Like Tree1Likes
Old 02-26-2014, 05:03 PM   #6361
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by Mitamiya View Post
Just received a first generation 417 in a trade. Does the gear diff II drop right in or are there other parts I need to purchase to swap out the ball diff? Car looks pretty much stock, any upgrades I need to buy to go asphalt racing on a low grip track?
Thanks in advance!
diff2 drops in with no problems...
aside from HPI silver springs and the large diameter spring cups car should be good to go.
i remember having to cut some sections of the top deck for more flex and traction (some when to the extent of cutting the motor mount as well).
a floating servo mount could give the car a more "updated" look to (Smokem makes one without the peg so you don't have to drill a hole in the chassis).
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 02-27-2014, 03:54 PM   #6362
Mitamiya's Avatar
Trader Rating: 14 (100%+)
Much appreciated, thanks!
MItamiya
Currently Racing
Offroad - Associated B5M Lite
Onroad - TRF 418 Samix VTA/TRF 419 USGT
Mitamiya is offline   Reply With Quote
Old 03-03-2014, 10:56 AM   #6363
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Exclamation Black gear case.....
Anybody out there know of a place or has one to sell, a black gear diff case??..... Maybe the complete kit??...... I know Tamiya sells the casing alone but I have not seen just the black casing alone..... LMK....
Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 03-03-2014, 01:58 PM   #6364
Potoczak's Avatar
Trader Rating: 111 (100%+)
Thanks!
Hey Alex, check out spec r, they have black gear diffs.
http://www.spec-r.com/default/index....42&language=en
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-19-2014, 04:56 AM   #6365
Fredp1's Avatar
Default Removal of Direct Coupling
Doing some routine maintenance on a 417 front direct pulley and was wondering if it's possible to remove the Direct coupling off the Direct cup without destroying the cup?
The manual on section 7 suggests to cut/remove the lip on the cup so the coupling can slide off.
Fred
Dean(14 years old)- Awesomatix A800X, Fantom FR-1 5.0 Motor, Fantom batteries, KO Propo
Dean(14 years old)- Roche P12-2017, Fantom FR-1 4.5 Motor, Fantom batteries, Team Powers Radon Pro 1s
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Fredp1 is offline   Reply With Quote
Old 03-19-2014, 04:08 PM   #6366
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Fred
It is possible, but quite awkward. I replaced the Tamiya cups with aftermarket ones which tend to last longer anyway. Roche, Arena, Reflex Racing and others have options.
Other than that, I've regarded the standard ones as consumables
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 03-20-2014, 02:57 AM   #6367
Mister-E's Avatar
Fred
Don't remove the lip fully.
Leave about 2-3 mm lip material on each half of the cup (opposite to each other).
To remove it, just compress the lips on both halves.
You should also try putty in your front gear diff.
It will react almost like a spool, but has more turn in and less wear!
Mister-E is offline   Reply With Quote
Old 03-20-2014, 10:09 PM   #6368
Fredp1's Avatar
Thanks for the info
Old 03-20-2014, 11:07 PM   #6369
You could also dye a white one on the stove with RITT (or similar) clothes dye like the OCD blokes/nerds on Tamiya Club do.
cplus is offline   Reply With Quote
Old 03-21-2014, 06:50 PM   #6370
Selling a really nice 417x if anybody is looking for one. RTR or roller
Pm me
Atechbh is offline   Reply With Quote
Old 03-21-2014, 06:50 PM   #6371
Pm me
Old 03-23-2014, 07:34 PM   #6372
Fredp1's Avatar
I've got a 417 with a smokem bottom deck running in 21.5 blinky novice.
Does anyone have or suggest a setup to use?
Old 03-23-2014, 07:46 PM   #6373
VooDooPH's Avatar
asphalt or carpet? grip level? share more info on the track you run at...
Old 03-23-2014, 10:43 PM   #6374
Fredp1's Avatar
Its a low grip track, some sort of painted surface on concrete slab.
The race is run in the evenings and its under cover.
I wasn't sure how the Smokem deck changes the behaviour of the car.
My two boys both run 417v5's in the same class and track if that helps.
Old 03-24-2014, 12:30 AM   #6375
PDR
PDR's Avatar
Amongst other things, check out Craig's setups here:
http://tchub.wordpress.com/category/setups/
Around Castle Hill, shortening the rear wheelbase helped my car get around the tighter corners pretty well.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
