Like Tree1Likes
Old 02-16-2011, 04:19 AM   #736
chrisk's Avatar
Trader Rating: 32 (100%+)
Just looking at the pics from ets series, what spoked wheels are they running?
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 02-16-2011, 05:00 AM   #737
PizzaDude's Avatar
Solaris wheels with medium compound Solaris tires.
PizzaDude is offline   Reply With Quote
Old 02-16-2011, 07:45 AM   #738
Tron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Nilks View Post
I think it has more to do with the lack of Jilles Groskamp for Team TRF.
Why is Jilles not showing up with team TRF for these larger races?
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 02-16-2011, 07:51 AM   #739
Trader Rating: 35 (100%+)
I see Tamiya has returned to the old style thrust bearing (as opposed to the prebuilt). Are you guys building and racing with the thrust bearing included with the kit, or are you using the a pre-built unit.
If you're building the Tamiya thrust bearing per the instructions has anyone tried using ceramic balls rather than the steel balls? If so, what size ceramic balls are required?
Geppetto is offline   Reply With Quote
Old 02-16-2011, 08:03 AM   #740
Trader Rating: 55 (100%+)
I used the ceramic balls I had from TOP car and they work fine. Not sure what size they are. Although, I have recently switched to the spec-r gear diff and so far it is working quite well.
Jamison R is offline   Reply With Quote
Old 02-16-2011, 08:40 AM   #741
John.C's Avatar
Trader Rating: 36 (100%+)
I ran my 417 for the first time this past weekend. It appears that the front belt is touching/rubbing on the top deck (near the center pullies). I noticed a rubberish residue on the top deck. Wiped it off and it came back. The kit is built per the instructions and the belt tension is set properly. Any thoughts?
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 02-16-2011, 08:52 AM   #742
jonest's Avatar
I'm using ARENA 1/16 Ceramic Ball for the thrust. I got it from RC Market.
jonest is offline   Reply With Quote
Old 02-16-2011, 02:28 PM   #743
He has moved to Thailand.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-16-2011, 04:49 PM   #744
chrisk's Avatar
are they available to purchase anywere?
they look good on the cars
smaracing.org
Old 02-16-2011, 05:55 PM   #745
TryHard's Avatar
Pretty sure you can't use the old type thrust with the new diff screw, as the screw is larger in diameter.
I've done what an number of other people have mentioned here, just used some ceramic imperial balls I had lyaing around... nice and smooth. Almost a shame that I've pretty much gone gear diff exclusive!
| THard.co.uk | Xray | MuchMore |
Old 02-16-2011, 08:03 PM   #746
Geppetto,
Are you going to run the 417 this Sat?
M3dreamin2008 is offline   Reply With Quote
Old 02-16-2011, 10:56 PM   #747
CHICO1977's Avatar
It shouldnt be touching u can try n adjust the belt tensioner or maye ur topdeck is to fit on the bulk head.Hope this helps
CHICO1977 is offline   Reply With Quote
Old 02-16-2011, 11:00 PM   #748
Tron's Avatar
"Slow Sportsman"
Old 02-17-2011, 05:28 AM   #749
TryHard's Avatar
Ahem, and who pays for that...?
Old 02-17-2011, 05:45 AM   #750
Default spec-r
Just a question regarding spec-r gear diff...since you are using it, which universal dogbone did you use? 46mm, 44mm? which model please...
k4mp4q is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
