Old 01-07-2014, 07:14 AM   #6286
Originally Posted by eevul View Post
I had some bad luck this weekend and broke my V5 chassis. I caught the rear wheel on a protruding board and the rear suspension arm pulled right through the carbon chassis damaging it beyond repair. I am now trying to locate a replacement V5 chassis but can't seem to find one in stock. Does anyone know any site that has these in stock?
http://rcmarket.com.hk/product_info....ducts_id=14393
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 01-07-2014, 08:41 AM   #6287
eevul's Avatar
Originally Posted by dizope View Post
Unfortunately they are sold out as well:
TAMIYA 13404011 TRF417V5 LOWER DECKSOLD OUT Pre-order around 2-3 weeks back in stock !
Thanks though. I think Banzai Hobby might have them in stock. Checking with them but they are closed from Dec 28, 2013 to January 6th, 2014 for their holidays. Hopefully I'll hear back this week if they have them in stock.
eevul is offline   Reply With Quote
Old 01-10-2014, 01:38 PM   #6288
clint's Avatar
Trader Rating: 23 (100%+)
Send a message via MSN to clint
Hello there I went to your link but nothing is there any more..any chance you have some of these left?
Originally Posted by DS Motorsport View Post
We're offering Low Profile shocktowers for the TRF417 chassis.
Our shocktowers are designed to enable the use of LP shocks but retain full length springs. During testing it was very clear the full length springs are superior to the short springs and thus we designed our shocktowers to enable the use of both type of springs.
The shocktowers are currently in stock and sold through the following site:
http://www.capricornrc.nl/dsmotorsport/shocktowers
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 01-13-2014, 11:57 PM   #6289
Blueman Austria's Avatar
Default Smokem LX Steering Arms
Hy there!
Have anyone tried the 2mm longer Smokem LX Steering Arms?
Is it worth to try them out?
Greetings Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 01-19-2014, 12:17 AM   #6290
skyball's Avatar
Hey Rainer, I have the LX arms built into my car. I bought them to gain a more linear steering, because I think that all those different radiuses in the steering assembly (servo arm, steering arms, steering knuckles) can't be good. Now at least my servo arm and my steering arms are the same length and the difference to the knuckles is a bit less.
Unfortunately I have no "home track" where I practice regularly, so I can't deliver any "hard data" on the effect of the arms compared to the tamiya arms. All I can say is that - at least - the car feels just as good if not a bit better. Also the build quality of the arms is great and on par with the tamiya parts.
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 01-19-2014, 05:22 AM   #6291
SS LS1's Avatar
Has anyone tried the 418 lower chassis on a 417 yet? (high grip carpet)
Besides the floating servo mount, the 418 chassis would be a direct swap onto a 417x wouldn't it? Are the steering arm screws in the same location?
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 01-19-2014, 08:19 AM   #6292
vivo quevas's Avatar
Trader Rating: 18 (100%+)
SS LS1, I just went over to my box I took my 417v5 and layed it on my 418 and all the chassis holes are in the same locations. get a floating servo mount and you will have 417 1/2.
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 01-19-2014, 11:52 AM   #6293
Trader Rating: 24 (100%+)
I have a V5 chassis and the motor mount from the 418 does not fit. The holes are just a bit shorter. It will fit with a slight mod.
JoeyE is offline   Reply With Quote
Old 01-19-2014, 11:55 AM   #6294
SS LS1's Avatar
Thanks Vivo! I currently have the Smokem 417v7 motor mount, upper deck and floating servo mount on my sedan. Was hoping I could just swap them over to a 418 chassis plate. Sounds like it will work out nicely.
AE SC10 4x4
AE SC10 AE B4.11
Old 01-19-2014, 10:35 PM   #6295
I have also a 418 on my wrenching table, and the motor mount, bulkhead screws are different! So no dircet fit!
Greetings Rainer
Old 01-20-2014, 09:31 AM   #6296
SS LS1's Avatar
What kind of mod would be required? Elongating 2 holes and chamfering them to accept the countersink screws? Wonder if the 417x belts would work then?
AE SC10 4x4
AE SC10 AE B4.11
Old 01-20-2014, 10:14 AM   #6297
d16dcoe45's Avatar
Default Roche DCJ outdrive length?
Hey ya'll
wondering about the Mr. Roche 417 DCJ bone length? Is it 44 or 46mm? I ask because I am looking for a DCJ to work with the plastic TA06 54544 direct cup spool outdrives which I believe are 2mm shorter per side, on my 417. I have never seen a length listed and I've heard good things about Roche DCJs.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 01-20-2014, 10:32 AM   #6298
Originally Posted by d16dcoe45 View Post
Hey ya'll
wondering about the Mr. Roche 417 DCJ bone length? Is it 44 or 46mm. I ask because I am looking for a DCJ to work with the plastic TA06 54544 direct cup spool outdrives which I believe are 2mm shorter per side, on my 417.
Tamiya dcj should be okay
farmbridge2404 is offline   Reply With Quote
Old 01-20-2014, 11:01 AM   #6299
Yes exactly. You might as well buy a 418 if you want that stuff to fit nicely.
Old 01-21-2014, 08:00 AM   #6300
d16dcoe45's Avatar
Smile
Thanks for the response. Do you happen to know the Tamiya DCJ length? Again since the TA06 plastic spool outdrives are clearly shorter my guess is 46mm will be necessary. I like the idea of the TA06 outdrives for blinky 17.5 as they are much lighter AND use the wider V5 white blades. Combine those with the (lighter) 418 spool and it seems like a perfect combo for blinky.
Jay Lestingi
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
