Old 03-14-2011, 12:31 PM   #991
geeunit1014's Avatar
Originally Posted by EDWARD2003 View Post
I'm having a heck of a time replacing the front spool drive cups, any special techniques used to 'pinch' the out-drives in order to slide the blue aluminum sleeve off?
Cheers
Edward
Easiest way if you are trying to save the outdrive is take a big flathead and push the whole bearing/cam assembly. If you dont care about the outdrive, cut off the flange as ed says.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-14-2011, 02:43 PM   #992
Does anyone know the maximum size 48dp spur gear that will fit the 417??
Mark
Bony85 is offline   Reply With Quote
Old 03-14-2011, 06:33 PM   #993
Trader Rating: 31 (100%+)
Originally Posted by FERNANDO.G View Post
EDWARD2003....I use the cap from my exacto knife and squeesze it over the front causing it to close and it will slide out.
Try find something round and a bit smaller and press it over.
Recently I posted some pics on the www.Tamiyausa.com
about the plastic outdrive cups. I dremmeled the slots so 3mm plastic blades would slide and now I have the blades against the outdrive instead of the pin eating the plastic away.I ran all day Sunday testing with 4.5 and all looks good however the Tamiya blades are fragile due to the plastic and cracked. I then switched to XRAY ones which needed a bit of trimming but held up all day no problem. I will be updating the pics tonight on TamiyaUSA..
I use a similar technique, only I use a spare 15x10 bearing. Works like a charm!!!
ittjv is offline   Reply With Quote
Old 03-14-2011, 08:15 PM   #994
Does the 417 work better with shorter upper camber links? The kit set up has the short links. I'm aware of the effects of both long and short. I just was curious if the car design works better with short links. I'm running mod on med to low traction asphalt.
M3dreamin2008 is offline   Reply With Quote
Old 03-15-2011, 01:59 AM   #995
Hey,
could anyone tell me what the Rebound Stroke in the setting sheet means? My friends and I have been arguing on this. And I think Rebound Stroke = Droop.
Thanks in advance.
campaign000 is offline   Reply With Quote
Old 03-15-2011, 02:14 AM   #996
Trader Rating: 69 (100%+)
Originally Posted by campaign000 View Post
Hey,
Thanks in advance.
Shock bound means compression while rebound means extension. So reboud stroke means how much length in mm the shock shaft extends when fully compressed.
Assemble the shock to 61.5mm full length measuring from top of the shock ball end to the bottom end of the 5mm ball end connector. You can then measure rebound stroke by fully compress the shaft (stops by the lower ball end connector) and quickly release it. If the lower ball end connector stays fully compressed, you have 0 rebound. If it extends, the distance between the shock body and the lower ball end connector is the rebound stroke.
Most of the TRF guys runs little to no rebound. With the sponge piece in the shock cap, there will be some rebound. So to achieve little to no rebound, use no sponge and drill a small vent hole on the top ball end connector to relief air in the shock cap.
Droop is not rebound stroke. It is how much length you lift the end of the car before the tires of that end start to lift off the ground. This is affected by the downtravel of the suspension arms by adjusting the droop screws in the arms. To measure downtravel, you need a droop/downtravel gauge and measure from the bottom of the chassis to the lower end of the arms. A higher number means less droop as the arms will not lower more droop.
Check: http://www.competitionx.com/rc-tunin...-tuning-droop/
eComet is offline   Reply With Quote
Old 03-15-2011, 02:26 AM   #997
Great appreciation ecomet! And could you explain how the rebound stroke affects the controlling?
Thanks.
Old 03-15-2011, 02:47 AM   #998
Thanks.
If you read through this thread, you'll find some information regarding rebound stroke.
Most people run little to zero because it's more consistent. On high traction surface like carpet, some run with rebound stroke by adding the sponge in the shock cap. Incidentally, rebound will add some stiffness to the spring.
Still, 80% runs without rebound because it is more consistent, that makes shock do only what it should be doing, to damp the movement.
Old 03-15-2011, 05:24 AM   #999
Thank you eComet for the great help!
Old 03-15-2011, 05:25 AM   #1000
TryHard's Avatar
Actually, the kit positions on the 7 are very close to the inner most holes on the 6, because the bulkheads are closer together.
Having said that, I'm prefering the longest link now, with kit shims... seems to me that I can just lean on the car more in the corner, without the rear snapping.
HiH
Ed
Old 03-15-2011, 09:23 AM   #1001
Tron's Avatar
Trader Rating: 16 (100%+)
HiH
Ed
Kit shims? Meaning kit recommendation roll center shims on bulkhead and hub?
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 03-15-2011, 11:59 AM   #1002
Hi Ed,
Your still running a cut motor mount right? I've been tempted to cut mine a few times... My car seems to be very solid on carpet so I've held off. Carpet Nationals is next week and im very tempted to test it cut this weekend... Also I've been running long links with 5 and 4mm inner ball stud washers. Car seems good but I haven't tried shorter or longer with less shims... I guess if I make the front end more aggressive I might need more rear grip!
Were do you see most of the guys running there diffs? Low or high?
Thanks,
Kody
Kody is offline   Reply With Quote
Old 03-15-2011, 01:37 PM   #1003
syndr0me's Avatar
Trader Rating: 32 (100%+)
Maybe experiment with taking screws out of the rear of the top deck before cutting the mount? It seemed to help with rear grip quite a bit in a challenging situation I encountered recently.
I've been neglecting my 417 to give 1/12 a try. At one point, I bumped the 417 off my table by accident and it fell into the trash can. I laughed. That was 2 weeks ago. It's still there.
syndr0me is offline   Reply With Quote
Old 03-15-2011, 04:05 PM   #1004
flyradio's Avatar
does 417 upper deck compatible with 416x?
Team TRF Malaysia
flyradio is offline   Reply With Quote
Old 03-15-2011, 04:29 PM   #1005
No, the bulkheads of 417 is narrower.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
