no boost and been quite happy with it. Is there any reason right now to replace it with the 417? I have read a lot about the rear grip issues, and running on asphalt only, I don't see that it would be an advantage for me, but I would like to hear if anyone else has some experiences between the two.
Also, maybe at this point I just wait for the 417X coming out next year (no inside information, just the typical Tamiya pattern).
AWK is offline   Reply With Quote
Old 04-19-2011, 01:37 AM   #1256
Can someone tell me the spring ratings for these springs
http://demonpowerproducts.co.uk/prod...oducts_id=3856
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 04-19-2011, 03:22 AM   #1257
Frankly speaking, for non-boost 17.5 the TRF416 would work fine. The TRF417 has beefier motor bulkheads so it's better if you're running boosted or mod motor. I have both TRF416XL and TRF417 and I intend to keep my TRF416XL for non-boosted and TRF417 for boosted class. Also, my TRF416XL flexes more than the TRF417 so for medium grip asphalt, it should grip a bit better.
For TRF417, have you guys try to cut the front upper deck link? The stock one looks like an A shape and I wonder if anyone cut the center support to make it a V shape, so to make it more flexible? I don't want to cut the motor mount and I am using the split blocks as well.
Old 04-19-2011, 09:29 AM   #1258
syndr0me's Avatar
You know what Tamiya needs? A touring car that has some f'ing rear grip on something other than the most pristine surfaces. I've been driving these stupid piece of s*** cars for 4 years now, and that problem has plagued me everywhere I go. So you know what? I'm done supporting a brand that doesn't care about North America, and only works right when the stars align. I'll be selling all this junk and buying something that works, from a company that supports racing.
syndr0me is offline   Reply With Quote
Old 04-19-2011, 09:37 AM   #1259
No problem with the cars in the Uk, and we have no grip over here.
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 04-19-2011, 09:45 AM   #1260
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Man did ya have a bad weekend of racing or what?? Wish I had some extra cash...I'd buy your 417.
My 416X works great on low-med grip carpet. I'll be trying it on a parking lot track in the up coming months. Is the 417 really that bad?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
