Like Tree1Likes
Old 01-21-2011, 07:50 AM   #616
Originally Posted by dawgmeat View Post
Lol let me refine my question. What part break the most n
Get the following:
46mm steel dog bones for the front.
Titanium turnbuckles
1c and 1d front split hinge pin blocks (only needed in the front)
Aluminum adapter for the tamiya servo saver
For spares:
Spool cups
Rear Hubs (don't really break often if you place a set screw in the open camber hole)
ISF plastic caster blocks
Front steering knuckles
Suspension arms (don't brerak often but you should carry spares)
Belts
malkiy is offline   Reply With Quote
Old 01-21-2011, 09:08 AM   #617
Trader Rating: 26 (100%+)
I just started my build last night and need some info. On the center pulley, there are extra shims. Should I allow any play. I used the blue shim and 1x.02 shim and this leaves no play. Also any other tips I should be aware of.
Another question, can you reverse the gear pulleys so the belts are on the opposite sides which would give more battery room or does this take away too much space for the electronics? What is recommended?
svines1972 is offline   Reply With Quote
Old 01-21-2011, 09:38 AM   #618
Shim till there is as little play as possible without binding up the assembly. Double check the shims are in the correct location, sometimes too many shims on one side will push the spur into the top deck.
I've heard the belt moved toward the battery gives the best balance. Since the electronic side is usually the heavy side. That being said, you can flip the belt to which ever side suits you best.
Old 01-21-2011, 09:41 AM   #619
ngo8's Avatar
Send a message via ICQ to ngo8
just shim till it rolls freelly with no play mine took only one shim
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 01-21-2011, 10:09 AM   #620
Ok, I used one shim also and it seems ok. I am waiting on the gear diff to come in. Will be running on carpet, 90x45 with great traction. What weight oil is recommended for the gear diff and I have HB spring set, what springs would be recommended to start. I used blue/f & silver/r on my Cyclone TC. Also any other building tips would be greatly appreciated.
Old 01-21-2011, 10:21 AM   #621
TryHard's Avatar
On the 417, you won't be able to do this, as the servo will get in the way of the front belt, and there is no provison for the outer servo mount hole (having said that, shoe-goo servo tape would mean you could do away with the mounts... but why? )
Old 01-21-2011, 10:28 AM   #622
Oops, I just assumed it was similar to the 416. Thanks for the clarification
Old 01-21-2011, 10:30 AM   #623
Also, kit comes with 111t & 113t spur gears. Is one better to use than the other. I have the full range of 64p pinions.
Old 01-21-2011, 11:10 AM   #624
ngo8's Avatar
Put 1000w in it will work great ...as for springs just use the second carpet spring set that came with the kit they work good .
Old 01-21-2011, 11:14 AM   #625
superspeed's Avatar
It won't make much difference, they gave you two different size spur gears so you can fine tune the gear ratio to exact or get close to the ratio you want to run. I'd run 111, less rotating mass and pinion won't have to go up in size which could be possibly heavier.
superspeed is offline   Reply With Quote
Old 01-21-2011, 12:04 PM   #626
slakr's Avatar
Trader Rating: 28 (100%+)
Get the following:
What is the advantage of using the split blocks up front?
And... are you using them up front in both positions?
Thanks.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 01-21-2011, 03:29 PM   #627
Trader Rating: 31 (100%+)
Thanks.
The advantage is you won't bend the suspension block if you crash a lot.... It may also allow a little more flex.
ittjv is offline   Reply With Quote
Old 01-24-2011, 04:05 PM   #628
anybody run this in stock spec 17.5? i know mod is better but until it gets warm i will be running indoors. So far i've been using my 416x for spec and would like to try my 417
M3dreamin2008 is offline   Reply With Quote
Old 01-24-2011, 04:45 PM   #629
Trader Rating: 69 (100%+)
You will also clear the front drive belt from contacting the regular block. It's also easier to replace the belt if it's worn down.
eComet is offline   Reply With Quote
Old 01-24-2011, 06:48 PM   #630
Works great in 17.5 no timing.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
