Old 02-22-2014, 01:41 AM   #6346
narcotiks's Avatar
Originally Posted by Burlap View Post
I've been playing around with my two Futaba servos this weekend, and notice both (9550 & 9551) have tons of travel going left, but not the same going right. To fix this I have pulled back the steering travel to the left. I have tried both aluminium servo horns and servo savers.
Now I think I have read in this thread about people having similar issues with Futaba servos and the 417. Is there a better brand of servo that gives more even travel than the Futabas?
Have you adjusted the sub trim(centre position) on your radio? If you're using a futaba radio, the manual goes through a way to set up channel mixing that gives the servo more throw in the desired direction. I've got my bls551 getting equal throw left and right using this method.
narcotiks is offline   Reply With Quote
Old 02-22-2014, 02:57 AM   #6347
Burlap's Avatar
Send a message via MSN to Burlap
I've got a Spektrum DX3R Pro, and have had a look at sub trim, but not mixing. I'll see what is required to do that with that controller. Thanks for the tip!
Burlap is offline   Reply With Quote
Old 02-22-2014, 04:52 AM   #6348
narcotiks's Avatar
I setup my steering servo as follows
Mount servo in the car and make sure all radio settings (sub trim and trim are on 0).
Turn the car on, and mount the servo horn on the servo so it is angled in towards the centre of the car (see 417 manual).
Make sure steering links are the same length and then put the car on the setup station, adjusting the subtrim until the toe is equal left and right.
Now the steering is centred and and the car should track in a straight line with 0 steering trim.
Adjust the steering throw on the radio to get equal left and right throw on the setup station.
Most of the time the car will track straight if it isn't tweaked, if it isn't tracking straight in the warm up before a race, adjust the steering trim to make it track straight for the race, and check for tweak after the race.
Using a longer servo horn will also give you more left and right throw.
Hope this helps
Old 02-22-2014, 04:31 PM   #6349
JimmyMac's Avatar
Rather than adjusting subtrim to get center, you can also adjust the center link if you are close. This way the servo remains at true center and max physical travel is not affected left or right.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 02-23-2014, 01:44 AM   #6350
Burlap's Avatar
I've done a mix channel, as narcotiks suggested. I guess I should read the manual sometime! That's probably where I have got it wrong. Thank you for the extra information narcotiks, I will play around with that a bit more.
Old 02-23-2014, 06:13 PM   #6351
Trader Rating: 50 (100%+)
Loving my 417x on carpet ..... but in breaking c-hubs like crazy .... what's the fix ? More flexible ta05 c-hubs? Or aluminum
Rick Hess
Sworkz USA-Amain Hobbies
R&C Hobby Shop Clarksville TN
-RCJuice-HobbyStar-RCP Customs-AKA-Protek RC
rkhess is offline   Reply With Quote
Old 02-23-2014, 08:10 PM   #6352
Super Moderator
Grizzbob's Avatar
I've always preferred the softer plastic ones, they're not indestructable, but they can take more hits than the harder ones.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 02-24-2014, 04:28 AM   #6353
narcotiks's Avatar
Best fix would be to hit stuff less
The softer non carbon re enforced c hubs might take a few more hits but will still break in hard hits and could potentially make you traction roll from the increased traction (on carpet).
Old 02-24-2014, 07:20 AM   #6354
golgi's Avatar
Trader Rating: 14 (100%+)
I also had the issue of breaking c-hubs. Other than improving my driving...which will take some time...was to buy a full width front foam bumper to replace the stock one. It has to be full width so it is as wide as the outside of the front tires. Once I did this, breaking c-hubs has not happened in over a month.
golgi is offline   Reply With Quote
Old 02-24-2014, 01:58 PM   #6355
maxepower's Avatar
Talking new C-hubs
Tamiya is coming out with a new C-hub, it's appears to be thicker and wider to compensate for the DJ axles. Not sure when they will make it to the hobby stores, but is coming soon!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-24-2014, 01:59 PM   #6356
golgi's Avatar
Thanks, I didn't realize they had a new design in the works! Good to know
Old 02-24-2014, 04:21 PM   #6357
I barely even tapped the pipes !
Rick Hess
Old 02-25-2014, 08:04 AM   #6358
skyball's Avatar
...that's what they all say...
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 02-25-2014, 08:33 AM   #6359
Says in the description "carbon reinforced" so I doubt it will lead to fewer broken hubs but I agree it will make the changing/cleaning of the axles easier. The 418 has the same hubs and I've already broken one of those so I switched to the more flexible TA05 C hubs (51293).
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 02-26-2014, 01:39 PM   #6360
Mitamiya's Avatar
Just received a first generation 417 in a trade. Does the gear diff II drop right in or are there other parts I need to purchase to swap out the ball diff? Car looks pretty much stock, any upgrades I need to buy to go asphalt racing on a low grip track?
Thanks in advance!
MItamiya
Currently Racing
Offroad - Associated B5M Lite
Onroad - TRF 418 Samix VTA/TRF 419 USGT
Mitamiya is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
