Old 02-20-2011, 08:32 AM   #781
Originally Posted by syndr0me View Post
Oh yeah, same here. 44mm steel for front gear diff. 46 for front spool.
Kody, you running the extra long links like Jilles? Change his birds setup much? I guess I'll start with it in ABQ. I'll be surprised if I traction roll with Solaris.
Yeah my set up is very close. Played with ball stud height a little and oils. Car was on. edge if I juiced to long. Car is stuck with Sweep QTS32's and has great corner speed. Forward bite is insane!
Kody is offline   Reply With Quote
Old 02-20-2011, 06:00 PM   #782
TryHard's Avatar
Morning from thailand all...
So quick observations from meeting up with Jilles, Marc and co yesterday, and as I'm late for breakfast, quick summary..
No front gear diff - back to the spool, just seems to work better at the moment
Straight front arms - 1C/1C, more into, less out of the corners
Long links - full length
Shocks - pretty standard it seems, even going to lower oil to combat traction roll (yes, traction roll on asphalt, with 36 rated tyres... wtf !)
Will try post some more laters.. although also running a blog style thing here http://www.thard.co.uk/viewforum.php?f=64
Ed
Old 02-20-2011, 07:39 PM   #783
Ed
Dont forget to go introduce yourself to the Ozzie boys. Guaranteed for a good laugh. As well as a couple of Tammy guys too.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-20-2011, 10:21 PM   #784
jonest's Avatar
Ed
Ed,
hears that the MM tires aren't lasting. Are we allowed to purchase additional sets for the qualifying runs?
Thanks.
jonest is offline   Reply With Quote
Old 02-21-2011, 12:47 AM   #785
Has anyone used the center one way? Is it worth getting?
cvccsi is offline   Reply With Quote
Old 02-21-2011, 09:47 AM   #786
TryHard's Avatar
Originally Posted by jonest View Post
Ed,
Thanks.
It's not that they are not lasting (12 runs + seems to be easily achievable), just they change so much during a run. Super edgey to start with, then lapse into understeer after a few mins. Not much that can be done but try and get the car as well set for the end of the run, then hold on tight at the start!
Old 02-21-2011, 10:26 AM   #787
TryHard's Avatar
Have done so already, they've been kind enough to let me stash my gear in their room, which is handy. Will certainly be hooking up for a beer at some point, but tonight circumstance precluded that (bloody barriers!).
Old 02-21-2011, 11:15 AM   #788
jonest's Avatar
That could be tricky....
Old 02-22-2011, 01:11 PM   #789
John.C's Avatar
Trader Rating: 36 (100%+)
Originally Posted by cyclone speed View Post
Hello, i just noticed i bent a suspension shaft ( the 46mm titanium coated shaft that goes through the wishbone ) ... is it possible to use the one from my HB cyclone ?
The HB's Cyclone TC uses 45mm suspension shafts vs. Tamiya's 46mm. Having said I'm sure you could get away with it till you get the Tamiya replacement part.
Unfortunately, Tamiya USA along with US and HK based online stores are all out of stock. You can also use the Evo IV suspension shafts (TAM54093), same dimensions minus the Ti coating.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 02-22-2011, 04:02 PM   #790
cyclone speed's Avatar
, thanks, i just got those from rc market without the titanium coating, but does the Ti coating makes a noticeable difference, it's not as if the whole shaft was made of titanium O.O, otherwise it wouldnt bend lol ...
Also, I was playing with my car on my setup board, and when i accelerate and then steer, i get a " chatering " noise, where does that come from ? I heard it's also on other chassis, but whats the problem ?
-TRF417 | Speedpassion GT2.0 LPF | LRP x12 13.5| 40 mhz FM Micro receiver |
T2M diamond servo | Mazda 6
Novak GTB, LRP TC Spec, Demon lipo's
And remember, dont forget to brake ;)
cyclone speed is offline   Reply With Quote
Old 02-22-2011, 07:13 PM   #791
geeunit1014's Avatar
It is the cvd's binding a little bit. This is why some others use double jointed shafts, but a lot of the double jointed shafts have durability issues. I wouldnt worry about it too much, it doesnt seem to bother the team drivers Otherwise you would see them change to a dcj if they thought it was a big issue
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-22-2011, 11:23 PM   #792
ECS-driveshafts (double-jointed) are pretty comon on the Xray, but that is mainly because Xray normal driveshafts are "bad" / give alot of wheel-chatter, and because Xray made some very good ECS-driveshafts, that are durable.
Unfortunately they are too long for the Tamiya, as Xray only makes 50mm and 52mm driveshafts.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-22-2011, 11:33 PM   #793
I have some questions.
I race an Xray at the moment, so I am used to driving an immortal tank. I am thinking about switching to Tamiya, but I know that it isn't as durable as the Xray.
So my question is: Is there any way to make it more durable, without losing performance? I've heard about the split-blocks. Do they help? Are they worth the money?
Niklas Hansen
Old 02-22-2011, 11:38 PM   #794
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Dont crash
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 02-22-2011, 11:41 PM   #795
the split blocks are much more durable than the single piece blocks and you get basically 2 different blocks for less than how much 2 blocks would normally cost you.
platypus_s13 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
