Like Tree1Likes
Old 02-13-2011, 09:01 AM   #706
Blueman Austria's Avatar
Hy there!
Anybody know how much teeth the 417 rear belt have?
THX in Advance,
Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 02-13-2011, 09:32 AM   #707
syndr0me's Avatar
Trader Rating: 32 (100%+)
Still can't beat Ronald, even without Umino there.
syndr0me is offline   Reply With Quote
Old 02-13-2011, 10:02 AM   #708
I think it has more to do with the lack of Jilles Groskamp for Team TRF.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-13-2011, 10:12 AM   #709
syndr0me's Avatar
I agree! I told Jilles as much at Snowbirds. In looking at the pictures, it doesn't look like they're trying the stuff Jilles came up with at 'Birds.
Old 02-13-2011, 10:34 AM   #710
hi there,
i ordered a trf417, just wondering does it come with a gear diff or a spool?
the ruppers is offline   Reply With Quote
Old 02-13-2011, 10:44 AM   #711
Trader Rating: 35 (100%+)
Originally Posted by the ruppers View Post
hi there,
I don't have one, but if it's like my 416x...
Spool - Yes
gear diff - No
Geppetto is offline   Reply With Quote
Old 02-13-2011, 10:44 AM   #712
Originally Posted by Blueman Austria View Post
Hy there!
THX in Advance,
Rainer
177
kdempsey is offline   Reply With Quote
Old 02-13-2011, 10:49 AM   #713
syndr0me's Avatar
The 417 (outside of Japan) comes with a spool up front and a new ball diff in the rear. The new ball diff has hubs that fill the entire pulley, presumably to keep out dirt, and uses D-rings that lock on to the hubs. It also comes with a new thrust (not caged, 201 style) t-nut and diff screw.
I believe the Japan version comes with a one-way up front rather than a spool. The Tamiya gear diff is just a Spec-R with a Tamiya header card (and price), so I'd get the Spec-R version for cheaper. It sounds like maybe Tamiya is working on their own.
Old 02-13-2011, 10:53 AM   #714
i hope the new tamiya one is stronger then the one Marc was running tody
unlucky marc , but a great result for Ronald and Andy moore
sidecarphil1 is offline   Reply With Quote
Old 02-13-2011, 11:19 AM   #715
+1 Jilles set up from the birds worked extremely well yesterday at our ROAR Regionals. Only thing that was changed on my car was I had 500K up front. If I had 300K I would have tried it as I needed a touch more steering! But in the end my car was more consistent then anything I raced other then a WGT car on carpet! This was in Mod. With my first two runs every on the car in the morning practice I was extremely pleased with the car. Quilified 2nd behind Travis "Peeler" Schreven and took first in the main.
Look forward to getting this thing on the track again very soon!
Kody is offline   Reply With Quote
Old 02-13-2011, 11:30 AM   #716
cyclone speed's Avatar
Hello,
Today I ran my TRF417 for the first time ( same as crabboy ), I must say that compared to my HB cyclone, it is MUCH nicer to drive and also easier to drive with a standar/comon setup.
Grip wise was very good, I had a tiny bit of traction rolling at the end of the last race but on the previous races, grip was very good.
My main problem was mid-corner steering... Initial steering was fine, exit was good but mid-corner steering was lacking. I had to slow down more to get the car around the curve. On-power mid corner steering was ok, but off power ( mainly during a hairpin ), mid-corner steering was missing.
-My question : how could I increase mid corner steering ?
-Side question : What is the difference between longer/shorter camber links ?
-Final question : Why are their more people using anti-dive in front these days ? What does it do ?
Thank you very much
Anyone please ?
cyclone speed is offline   Reply With Quote
Old 02-13-2011, 12:21 PM   #717
Originally Posted by cyclone speed View Post
Hello,
Thank you very much
Anyone please ?
Hi,
Anti-dive makes the car react faster of center. I prefer a little to make the car not feel lazy. Never tried 1mm but have used .5 almost all the time.
I've found that raking the car (Rear ride hight higher then front) can help mid out steering. Ackerman plays a large part in your steering as well. Trying shimming your inner steering link balls on the steering in and out to see what you like. Body and wing position make a difference as well. On a Speed 6 a wing more forward gives you more high speed steering.
Shorter camber links give you more camber gain and longer camber lings give you less camber gain.
Hope thats right!
Old 02-13-2011, 12:38 PM   #718
Send a message via MSN to WinDarK83
According to the manual setup of Hudy, Anti-dive is to lift the front of the lower arm (ex:1mm on FrontFront c block and 0.5mm on FrontRear c block), it is seen as positive Anti-dive, and this is what increases steering response.
Is not that right?
Andrés Glez.
www.agonl83.blogspot.com
WinDarK83 is offline   Reply With Quote
Old 02-13-2011, 12:45 PM   #719
syndr0me's Avatar
I'm never sure what I'm feeling with anti-dive. I think mostly I feel the reduction in caster. I tend to go between running flat and .5.
Old 02-13-2011, 12:49 PM   #720
i found Anti dive great on my TRF416 but on the T3 i am now running it doesnt give me the same feelin , the car is really wierd
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
