Old 03-24-2011, 02:15 AM   #1066
I)arkness's Avatar
Hey TryHard
with cutting the motor mount why is it that only cut the center out? why not cut it all the way to the edge making it clean (so it would look like the mount from the 416x).
id think by keeping the little extruded parts on the mounts, you would be actually limiting the total amount of flex that is possible. Thus you may not get a "true" representation of its handling effects.
Just my thoughts on the subject.
Brad.
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 03-24-2011, 03:02 AM   #1067
Jack2's Avatar
Originally Posted by I)arkness View Post
Hey TryHard
Brad.
The section you cut isnt actually mounted hard against the chassis Brad. its like 1mm or so off the deck. I can see what your saying but don't think it will make a difference.
I'm running split blocks in the back of the car for the first time this w.e, dont know if it will make much of difference..
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 03-24-2011, 03:06 AM   #1068
TryHard's Avatar
Hey TryHard
Brad.
I cut it in a hurry... and haven't bothered to go back to it yet (my dremel is a few thousand miles away! ).
As Jack2 says, the centre part of the mount is actually raised above the chassis, so the centre parts don't touch.
HiH
Ed
Old 03-24-2011, 08:37 AM   #1069
2-Bad's Avatar
Trader Rating: 24 (100%+)
and dremels aren't sold in China, wahahaha (sry, my smart-ass is creeping out )
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 03-25-2011, 07:16 AM   #1070
Swampracer's Avatar
Trader Rating: 67 (99%+)
Default Gearing
What size spur gears are people using for 17.5 boosted? and 13.5 boosted racing? Rubber tire and carpet racing. Medium to large sized tracks.
I know Tamiya sells the 111 & 113, should I be looking for different sized spurs, if so what brands are people using? (PRS, Xenon etc)
Thanks Greg G
Swampracer is offline   Reply With Quote
Old 03-25-2011, 07:38 AM   #1071
poochy's Avatar
Hey, might pickup a 417 real soon.
any problems that i may encounter when assembling it out of the box?
what upgrades should i order?
what spares should i order with the kit?
thanks!
poochy is offline   Reply With Quote
Old 03-25-2011, 08:56 AM   #1072
EDWARD2003's Avatar
Thanks Greg G
Xenon are the best, try to aim for spur sizes 98-105 teeth...
EDWARD2003 is offline   Reply With Quote
Old 03-25-2011, 10:15 AM   #1073
John.C's Avatar
Trader Rating: 36 (100%+)
thanks!
Hi,
I recommend using longer screws then what the manual indicates when screwing down the suspension mounts. It helps to keep them from bending when you accidently hit a barrier. Also, when assembling the front/rear axles note that there are 2 different sized shafts.
BB15 (9805776) is 2X9.8mm -> shaft that connects the wheel axle and swing shaft; also used to connect the direct cup to the spool
BC13 (50594) is 2X10mm -> shaft that sets the wheel hubs to the axle
Lastly, ensure that the proper shims are used when building the steering linkage.
I posted this a couple of pages back. The upgrade/modification items help to strength the front end and the car in general.
The usual plastic items (ie. hub carrier, front/rear uprights, direct cup, arms, etc) and spare suspension blocks are a good start for spares. Tamiya has a great article on the supsension blocks (click here).
Maybe we can convice Min to start stocking some of these parts at the store.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 03-25-2011, 10:18 AM   #1074
Trader Rating: 45 (100%+)
thanks!
- Might have to sand the arms in the rear hub area to allow for freer movement
- Make sure when the instructions call to use an 0.5 or an 0.7 shim that you are using the correct shim.
- May have to shim the spur assembly more than instructed
- Gear Diff
- 44mm steel bones for front
- Possibly the 1X/1XA split blocks to gain more rear traction
- Titanium turnbuckles for steering and camber
- HPI springs for asphalt racing
- A-arms front and rear
- Front C hubs
- Steering spindles/Rear hubs
- Belts
Apex is offline   Reply With Quote
Old 03-25-2011, 10:26 AM   #1075
poochy's Avatar
- Gear Diff
- Front C hubs
- Belts
Thanks Apex!!!!
Old 03-25-2011, 10:36 AM   #1076
syndr0me's Avatar
Trader Rating: 32 (100%+)
If you plan to run the spool, get the 46mm steel bones for the front. Order some spare spool inserts, too.
syndr0me is offline   Reply With Quote
Old 03-25-2011, 10:42 AM   #1077
Thanks Apex!!!!
No problem. One more thing, when cutting\slicing tops of the ball cups for the sway bar use a fresh x-acto blade. It will leave a real clean cut.
Old 03-25-2011, 10:48 AM   #1078
Trader Rating: 35 (100%+)
thanks!
Problems:
- differentiating between the various size spacers/washers
Upgrades:
- I ordered the Tamiya Air Duct (Tamiya 3454480) because it provides a solid flat surface for mounting my ESC. Not a necessity, but it helps.
- I use ceramic diff balls for a smoother diff
General building tip:
- Step 4: part "K1" - I like to place a dab of liquid white out (or white paint) in the position indicator holes. Makes it much easier to tell where the pointer's located. See Below:
Geppetto is offline   Reply With Quote
Old 03-25-2011, 10:53 AM   #1079
John.C's Avatar
Originally Posted by Geppetto View Post
Problems:
Upgrades:
And it's BLUE so can't go wrong there. Are you also using ceramic balls for the thrust bearing?
Old 03-25-2011, 10:59 AM   #1080
I was going to, but Victor suggested that ceramic in the thrust wouldn't add much in terms of performance.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
