Like Tree1Likes
Old 04-05-2011, 02:17 AM   #1171
Trader Rating: 55 (100%+)
Originally Posted by M3dreamin2008 View Post
I ran blue front and yellow rear with 450wt oil all around. I normally run blues all around. Just ordered some HPI silver springs though. What tires were you running?
I was running muchmore 28's. Where did you find the silver springs??????????
Jamison R is offline   Reply With Quote
Old 04-05-2011, 04:02 AM   #1172
Originally Posted by entitymugenmtx View Post
Can someone help me with something? I was looking at the setup sheet, and there are these number 1 2 3 4 on the front and rear lower arms what do they do ?
Hi.
You can angle the suspension - either on the tower or on the wishbone. There are two holes on each side of the wishbone, but they are not equal. By twisting the wishbone you have 4 different holes to adjust the lower mount of the suspension. They are named 1 to 4. When you build the car, you have to take care of correct twisting the wishbones. Otherwise you have different angled suspensions.
BCDK is offline   Reply With Quote
Old 04-05-2011, 05:06 AM   #1173
TryHard's Avatar
Originally Posted by BCDK View Post
Hi.
Moving the shock position on the arm also changes the amount of leverage that is put on the shock.
Changing on the tower changes just the angle, changing on the arm alters both angle and amount of leverage.
Out on the arm in effect stiffens the suspension, as there is less of a lever for the arm to act on (lower shock position to outer arm pivot). Going in makes it softer (more of a lever).
With the angle, more upright makes the shock more linear, more angled makes it more progressive (stiffens up more as the suspension compresses).
HiH
Ed
Old 04-05-2011, 06:27 AM   #1174
Ray k's Avatar
Trader Rating: 46 (98%+)
I believe the HPI spring is 6543 (silver).
Tower shows mid April for stock, but HPI has been pushing back all of it's " in stock" dates . Stuffs coming from Japan and we all know how that is going right now!
Ray k is offline   Reply With Quote
Old 04-05-2011, 09:17 AM   #1175
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
THANKS FOR ALL THE HELP GUYS
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 04-05-2011, 01:57 PM   #1176
Quick question: When using the split-blocks (in the front), are they the same height as the stock blocks, or do i need to use different size shim to get the same result?
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 04-05-2011, 02:19 PM   #1177
Hi, just thought I could help here, using 0mm under the split blocks is the same as using 3mm under the flipped standard block.
Team Durango, ORCA, MuchMore, Sanwa, Protoform, Tonisport, MR33, Roche, Custom Blitz Bodyshells
Elliott Harper is offline   Reply With Quote
Old 04-05-2011, 02:37 PM   #1178
Thank you, Elliott
Niklas Hansen
Old 04-05-2011, 03:57 PM   #1179
GMartinez's Avatar
Trader Rating: 85 (100%+)
for those that are looking for some Spec R diffs,cvd's I got mine from this store http://www.superiorhobbies.com/istar...t=19&class=SPR
I ran the Spec R diff min the front with 300,000 ball diff in the rear for outdoor really liked the feel of it finished 3rd overall 1st time out with the car
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-05-2011, 06:24 PM   #1180
I ordered them from hooby Hangar. Not sure when they will be in. Were you running the kit set up?
M3dreamin2008 is offline   Reply With Quote
Old 04-06-2011, 01:34 AM   #1181
I was wondering if there is a recommended length for the front and rear sway bar links that connect from the lower arm to the sway bar.
thanks
Old 04-06-2011, 06:23 AM   #1182
Send a message via MSN to Bigger Brother
Thanks for clearing that up for everyone Elliott.
Congrats on the new deal
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 04-06-2011, 12:16 PM   #1183
I've noticed that my spec-r gear diff can move up to 2mm side to side in the bulkheads which makes the belt rub the servo holder and ariel. Does everyone else get this? What type of shims should I use to sort it? Or should I just use a massive washer?
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 04-06-2011, 01:08 PM   #1184
i used the CRC 10mm spacers
Old 04-06-2011, 02:43 PM   #1185
I just got done building my Tamiya TRF417, and I took it for a couple of laps (to see if it was working). This thing has amazing steering! I had an Xray T2 '009, but it had nowhere near as much steering.
Going to race it this weekend - really looking forward to it!
Niklas Hansen
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
