Old 03-24-2014, 02:30 AM   #6376
Fredp1's Avatar
Here is the setup of the car as I received it.
Its a 417 with a smokem deck.
I haven't pulled the shocks appear yet, so any hints for a improved setup on a low grip track will be welcomed
https://onedrive.live.com/redir?resi...nt=file%2c.pdf
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 03-24-2014, 03:41 PM   #6377
Fredp1's Avatar
Thanks Phil,
I'll try some of Craig's suggestions and try to shorten the wheelbase.
Old 03-24-2014, 05:48 PM   #6378
veecee's Avatar
Trader Rating: 34 (100%+)
I would start with this setup - http://www.petitrc.com/reglages/tami..._RROC20130526/.
Then make these changes:
1) Front spool
2) Front blocks C-C
3) Soft rear swaybar
If you are on really low traction and lacking rear grip, remove the toe block shims from the rear blocks and reset your rear droop after that.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 03-24-2014, 07:07 PM   #6379
Hey guys Does anyone know the size of the pin that goes through
the dog bone (swing shaft) on the diff side?
thanks
Dynodn is offline   Reply With Quote
Old 03-25-2014, 03:58 AM   #6380
Fredp1's Avatar
1) Front spool
2) Front blocks C-C
Thank you. I'll try your suggestions.
Old 03-25-2014, 09:16 AM   #6381
thanks
2mm IIRC.
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 03-25-2014, 11:38 AM   #6382
Trader Rating: 51 (100%+)
Tamiya TRF 417x roller
hate to sell but got a bteam deal for offroad
Rick Hess
Sworkz USA-Amain Hobbies
R&C Hobby Shop Clarksville TN
-RCJuice-HobbyStar-RCP Customs-AKA-Protek RC
rkhess is offline   Reply With Quote
Old 03-25-2014, 12:02 PM   #6383
Originally Posted by c2tcardin View Post
2mm IIRC.
Thanks Jeff
Old 03-27-2014, 09:43 PM   #6384
Fredp1's Avatar
Default Bottom deck choice
If got to replace the bottom deck on a 417x.
If you had a choice between a 417x, 417v5 or a 417 smokem deck which would you choose and why?
I've also heard the 417x deck is stiffer than "some".
How do the 3 decks compare in stiffness and is it better to use a softer deck for a low grip concrete track, running 21.5.
Old 03-27-2014, 10:11 PM   #6385
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
I like the V7 conversion:
http://shop.smokem-racing.com/Smokem...sion_p_16.html
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 03-30-2014, 04:15 AM   #6386
Burlap's Avatar
Send a message via MSN to Burlap
If you go for the 417v5 deck you will need to buy a floating servo mount, either Tamiya or third party.
Burlap is offline   Reply With Quote
Old 03-30-2014, 06:23 AM   #6387
417x roller with spare upper and lower decks plus spares $250 shipped
Atechbh is offline   Reply With Quote
Old 03-30-2014, 06:24 AM   #6388
417x RTR
Sorry meant to put link
Old 04-06-2014, 02:49 PM   #6389
When going to different tracks hpw do you guys select your rear diff oil? What does lighter vs heavier oil do?
NickGroves is offline   Reply With Quote
Old 04-06-2014, 03:38 PM   #6390
Heavier oil will make the diff act more like a locked unit.
Lighter oil will give more off power steering (as the diff is more free to spin at unequal rates)
On the flip side, if you are struggling to put power down on corner exit, you need to go up.
Generally, the more power you've got the higher the viscosity of oil you'll need to run too.
The higher the track grip, the lighter you can run the rear oil without "diffing out" (inside/power wheel spinning)
Summary from Hudy!
Thinner
• Increases cornering traction
• Increases steering into corner
Thicker
• Decreases rear traction while cornering
• Reduces wheelspin
cplus is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
