Like Tree1Likes
Old 02-07-2011, 07:31 AM   #676
TryHard's Avatar
Originally Posted by cyclone speed View Post
Cheers for the reply, I will defenetly try that for sunday.
Another question, on the sterring crank, the dual thingy, when I tighten the 2 screws holding the rotating part, my steering will get stuck :-( so I have to unscrew them abit and its a litle lose, is this normal ?
Finally, is anyone using weights on the side of their lipo battery the balance ?
I remember on my cyclone, even with weights on the batt side, the car woupd stillean on t motor side, but on the 417, can I remover the weights ?
Thanks alot :-)
There shouldn't be any need to have screws loose in the steering. Check the instructions again carefully, and make sure you've got the right type and number of shims in the assembly. If it's tight when you screw down, you've not got enough shims in there!
As for the weight, pretty much is dependent on the electronics and so on used. I know with mine I need to add a little on the front right to balance it up.
HiH
Ed
Old 02-07-2011, 07:59 AM   #677
slakr's Avatar
Trader Rating: 28 (100%+)
I had the same problem with the steering on my 417
In step #8 of the manual I just doubled up on the shims. I put the shims in as directed, but also put the same set of shims (BB13 & BB10) on the screw (BA1) before I passed it through the bearings in the block (BB20).
Works free and smooth... although I could not figure out why I needed to do this.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 02-07-2011, 09:00 AM   #678
For 17.5T, would Spool/gear diff works better or Gear diff front and back?
seasons29 is offline   Reply With Quote
Old 02-07-2011, 09:22 AM   #679
John.C's Avatar
Trader Rating: 36 (100%+)
Originally Posted by TryHard View Post
Do the following;
Build as kit, except
put the white (F) and blue (R) springs on the car.
Droop to 6/5 on a gauge (I think is about 2mm/3mm over ride height, dependent on tyre dia).
Fill the shocks with 450-500wt oil, remove the red foam from the top of the shock cap.
Put on the track and drive...
Seriously, that'll be a very good starting point on carpet. It's hard to suggest absolute settings, but that should give a good starting point for sure.
HiH
Ed
Hi Ed,
I'm interested in learning more about the cause and effect of removing the red foam from the shock cap. I've always ran it on my previous Tamiya TCs and was wondering what change I'll see in the overall car and/or shock handling characteristics.
Thanks.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 02-07-2011, 10:08 AM   #680
RL.2002's Avatar
Originally Posted by double_green View Post
Hi Ed,
Thanks.
+1
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 02-09-2011, 01:02 PM   #681
EDWARD2003's Avatar
Default Spur Gear Issues
Just bought a bunch of Yeah Racing 64 pitch spur gears for my 417 and the noise coming from the gear is horrid. I've set the mesh properly, checked the pinion and spur wasn't rubbing the top deck all is fine.. Yet it still continues this noise.. Any one encounter such issues? Also I tried putting graphite grease on the gears to reduce the noise.
Cheers,
Edward
EDWARD2003 is offline   Reply With Quote
Old 02-09-2011, 03:10 PM   #682
dameetz's Avatar
Cheers,
Edward
I bought once before, use it for 2 packs only,you are right the noice was horrible and nothing that I can do to silence it. I think thats what you get from buying a cheapo brand. I never bought it again since.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-09-2011, 04:22 PM   #683
EDWARD2003's Avatar
On that note.. Does anyone have any spur gear suggestions?
Old 02-09-2011, 05:34 PM   #684
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
New Xenon spurs
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 02-09-2011, 10:48 PM   #685
Taman's Avatar
Trader Rating: 64 (100%+)
Originally Posted by Yokomo_Ant3 View Post
New Xenon spurs
are they 48 pitch and where do you buy them? I'm in Aus aswell
cheers
Taman is offline   Reply With Quote
Old 02-09-2011, 10:55 PM   #686
EDWARD2003's Avatar
Default 64 over 48 pitch.
48 pitch man.... come on its 2011 get with the times...lol.. Get the 64 pitch my friend so much better. You can really refine your gear ratios using 64 pitch..
I got mine from RC Model..
Cheers.
Aussi Aussi oye oye oye.
Old 02-09-2011, 11:06 PM   #687
cheers
only 64p. Most online shops have them, either HK or US.
Antoni Caretti
Old 02-09-2011, 11:08 PM   #688
Taman's Avatar
Cheers.
lol thanks the buys at the local track run 48 as the small stones etc apparently destroy the 64p too quickly
Old 02-10-2011, 12:01 AM   #689
TryHard's Avatar
Hi Ed,
Thanks.
Basically, removing the foam removes a lot of the pack from the shocks, and makes the car much smoother to drive. Coupled with drilling a hole in the top of the shock cap (to let out the compressed air), and you can dramitically change the feeling of the car, and also better set the rebound level.
Personally, I never run the foam any more, and switch between sealed and drilled top caps, depending on the affect and feel I'm after.
Give it a try, you might be suprised at the results.
Regards
Ed
Old 02-10-2011, 12:05 AM   #690
jonest's Avatar
Regards
Ed
Ed,
This method works best on high grip track. Back home where the grip is low, I don't quite like the feel. A lil inconsistent
jonest is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
