Old 02-23-2011, 08:47 AM   #796
John.C's Avatar
Trader Rating: 36 (100%+)
The following adjustments can be made to the 417 to improve duarability.
- Replace the stock Tamiya foam bumper for a Parma PSE XRAY T2 Ultimate Bumper [PAR8053].
- Dremel the wheel axles to be flush with the wheel nut.
- [Already mentioned] Replace the 1 piece aluminum suspension mount with the split type.
- Replace the aluminum turnbuckles with the titanium type (especially the steering turnbuckle - 42mm).
- Replace the aluminum hex ball connector on the steering bridge with 5mm aluminum ball nuts and steel grub screws.
- Replace all other aluminum hex ball connectors with either a steel type or the ball nuts w/ steel grub screws.
- [Thx Geppetto] Replace the stock 44mm with the 46mm steel swing shafts.
- [Thx KHoff7] Replace the Tamiya hub carriers and front uprights with Xray type.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 02-23-2011, 09:28 AM   #797
dameetz's Avatar
Originally Posted by Nilks View Post
ECS-driveshafts (double-jointed) are pretty comon on the Xray, but that is mainly because Xray normal driveshafts are "bad" / give alot of wheel-chatter, and because Xray made some very good ECS-driveshafts, that are durable.
Unfortunately they are too long for the Tamiya, as Xray only makes 50mm and 52mm driveshafts.
Arrowmax has DCJ/ECS made for 416/417. A friend of mine is using it, qualitywise is on par with Xray's ECS. Best of all it does not need and modification to the c-hub (enlarge it), its a perfect fit. No chatter at all.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-23-2011, 09:28 AM   #798
KHoff7's Avatar
Very nice list. People might not like this, but I have found it very easy to put xray c-hubs and knuckles on the 417, which are much stronger.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 02-23-2011, 09:36 AM   #799
Trader Rating: 35 (100%+)
Hadn't considered this one. I like it!
I didn't see it mentioned, but replacing the stock 44mm front alloy dog bones with Tamiya steel 46 mm units.
Geppetto is offline   Reply With Quote
Old 02-23-2011, 09:52 AM   #800
John.C's Avatar
Do you have a link for the Arrowmax DCJ/ECS? I've used the Spec-R C.V. Universal Swing Shaft in the past. I'd be interested in giving the Arrowmax version a try.
Updated the list.
Old 02-23-2011, 09:53 AM   #801
John.C's Avatar
Do you by chance have the Xray part numbers for these 2 items? These might be the missing pieces to make the 416/417 front end indestructable.
Old 02-23-2011, 11:28 AM   #802
RL.2002's Avatar
Updated the list.
here is the link for the arrowmax product http://www.freemaxmp.com/
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 02-23-2011, 11:54 AM   #803
KHoff7's Avatar
Knuckle 302253
c-hub 302363 and 302364
Also required are, 302291 steering bushings, and 307221 hinge-pin.
In order to fit the c-hubs on the car you must drill the 417 arm slightly bigger to match the larger xray arm pin. Also the xray c-hubs require some shaving to make them fit in the 417 arm. Once all of this is done you will have an awesome front end.
Karl Hoffmeister
Old 02-23-2011, 11:58 AM   #804
Hi all
I have here my Set Up for the 417 on Asphalt with Sugarwather mit Solaris Med Tires from the ETS Rnd3 in Austria.
The best Laptime was the fastest Laptime over the Weekend in the ProStock Class...
Best Regards
Sandro
Stanmarsh is offline   Reply With Quote
Old 02-24-2011, 05:49 AM   #805
Trader Rating: 54 (100%+)
What springs come with the kit? Are they the long or short springs? Also are the extra springs for carpet? And I assume other springs are for asphalt. Last question. Which colors go in front and back for both carpet and asphalt springs. Thanks in advance
Jamison R is offline   Reply With Quote
Old 02-24-2011, 08:44 AM   #806
cyclone speed's Avatar
With the kit, there is the white/yellow springs that come with it, and the bonus parts are the extra white/blue springs used for carpet racing.
White is always for front, and blue for rear when doing carpet racing.
when doing asphalt,its white for front and STILL blue for rear,but you can use yellow for rear as its softer then blue ;-)
-TRF417 | Speedpassion GT2.0 LPF | LRP x12 13.5| 40 mhz FM Micro receiver |
T2M diamond servo | Mazda 6
Novak GTB, LRP TC Spec, Demon lipo's
And remember, dont forget to brake ;)
cyclone speed is offline   Reply With Quote
Old 02-24-2011, 10:01 AM   #807
dameetz's Avatar
Updated the list.
The link is as per RL2002 posted. Those who want to get rid of the chattering you can try it. The best thing is its a perfect fit, no modification to the c-hub needed. From the pic it shows the design is identical to the HUDY ECS, however it has got a different design to the HUDY's, the package includes 2 thin bearings, you will need to replace the stock inner bearings with the included thin bearings, so the double joint mechanism is place more into the knuckle. Very clever design. The material use is on par with HUDY and miles better than the Spec R
Old 02-24-2011, 10:29 AM   #808
syndr0me's Avatar
Trader Rating: 32 (100%+)
Heading out to the superstock nationals. Lets see if the 417 will stay on all 4 wheels this time. I've decided to roll with the short arm setup that's worked everywhere but 'Birds.
syndr0me is offline   Reply With Quote
Old 02-24-2011, 11:28 AM   #809
John.C's Avatar
Where can I purchase them? Although the site provides the description of the item, it does not offer it up for sale.
Old 02-24-2011, 03:00 PM   #810
dameetz's Avatar
I bought directly from their site. Email them, their customer service is very good.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
