Old 04-06-2011, 03:10 PM   #1186
Originally Posted by Jamison R View Post
i used the CRC 10mm spacers
Cheers for the info.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 04-07-2011, 02:33 AM   #1187
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
N/A
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 04-07-2011, 04:16 PM   #1188
EDWARD2003's Avatar
Default Snowbird Setup
Has anyone tried Jilles Snowbirds setup?? Any thoughts on the longer camber links used in his setup?
Cheers.
Edward.
EDWARD2003 is offline   Reply With Quote
Old 04-08-2011, 01:13 AM   #1189
2-Bad's Avatar
Trader Rating: 24 (100%+)
Default Finally.....
After Pre-ording my 417 and recieving in late Dec '10 I have been enduring the wait till now while my 417 sat on the shelf at home while I worked overseas. After a long 3 months I have now built it and will be racing it this weekend (please don't rain, sob sob)....
Here are some pic's before I drive it in anger, hahaha
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-08-2011, 01:52 AM   #1190
Trader Rating: 54 (100%+)
^^^ are you gonna put the split mounts in the back? I didnt like how car felt with only front split suspension mounts.jmo
Jamison R is offline   Reply With Quote
Old 04-08-2011, 04:40 AM   #1191
Default 48 pitch
If anyone is looking to run a 48 pitch spur I have used an Xray spur and drilled two extra holes to fit the Tamyia spur holder and it fits like a charm. A must for racers racing on asphalt outdoors. If anybody has a 48pitch which fits without modification please let me know.
67fastbk is offline   Reply With Quote
Old 04-08-2011, 04:52 AM   #1192
Send a message via MSN to Bigger Brother
I'm running the older stly Xenon spur gears. They have the correct holes and spacing to fit the pulleys/spur holder. I just drilled a 6 or 6.5mm hole in the outer edge to allow for motor screw adjustment.
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 04-08-2011, 05:27 AM   #1193
Default Inner Camber Link Height
HI All
Just interested in understanding what changing the inner camber link height does, at that end of the car;
1. raising/lowering the front inner camber link - keeping all other bits equal
2. raising/lowering the rear camber link - keeping all other bits equal
I plan to fiddle with these settings next time I get a test day, ie change the front from 4-6mm over a couple of runs, and the rear from 3-5mm over a couple of runs and see if i can tie my findings back to what you think they should be (note i realise these changes are extreme, but i'm not good enough to feel the difference of a 0.5mm change but plan to at least have the learning there so i can make a minor change if needed at a big meeting)
Mark
Bony85 is offline   Reply With Quote
Old 04-08-2011, 06:02 AM   #1194
crabboy's Avatar
Trader Rating: 58 (98%+)
The Tamiya 64 pitch spurs are killa, we have been running nearly every weeekend on asphalt and have not gone through one yet.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 04-08-2011, 06:23 AM   #1195
Rhys
If you dont run a chassis protector, use a lil foil tape to cover the spur and pinion holes on bottom of chassis. This will also help keep gears from getting destroyed.
I agree Tamiya gears are very good!
Old 04-08-2011, 08:28 AM   #1196
2-Bad's Avatar
On the 416 I never noticed any difference... but I have them if I need them.
Old 04-08-2011, 01:12 PM   #1197
TryHard's Avatar
Originally Posted by Bony85 View Post
HI All
Mark
Raising or lowering the links will do two things;
1) change the amount camber change
2) change the roll centre
With the first, a more shims will make for a flatter link, which in turn will reduce the amount of camber change as the car rolls. Now, as your probably aware, it's a bit of a balancing act. You want camber change to maintain good amount of grip (i.e. keep the most amount of tyre in contact with the road as possible) as the car rolls, but too much, and the car will become snappy. This is because if the camber becomes too much, the tyre's will rapidly loose grip.
In effect, more camber change (less shims) should give you more grip, but a snappier car to drive, whilst less camber change (more shims) will give less overall grip, but a more progressive and consistent car.
However... this is balanced against lowering the rollcentre (more shims), which will naturally make that end of the car want to roll less, so less grip. Interestingly though, out of the three main alterations that affect the roll centre (inner lower pivot, outer upper pivot, and inner upper pivot), the inner camber link as the least effect on the roll centre placement.
As such, I tend to use the inner shims (and link placement) more as an alteration of the camber change than roll centre. If I want to adjust the roll-centre, first will be shims under the suspension blocks, then the outer hub. Last of all would be the inner camber link.
Don't forget as well that the link position has a big effect as well, to both the Roll centre and camber change. If you have time, it's worth trying different amount of shims along with different link positons, and see what works best for you.
Personally, I like the longest link with the kit shims. Seem to find the kit link a bit too nervous for my tastes, and more shims roll too much. But it's worth trying to see what suits you vest.
HiH
Ed
Old 04-08-2011, 11:40 PM   #1198
EDWARD2003's Avatar
TryHard,
Have you ever tried the 417 indoors on carpet?? My q's is what C rating are you using on your batts>?
Old 04-09-2011, 03:19 AM   #1199
TryHard's Avatar
Originally Posted by EDWARD2003 View Post
TryHard,
Never run the 7 on the rug, in fact haven't driven properly on carpet for over a year! To be honest, I'd just start with my outdoor setup, run a little less droop and different springs, and tune from there.
C rating on my batts, well, I use 5600mah 50C's, seem more than pokey enough!
HiH
Ed
Old 04-09-2011, 02:40 PM   #1200
GMartinez's Avatar
Trader Rating: 85 (100%+)
Getting my 417 ready for next weekend new lids on the way for those that are looking for a really good painter send an email to deani111@verizon.net
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
