Like Tree1Likes
Old 12-30-2013, 09:17 PM   #6271
Fredp1's Avatar
Default Gear diff 1mm screws
Building a new v2 diff, but when it came to tighten those tiny screws with a counter sunk 1 mm hex head, it's quite awkward to tighten without damaging the head.
What is everyone else dosing... Do you replace them with Philips heads.
If so where do you get it from?
Dean(14 years old)- Awesomatix A800X, Fantom FR-1 5.0 Motor, Fantom batteries, KO Propo
Dean(14 years old)- Roche P12-2017, Fantom FR-1 4.5 Motor, Fantom batteries, Team Powers Radon Pro 1s
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Fredp1 is offline   Reply With Quote
Old 12-30-2013, 09:37 PM   #6272
SS LS1's Avatar
Trader Rating: 23 (100%+)
Sounds like you are possibly using the wrong sized wrench. On all of my Tamiya gear diffs I have always used the same 1.5mm wench I use to adjust the droop screws and have never stripped a screw head.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 12-30-2013, 09:38 PM   #6273
SS LS1's Avatar
Slow server response = double post
AE SC10 4x4
AE SC10 AE B4.11
Old 12-30-2013, 09:53 PM   #6274
Fredp1's Avatar
The 1.5mm hex will not fit.
Got the verniers out and the size of the L shapped allen key that fits is approx 1.4mm. Maybe its imperial?
Old 12-30-2013, 09:54 PM   #6275
Fredp1's Avatar
T
Old 12-30-2013, 10:06 PM   #6276
Trader Rating: 27 (100%+)
Use a small torx T-6 tool. Fits good.
JoeyE is offline   Reply With Quote
Old 12-31-2013, 12:50 AM   #6277
Fredp1's Avatar
Works well. Thanks
Old 12-31-2013, 01:55 AM   #6278
Originally Posted by Fredp1 View Post
Works well. Thanks
1.5mm works also; I've built several.
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 12-31-2013, 10:45 AM   #6279
Your're lucky. For some reason I cannot my TRF 1.5mm tool. Well, I take that back, I was able to fit into one gear diff screw.
Old 12-31-2013, 04:33 PM   #6280
CraigM's Avatar
Trader Rating: 34 (100%+)
Its just the paint on the screws that makes the 1.5mm tight. Using a slightly worn driver helps but you can use a new one if you are careful
Originally Posted by Dual Fuel View Post
Hi, could i get a definitive answer please as to raising the roll center by adding shims under the bulkheads will increase or decrease grip at that end.
I have bad understeer on a high grip Asphalt track. Especially on the fast sweeper. I am not sure which end to add the spacers.
Thanks in advance
Raising the front blocks will most likely result in less steering. You can try raise the rear to 1mm for high grip, otherwise post your setup and we can help
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-05-2014, 03:16 PM   #6281
eevul's Avatar
Default V5 Chassis
I had some bad luck this weekend and broke my V5 chassis. I caught the rear wheel on a protruding board and the rear suspension arm pulled right through the carbon chassis damaging it beyond repair. I am now trying to locate a replacement V5 chassis but can't seem to find one in stock. Does anyone know any site that has these in stock?
eevul is offline   Reply With Quote
Old 01-06-2014, 07:28 PM   #6282
Csaari77's Avatar
I have a 417x with a bunch of upgrades and spares if anyone is interested. Its listed in the for sale section.
Tamiya TRF 417x
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 01-06-2014, 11:19 PM   #6283
veecee's Avatar
You can always get a Smokem 417FX chassis. They work very well on the V5.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 01-06-2014, 11:29 PM   #6284
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
for those running the smokem conversion... do you use the spur mount screws and the center screw on the topdeck when running on asphalt? what's the effect with and without them? thanks!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-07-2014, 03:07 AM   #6285
infokiz's Avatar
If you want to stay with the stock chassis. send an email to RC-Champ. champ_international@rc-champ.jp They should be able to get it for you.
infokiz is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
