Old 07-01-2014, 07:56 PM   #6406
... Moved to more relevant thread.
cplus is offline   Reply With Quote
Old 07-02-2014, 03:46 PM   #6407
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Default 417/ta05/tb03
Anybody have a part number for a 1.3mm front sway bar?
I have several, but I have no idea what they came from or how to get them again...
CraigMBA is offline   Reply With Quote
Old 07-02-2014, 05:02 PM   #6408
Can't you use the TA06 ones? 54309?
Old 07-25-2014, 08:05 AM   #6409
Marcika's Avatar
Hi,
What tamiya body shell would you suggest for race taking into below conditions :-)
- no subaru B4 allowed
- NSX body is not available in the market
Car:
417v5, 10T brushless set, tyre: tamiya A slick.
Marton
Marcika is offline   Reply With Quote
Old 07-27-2014, 08:16 AM   #6410
barts71m's Avatar
Trader Rating: 34 (100%+)
I believe they are in the TA06 sway bar kit.
barts71m is offline   Reply With Quote
Old 07-28-2014, 07:30 PM   #6411
Anybody have a setup they use for VTA? I am running a stock 417 chassis. I have looked at petitrc...and have tried various setups from there. I just didn't know if anybody had a VTA setup that they wanted to share? Running on med/high grip ozite. The track is the same size and layout as the Vegas IIC Race.
USVTA Southern Nationals @ Thunder RC, Nashville TN
Thank you
Chad
Totally DIALED is offline   Reply With Quote
Old 07-28-2014, 08:55 PM   #6412
Burlap's Avatar
Send a message via MSN to Burlap
I am looking at rebuilding my 417 v5 and while creating a list of parts I need to get for it I saw the 417 centre one way pulley set.
Since that pulley setup uses screws to hold the spur gear onto the pulley instead of the "key" method on the standard pulley which will allow for a greater range of spur gear, has anyone been able to lock up one of those one ways and use that instead?
Burlap is offline   Reply With Quote
Old 07-31-2014, 09:08 PM   #6413
I recently bought a used 417v5 from and it came with multiple sets of springs. They are all white but on the bottom they are marked with different colored dots on the bottom. In order of hardness by feel- yellow silver blue gold (gold is hardest) I looked at all the spring charts but these colors don't seem to match up. Does anyone know brand they might be, because I have recently been chasing a good setup and would like to know how these compare or should I just throw these in the bin and buy the HPI silvers as I am going to be racing on asphalt?
DR.FAST is offline   Reply With Quote
Old 08-01-2014, 12:08 AM   #6414
JimmyMac's Avatar
You have pics? Maybe some of them are Yokomo springs?
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 08-21-2014, 08:26 PM   #6415
Burlap's Avatar
Arise from the dead o' 417 thread (bit of a shock that Tamiya are already rolling out the 419, but whateves).
Just wondering if anyone here has some 417v5 lower decks that they want to sell?
Old 09-06-2014, 11:06 AM   #6416
417x with v5 upgrades for sale. Listed in sale and trade section.
VegasJim is offline   Reply With Quote
Old 09-08-2014, 04:06 AM   #6417
Default newbie question
Hi.
Which is better for 21.5 or 17.5 racing? A TRF 417 v5 or TRF 418?
Thanks.
bosschick is offline   Reply With Quote
Old 09-08-2014, 04:21 AM   #6418
Salkin's Avatar
Originally Posted by bosschick View Post
Hi.
Thanks.
I have started up in TC "the hard way" in modified. The guys racing stock (13.5T) are scratching their behinds, taking a drink, maybe eating a little, on the strait. I would for sure rule out the 21.5T, and maybe thinking that even the 17.5T is too slow. Maybe a 13.5T is a good starting point if you want some speed to develop your skills with.
417v5 or 418. I have both. Even for skilled drivers the 417v5 is good. If you are not a skilled driver, I would believe it doesn't matter much, the potential in both chassis are on a much higher level than you anyway.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 09-17-2014, 01:22 AM   #6419
Salkin's Avatar
Please delete, double post.
Old 09-17-2014, 01:23 AM   #6420
Salkin's Avatar
I try to set up my v5 for carpet, and look at setup sheets on petitrc.com, like this one:
http://www.petitrc.com/reglages/tami...ional20130210/
Most of the setup sheets specifies "Tamiya white" and "Tamiya blue".
I can find a set of springs with part number 53440, where the springs are different colours.
I can find another set of springs with part number 53333, where the springs are also in different colours.
And I can find a set of springs with part number 49382, where the springs are all white, but with a little colour marking in the end.
From which set are the "Tamiya white" and "Tamiya blue" from that the setup sheets uses?
The 417v5 manual says part number 53440 on the white/yellow springs in the kit, so maybe it is the white/blue springs from the 53440 set?
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
