Like Tree1Likes
Old 03-18-2011, 07:05 AM   #1021
I fianlly received my 417 last night. I'm soo pumped to get it on the track and start testing.
Such a beauty.
Cheers!
Turillo is offline   Reply With Quote
Old 03-18-2011, 08:22 AM   #1022
hana166's Avatar
Such a beauty.
Cheers!
I agree, only finished mine a couple of days ago really pleased
hana166 is offline   Reply With Quote
Old 03-18-2011, 09:20 AM   #1023
Send a message via MSN to WinDarK83
Hi, That effect is achieved by varying the position of the battery? The rearward position is the original 416, but if you put the brackets must be put in the position advanced.
Thanks and regards
Andrés Glez.
www.agonl83.blogspot.com
WinDarK83 is offline   Reply With Quote
Old 03-18-2011, 11:25 AM   #1024
jonest's Avatar
Originally Posted by KRYS06 View Post
hi everybody, i'm from france, i try to find a good setup to my 417 because in france there a not many !
i drive on asphalt with low grip and fast speed.
someone has cut motor mount and try on asphalt ? ?
thank you for your help...
I've cut the mount and I'll be trying it out tomorrow afternoon. Hope it works.
Alternatively, you may try soft shock oil and spring and more flex...
cheerios.
jonest is offline   Reply With Quote
Old 03-19-2011, 11:57 AM   #1025
SammyZ's Avatar
Trader Rating: 138 (100%+)
i have NIP roche steel spool cups for this car, direct fit,
must have hop up part.
$26 shipped for 2 pairs!
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 03-19-2011, 08:47 PM   #1026
Wondering if someone on this thread runs
Spectrum dx3r pro
Hitec servo 7965mg
Kit servo saver
I'm having an issue where either the horn realigns itself or the servo (which is brand new) does, while driving. And not necessarily with me hitting anything or anyone. It happens within the first couple of laps and pretty much ruins the rest of the race.
I have been told to switch servo savers as the kit one is a bit unstable but I am pretty sure this is no different to the 416we and this has never happened to me before. However I am using different electrics.
So hoping can guide me down the right path before I go spend a bunch of needless cash.
emerge is offline   Reply With Quote
Old 03-19-2011, 08:58 PM   #1027
Tron's Avatar
Trader Rating: 16 (100%+)
Spectrum dx3r pro
Hitec servo 7965mg
Kit servo saver
Definitely try a new servo saver, and make sure you have the proper adapter for your servo splines in the saver.
You can try the Kimbrough one, lots of great feedback on it being an upgrade.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 03-19-2011, 09:01 PM   #1028
Sweet, I love it when I get a quick and precise answer.
Old 03-20-2011, 03:59 AM   #1029
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can someone tell me if the arms, hubs, cvds, etc, are the same for 417 compared to the 416we?
LOSI123 is offline   Reply With Quote
Old 03-20-2011, 04:27 AM   #1030
2-Bad's Avatar
Trader Rating: 24 (100%+)
arms, hubs, cvd (excluding axles), are the same...
See New parts below:
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 03-20-2011, 04:43 PM   #1031
LOSI123's Avatar
Thanks Peter
Old 03-21-2011, 05:05 AM   #1032
Trader Rating: 55 (100%+)
any more test results with the split mount?????
Jamison R is offline   Reply With Quote
Old 03-21-2011, 09:47 AM   #1033
KRYS06's Avatar
cheerios.
Hi, thanks for your response, i drive with tamiya blue spring in front with oil 450 and yellow spring and oil 350 on rear.
My car have no more grip with sorex tires !
Do you have test with motor mount cut ?
KRYS06 is offline   Reply With Quote
Old 03-21-2011, 10:23 AM   #1034
FERNANDO.G's Avatar
KRYS06...Yes it's a waist of time.....DONT CUT YOUR MOTOR MOUNT.!
ARC USA.TITAN.BLITZ. VIPER USA.HORIZON-HOBBY.JACO. AIRTRONICS. TEAM TRINITY.
TEAM DYNAMITE.
FERNANDO.G is offline   Reply With Quote
Old 03-21-2011, 11:35 AM   #1035
jonest's Avatar
Had a race last weekend but the track was kinda bumpy and I stripped two spur gears. It could be due to the loose motor screws or could be due to the cut mount. Anyway, the car don't really feel nice at this track after tihe motor mount is cut. Will try at another track and see how it felt.
I wouldn't recommend you to cut the mount unless u got spares mount lying around. Not sure if we could use the 416 mounts on the 7.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
