Like Tree1Likes
Old 01-31-2011, 03:49 AM   #661
Originally Posted by hana166 View Post
Anyone know if the Spec R 37T gear diff fits the 417? I heard the bulkheads are closer together on the 417 compared to 416.
Yeah fits perfect..
kdempsey is offline   Reply With Quote
Old 01-31-2011, 06:04 AM   #662
Originally Posted by GeorgePravata View Post
what the best body to run on the TRF 417 out doors.
The two best ones are:
PF Mazda Speed 6 or PF LTC-R for abit more steering
Smartypants is offline   Reply With Quote
Old 01-31-2011, 06:56 AM   #663
GeorgePravata's Avatar
Trader Rating: 106 (100%+)
Thank you
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 01-31-2011, 07:45 AM   #664
hana166's Avatar
Originally Posted by kdempsey View Post
Yeah fits perfect..
Cheers thanks its good to know that not a lot of new parts will be needed if you already have a 416X
hana166 is offline   Reply With Quote
Old 01-31-2011, 10:08 PM   #665
Jack2's Avatar
Has anyone tested much with the Gear Diff? back to back with the ball? Got my car fairly well set up on my local track (tight technical low, to med grip asphalt, outdoor). I've ordered a Spec R diff, along with some 1000w oil, apart from the lower maintenance, which I'm not overly worried about, any advantages? running Mod/Open. Will have it before my next race meet, but I'm not able to test before hand, just wondering if its worth the punt to just put it in.
Cheers
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 01-31-2011, 11:36 PM   #666
TryHard's Avatar
Cheers
Just run it I prefer the feel with the gear diff now, much better response on throttle, certainly with open mod. 1000wt seems about right. I do want to try thicker oil in my next test session though.
For lower powered classes, I'd look at thicker oil though, help to get teh car to rotate on power better.
HiH
Ed
Old 01-31-2011, 11:48 PM   #667
Jack2's Avatar
HiH
Ed
Okay cool. I'll give it a shot. Atleast swapping the rear out is no biggie, 5 minute job in the mighty 417! so if i dont like it, easy to swap out between heats
Cheers
Schumacher Mi4CX
Mugen MTX & MRX
Old 02-04-2011, 12:36 PM   #668
getpip's Avatar
Cheers
I had a drive of a 417 with a gear diff fitted in the front and thought it was great. (Rubber on asphalt)
Id say try it in the front (thick oil) and the back (thin oil) and see what you think.
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 02-04-2011, 04:29 PM   #669
stitchy's Avatar
Got some TRF417 Aluminum Diff Joint Sets in
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-04-2011, 05:23 PM   #670
syndr0me's Avatar
Trader Rating: 32 (100%+)
Dual gear diffs seems like the future.
My long arms should be here early next week. I'm looking forward to branching out in other directions with setup to see what I find.
syndr0me is offline   Reply With Quote
Old 02-04-2011, 11:48 PM   #671
Jack2's Avatar
Mmmm Might give it a try. I will say tho, they are very different, but I've run 2 diffs in my 1/10th tourer, back to back with a diff/spool, and the spool always seems to be a bit quicker, with a fair bit more on-power steering.
Schumacher Mi4CX
Mugen MTX & MRX
Old 02-06-2011, 12:17 PM   #672
cyclone speed's Avatar
Hello everyone
I bought a TRF417 yesterday ( wooo =D ) and finished it about 5 hours ago, installed the electrics and stuffs and its ready to go
As i previously had a Hotbodies cyclone, I dont have much experience on setting up the TRF ...
I was wondering if someone could post a setup sheet for a medium carpet track please ?
It would be much appreciated, and also, I will be racing it next sunday so until then, il try to gather as much as information as possible.
Thanks in advance
cyclone speed is offline   Reply With Quote
Old 02-06-2011, 07:21 PM   #673
TryHard's Avatar
Originally Posted by cyclone speed View Post
Hello everyone
Thanks in advance
Do the following;
Build as kit, except
put the white (F) and blue (R) springs on the car.
Droop to 6/5 on a gauge (I think is about 2mm/3mm over ride height, dependent on tyre dia).
Fill the shocks with 450-500wt oil, remove the red foam from the top of the shock cap.
Put on the track and drive...
Seriously, that'll be a very good starting point on carpet. It's hard to suggest absolute settings, but that should give a good starting point for sure.
HiH
Ed
Old 02-06-2011, 07:26 PM   #674
ngo8's Avatar
Send a message via ICQ to ngo8
Do the following;
HiH
Ed
That is the exact set up i am running on my car with gear diffs all around and the car is dialed very easy to drive, was very impressed especially with the front gear diff it was just amazing .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 02-07-2011, 12:18 AM   #675
Do the following;
HiH
Ed
Cheers for the reply, I will defenetly try that for sunday.
Another question, on the sterring crank, the dual thingy, when I tighten the 2 screws holding the rotating part, my steering will get stuck :-( so I have to unscrew them abit and its a litle lose, is this normal ?
Finally, is anyone using weights on the side of their lipo battery the balance ?
I remember on my cyclone, even with weights on the batt side, the car woupd stillean on t motor side, but on the 417, can I remover the weights ?
Thanks alot :-)
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
