Old 02-09-2014, 08:20 PM   #6331
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Originally Posted by JoeyE View Post
I have a used V5 chassis. The only thing is that I have to look for it(I know I have it). I would say the condition is 8/10. When do you need it by?
Thanks. March race at Harbor for sure... slim chance of making the Feb race in Omaha due to work travel schedule (but never say never ).
Jimmy.
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 02-14-2014, 07:18 AM   #6332
eevul's Avatar
Originally Posted by g12314 View Post
If anyone has a 417 V5 chassis they would like to part with, please PM me. While testing for the upcoming TCS races managed to blow out the rear toe block screw . I guess worst case, I get a 418 if a V5 chassis cannot be found .
Thanks,
Jimmy
I recently had the same problem with my V5 chassis. I couldn't find a stock replacement anywhere so I went with the Smokem Chassis. I received it in a couple of days and had great response/customer service from them.
http://www.smokem-racing.com/417FX_417MX.html
I got the 417FX version which is a straight bolt on. I have only ran it once since I switched over to this chassis plate but found that it had way more traction over the stock V5 chassis plate.
eevul is offline   Reply With Quote
Old 02-14-2014, 09:30 AM   #6333
Hi eevul,
I'm looking to get the Smokem chassis as well, did you use the FX outdoor or carpet?
seasons29 is offline   Reply With Quote
Old 02-15-2014, 01:00 PM   #6334
Is anyone using a 417 for vta racing ? I'm using my 417x and need some help with the gearing , what spur and pinion would you recommend ?
mikpiz is offline   Reply With Quote
Old 02-15-2014, 05:20 PM   #6335
What final drive ratio are you trying to get to?
Juan Aveytia is offline   Reply With Quote
Old 02-16-2014, 06:44 AM   #6336
Right now I'm running 96.spur and 55 pinion for a final drive of around 3.4 , my question would be should I use a bigger or smaller spur gear , I'm mostly looking for straight away speed , corner speed is good.
Old 02-16-2014, 06:59 AM   #6337
Remember this formula- spur divided by pinion x's internal drive ratio
96 spur divided by 51 tooth pinion = 1.88 X 1.94 internal =3.65 final drive ratio
Old 02-16-2014, 11:00 AM   #6338
What motor timing are you at?
EDIT: And do you have a good fan on the motor?
-Mike
Old 02-16-2014, 11:48 AM   #6339
Simmi's Avatar
-Mike
A good fan is Muchmore 40x40 on a MR33 Motor Heatsink or from Muchmore Head
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 02-16-2014, 04:50 PM   #6340
-Mike
Im running about 50 degrees of timing just past the last mark ( 45 ) and yes I have a WTF high volume fan , Heat is not an issue I was coming of the track below 120 all weekend with the above gearing
Old 02-16-2014, 05:35 PM   #6341
Burlap's Avatar
Send a message via MSN to Burlap
If it is a big flowing track, then you can get down to almost 3.0:1. For a tight twisty track I'd aim for 3.4:1.
Burlap is offline   Reply With Quote
Old 02-16-2014, 06:44 PM   #6342
I've seen it go both ways. 3.6-3.7 with 50+ timing, or even down to 2.8 with like 35*.
-Mike
Old 02-18-2014, 01:30 PM   #6343
eevul's Avatar
Originally Posted by seasons29 View Post
Hi eevul,
I'm using mine on carpet.
Old 02-20-2014, 11:25 PM   #6344
Trader Rating: 24 (100%+)
JoeyE is offline   Reply With Quote
Old 02-21-2014, 11:28 PM   #6345
Burlap's Avatar
I've been playing around with my two Futaba servos this weekend, and notice both (9550 & 9551) have tons of travel going left, but not the same going right. To fix this I have pulled back the steering travel to the left. I have tried both aluminium servo horns and servo savers.
Now I think I have read in this thread about people having similar issues with Futaba servos and the 417. Is there a better brand of servo that gives more even travel than the Futabas?
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
