Old 01-24-2011, 08:29 PM   #631
Originally Posted by malkiy View Post
Works great in 17.5 no timing.
what size spur are you using? Motor?
M3dreamin2008 is offline   Reply With Quote
Old 01-24-2011, 10:36 PM   #632
95t speedtech spur geared at 3.83. Using a duo 3.
malkiy is offline   Reply With Quote
Old 01-25-2011, 07:40 PM   #633
Are you using the kit set up?
Old 01-25-2011, 09:27 PM   #634
Yes but running no spacers under the hinge pin blocks.
Old 01-27-2011, 10:11 AM   #635
Trader Rating: 26 (100%+)
Can someone lead me in the right direction on how to adjust the Stabilizer Bars. I am in the build process and have installed both. On the front, both sides rise evenly with very little delay. But, on the rear one side takes longer to rise than the other. I can't figure out why, I have tried both adjustment grub screws and I am not seeing any improvement. Is there a tutorial available that I can watch?
svines1972 is offline   Reply With Quote
Old 01-27-2011, 10:48 AM   #636
superspeed's Avatar
Are the rear shocks detached when you tested the sway bar? The shocks got to be equal length, tension, down & up travel. Also there is the droop setting/adjustment as well. Make sure the left and right side have same amount of droop.
superspeed is offline   Reply With Quote
Old 01-27-2011, 10:56 AM   #637
This is with no shocks. Droop is the same both sides.
Old 01-27-2011, 11:17 AM   #638
GeorgePravata's Avatar
Trader Rating: 106 (100%+)
what the best body to run on the TRF 417 out doors.
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 01-27-2011, 11:25 AM   #639
Trader Rating: 114 (100%+)
Take the sway bar off and set it on a flat board, make sure it sits flat and is not bent.
Chris Furman is offline   Reply With Quote
Old 01-27-2011, 11:55 AM   #640
Send a message via MSN to Bigger Brother
http://www.thard.co.uk/viewtopic.php?f=49&t=405
Read it through carefully, it is dead simple to do this way
HTH
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 01-27-2011, 05:19 PM   #641
TryHard's Avatar
Also have a look at posts #413, 416 and 417 ( hadn't spotted that) in this thread, back on page 28.
Might help to explain the technique a bit better.
Tamiya TRF417
Old 01-28-2011, 02:58 AM   #642
Mine is still in its box I am waiting for all of the diff parts to be released as a spool is useless to me... Hurry up Tamiya!!!
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is online now   Reply With Quote
Old 01-28-2011, 07:06 AM   #643
this??:
http://rcmarket.com.hk/product_info....8o88dqc3b2ee42
jorgesimes is offline   Reply With Quote
Old 01-28-2011, 07:14 AM   #644
jonest's Avatar
RC Market has them in stock already!
jonest is offline   Reply With Quote
Old 01-29-2011, 06:12 PM   #645
syndr0me's Avatar
Trader Rating: 32 (100%+)
I talked to Jilles for a while tonight (thanks again for the tires and the help all week). He put a gear diff in the front of his car with 500k and attributed the additional steering to his being able to TQ mod in the last round. He said he's running 1k in the rear gear diff.
As for me, my car has traction rolled off the track every run since the end of the first day. I've tried every suggestion imaginable. I'm basically giving up and putting the long arms on the car in hopes of finishing a race.
syndr0me is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
