Tamiya TRF417
#6511
What parts from 418/419 are suitable and recommended?
I have been running a 417x for over 3 years now, they are great cars and can be right up there with good setup. The good thing is you can drop a lot of 418 and 419 parts straight in to help improve performance slightly, a bad point is some parts are getting hard to get hold of now.
Also note the new 419x has gone back to a bulkhead width the same as the 417 probably because it works.
Another thing is the top-deck. Is very difficult to found spare top decks for 417. What can I do?
#6512
#6513
#6514
In general I had no problem to found parts. Only topdeck for me.
#6515
The 419 shocks are a bigger bore and have a different feel and stay the same over the run.
The 418 stabilizer kit is easier to adjust.
The 418 rear uprights give a shorter to link and increase the camber gain which helps a lot I have found.
I have found the V5 top desk works best.
Theres a few still around.
https://www.asiatees.com/display?Mis...id=74409&pid=1
#6519
TRF 417 V5 Chassis Std, Bezerk RC
They can even do modifications to the deck to your choosing, like different carbon fibre weaves, thickness, etc.
I have used Bezerk's top and bottom decks on my v5 and been really happy with them.
#6520
Bezerk RC is a great resource.
#6521
LF : TRF417x 17.5 Blinky setup
Looking for a 17.5 blinky setup for TRF417x running on an outdoor medium asphalt track.
Thanks! 😀
Thanks! 😀
#6522
Tamiya TRF417 Setup Sheets & Manual
This setup would be the closest to what I ran:
Tamiya TRF417X - Marc Rheinard - ETS Rd3 - Gran Canaria - 03-04.03.2012
#6523
Here are some setup sheets for the 417:
#6525
Upgrade to TRF418/418 suspension
