Old 04-12-2011, 09:00 PM   #1216
syndr0me's Avatar
Trader Rating: 32 (100%+)
Yellow springs look a LOT like white springs when the yellow dot wears off. It wouldn't have been quite so bad if I didn't have one of each up front.
syndr0me is offline   Reply With Quote
Old 04-12-2011, 10:54 PM   #1217
TryHard's Avatar
tsk... do the quick spring check, always...
Take one spring of known rate, place it against another spring, and squeeze between fingers.
If they both compress to the same amount, same rate, if one compresses less than the other they are different!
Have to do this regularly as my HPI Pink's and Blues are black wire jobs with no markings!!
and how long have you been running it like that? spill the beans...
Old 04-12-2011, 10:57 PM   #1218
TryHard's Avatar
Originally Posted by Turillo View Post
Thanks for the reply Ed! I assume you're referring to the HB springs?
Yeah, HPI Springs, not the Hara's. I ony rarely use the blue's and gold, could probably get away with 2x silver, 1x blue, 1x pink. Does depend on track conditions though.
Originally Posted by mickrcarver View Post
how bout some parts numbers? these are a pain to find lol
Originally Posted by stitchy View Post
Speedtech has some of the HPI springs in stock. (gold, blue, silver)
Stichy's got you
Old 04-12-2011, 11:00 PM   #1219
Tron's Avatar
Trader Rating: 16 (100%+)
Invest in some paint pens and make some nice markings on the springs.
And yes, how long did you run bolloxed up front springs
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 04-13-2011, 12:20 AM   #1220
syndr0me's Avatar
I'm not sure to be honest. It's possible they've been that way since I built the kit. I pretty much always go with white/blue on carpet. The yellow dot on this particular one was almost invisible, and right at the end of the spring. So there's a chance it was like that since I built the car before snowbirds. It's actually been great at home the past few weeks, but dreadful everywhere else.
There's gonna be a lot of fast guys at our track this week for our end of season race. We'll be on LiveRC under CORRC if you want to watch failure happen live and direct from the rug in Denver.
Old 04-13-2011, 02:24 AM   #1221
kentech's Avatar
To be announced at Shizuoka:
Tungsten Balls for Thrust Bearing (8 pcs)
TRF417 Gear Diff Unit II
Gear Diff Cross Shaft
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 04-13-2011, 02:27 AM   #1222
syndr0me's Avatar
Sweet Jesus! If that gear diff leaks, though, I'm gonna kick a puppy.
Old 04-13-2011, 03:36 AM   #1223
Trader Rating: 54 (100%+)
Out of stock
Jamison R is offline   Reply With Quote
Old 04-13-2011, 04:08 AM   #1224
Hi.
It is easy to see the difference between the springs as they have different turns. Smooth springs have many turns and hard springs have lees turns. I have made a list with the HPI and Tamiya springs. I have alse added block settings and gearing. See attachment.
It is in Danish, but "Omdrejninger" means turns. Use it if you want.
BCDK is offline   Reply With Quote
Old 04-13-2011, 04:43 AM   #1225
RL.2002's Avatar
Originally Posted by Jamison R View Post
Out of stock
that hot.....
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 04-13-2011, 06:09 AM   #1226
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
No they're not, unless you don't know how to type "HPI spring colors" into Google.
At any rate, here you go (under the Pro4 section):
http://www.hpiracing.com/graphics/in...2-V9-Color.jpg
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 04-13-2011, 10:33 AM   #1227
Ray k's Avatar
Trader Rating: 46 (98%+)
In stock yesterday,out of stock today !!!! WOW!!!
Ray k is offline   Reply With Quote
Old 04-13-2011, 11:13 AM   #1228
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
LOL But what if it is the same Spec diff just with the updated parts?? Hope you don't have a dog
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 04-13-2011, 12:32 PM   #1229
There were some pics of Mark and co's car with a White gear diff so I assume they were testing it a TITC
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 04-13-2011, 05:33 PM   #1230
2-Bad's Avatar
Trader Rating: 24 (100%+)
Some other springs you may like to consider are the Xray springs... 2.6 and 2.8 rating.
I run on generally low to medium grip ashpalt and carry a full set of Hara's, the HPI Blue, Silver, & Purple springs. The Xray & HPI are linear where as the Hara's are not. They can feel a bit peculiar on some track but on others they are the Gold/Best!....
The G/diff's can leak! Try not to over tighten the screws as this will warp the housing and leak worse. I'm also trying Assoiciated Green Slim around the O-ring seals and housing gasket.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
