Old 04-01-2011, 02:35 PM   #1141
Tron's Avatar
Trader Rating: 16 (100%+)
Since I like to use the search function, I did find this regarding the Hara springs:
Originally Posted by linger View Post
After sitting on my desk for a year - I finally got around to measuring the Hara Springs. I measured two springs and took an average.
I'm impressed - these spring actually measure very close to the rating on the package - that's rare in the RC world.
The graphs show that the springs are completely linear (with best fit R squared value between 0.9988 and 1.0000 for you technical types).
The measurement was done with a Chatillon 10 lb load cell and a test stand with accuracy within .001".
Hara Springs
66961 Yellow
published = 12.88, measured = 12.97
66962 Silver
published = 14.00, measured = 14.37
66963 Black
published = 15.12, measured = 15.44
66964 Purple
published = 16.24, measured = 16.41
66965 Pink
published = 17.36, measured = 17.57
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 04-01-2011, 07:50 PM   #1142
cuboi's Avatar
Hi,
anybody know part number for HPI blue and silver spring?
Thank you
cuboi is offline   Reply With Quote
Old 04-01-2011, 08:37 PM   #1143
Trader Rating: 31 (100%+)
Originally Posted by cuboi View Post
Hi,
Thank you
6542 and 6543. Good luck finding them though. They've been out of stock everywhere for like 2 months!
ittjv is offline   Reply With Quote
Old 04-01-2011, 10:11 PM   #1144
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by ittjv View Post
6542 and 6543. Good luck finding them though. They've been out of stock everyone for like 2 months!
I'm running into that very problem
Old 04-02-2011, 01:49 AM   #1145
chrisk's Avatar
Trader Rating: 32 (100%+)
I just got some blues in australia where i live and couldnt find silvers but was able to pick up the full set of HPI so i have plenty now
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 04-02-2011, 02:23 AM   #1146
piper48
Guest
Posts: n/a
Anyone know where I can find info on converting 64 pitch gearing to 48 pitch? Thanks in advance.
Old 04-02-2011, 08:15 AM   #1147
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
lem isn't the spur gear is all need to change over?
OVA is offline   Reply With Quote
Old 04-02-2011, 08:38 AM   #1148
piper48
Guest
Posts: n/a
The Spur and pinion. Trying to gear a car for 21.5 requires small spur and a really large pinion. I'm trying the 48 pitch to see if I can make it work with the gears I already have.
Old 04-02-2011, 09:54 AM   #1149
TryHard's Avatar
not sure quite how to read it, but i hope it's firstly obvious that to use 48dp spurs, you need to use 48dp pinions...
But as a quick reference, it's pretty easy to convert 64dp to 48dp.
(teeth of 48dp spur / 1.5)*2 = Teeth in 64dp
HiH
Ed
Old 04-02-2011, 10:34 AM   #1150
piper48
Guest
Posts: n/a
(teeth of 64dp spur / 1.5)*2 = Teeth in 48dp
HiH
Ed
Yes this would help. Just to clarify. Target FDR is 3.3. Gears req in 64p 100spur and 63pinion with a 2.13 I.R. So 100/63*2.13=3.38 in 64pitch So using the formula...I would need a 133spur and 84pinion in 48pitch....correct?
Old 04-02-2011, 11:15 AM   #1151
The formula TryHard provided is the wrong way around. It is from 48p to 64p. So you will need to revert it.
(64p teeth / 2)*1.5
Or just:
(64p teeth / 64)*48
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 04-02-2011, 05:51 PM   #1152
piper48
Guest
Posts: n/a
HiH
Ed
(64p teeth / 2)*1.5
Or just:
(64p teeth / 64)*48
Okay, Well.....guess I'll take both inputs and get a third opinion. Thank you both for your help.
Old 04-02-2011, 06:09 PM   #1153
TryHard's Avatar
yup, my bad, got the formula wrong way round there! Nilks is correct, and i corrected my post.
Ed
Old 04-02-2011, 08:42 PM   #1154
Trader Rating: 23 (100%+)
I am in the process of trying to decide which TRF car to purchase, a 416x or 417. I come to you with this question. Knowing what you know now, which car would you purchase, a slightly used TRF416x or a new TRF417? I have the opportunity to purchase a TRF416x with a bunch of spare parts for $140 less than a new TRF417 with a few spare parts. I have never raced on-road so I will have a learning curve with both cars. Would you go for the older car at a lesser price or a newer car with the newer technology?
AtownT is offline   Reply With Quote
Old 04-03-2011, 01:43 AM   #1155
cyclone speed's Avatar
Hello, just concerning setup between tracks, what are the main changes between going from carpet to asphalt ?
What should be the first thing changed or what does everyone tend to change?
I was looking at some setup sheets and I think that most people tend to run shocks more upright, thinner oil, higher roll centeron the inner pivot. And also the longer links .
Am I right ?
-TRF417 | Speedpassion GT2.0 LPF | LRP x12 13.5| 40 mhz FM Micro receiver |
T2M diamond servo | Mazda 6
Novak GTB, LRP TC Spec, Demon lipo's
And remember, dont forget to brake ;)
cyclone speed is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
