Old 11-28-2013, 09:32 PM   #6241
Fredp1's Avatar
Ah okay, that sort of makes sense about the braking.
What got me curious was reading a article about one ways. The article was dated around 2007. The author showed with a good setup, the front one way can be used quite effectively.
I wasn't sure if anyone uses them today, or had the cars/motors changed that much?
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 11-29-2013, 03:32 PM   #6242
Fredp1's Avatar
Here is the very very detail thread on how this driver got a one way working well on his car.
http://forum.teamxray.com/viewtopic.php?f=8&t=2293
Old 11-29-2013, 08:46 PM   #6243
CraigM's Avatar
Trader Rating: 34 (100%+)
Lots of people used to run one-way on foam carpet (as in the post). For rubber carpet and rubber asphalt no one uses them and they are illegal in some rules. That aside, even if you can get them to handle they are terrible for racing because you can't battle without brakes
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-01-2013, 04:17 AM   #6244
Fredp1's Avatar
No brakes would be a big problem.
Thanks Craig.
Old 12-03-2013, 10:58 AM   #6245
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
Default Roche and MR..Roche
New Roche and MR..Roche products for the 417 just came in: Blue anodized body height adjusters, Double Jointed CVD's, Blue Spring Holders & Pink Blades.
http://emrfactory.com/store/parts/parts-tamiya
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 12-03-2013, 06:45 PM   #6246
Burlap's Avatar
Send a message via MSN to Burlap
Just noticed that this is page 417
Burlap is offline   Reply With Quote
Old 12-07-2013, 10:48 AM   #6247
How often do you guys rebuild your shocks? I've noticed some oil around the Damper stays and piston rod ends so I'm wondering if after 2 months the seals need to be replaced?
From what I can tell it looks like the clear oil in the kit is 900 wt and the yellow is 400 wt, which do you use in the dampers?
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 12-07-2013, 04:31 PM   #6248
Yellow in the shocks the 900 is for the diff. I would go thicker in the diff though. But if that's all you have, just use it
Juan Aveytia is offline   Reply With Quote
Old 12-10-2013, 12:27 PM   #6249
Just curious but how many of you with the base 417 kit cut the motor mount to add more flex to the overall feel of the car?
Cheers, Jeff
Old 12-10-2013, 02:58 PM   #6250
CL
CL's Avatar
Trader Rating: 32 (100%+)
I installed the motor mount from the 417X, and it gives the car a little more flex as well. It also makes changing motor or pinion gear a lot easier with the 2 extra motor mounting holes.
Believe in yourself!
CL is offline   Reply With Quote
Old 12-10-2013, 05:13 PM   #6251
Doesn't that option require drilling a hole in the lower deck?
Cheers, Jeff
Old 12-10-2013, 06:44 PM   #6252
CL
CL's Avatar
No, it's a direct bolt-on.
Old 12-10-2013, 07:29 PM   #6253
Awesome thanks! There are 3 pieces to that set up correct, a left, right, and lower, do you use the lower?
Cheers, Jeff
Old 12-10-2013, 08:27 PM   #6254
golgi's Avatar
Trader Rating: 14 (100%+)
Hi all, I just recently purchased the 417x used. I've been wanting to get a 417 variant for a while now. What I'm curious about is, what are all the 417 variants and what order do they go in?
My assumption is 417, 417 w/gear diffs, 417x, ?, 417 v5. Is this correct? And if so, what is the model where there is a question mark?
Also, what are the benefits of each upgraded model? Is there a major difference in handling from the 417 to 417x to the 417v5? Thanks, I know that is a lot of questions but I've searched online and within this forum and haven't found answers to these questions.
golgi is offline   Reply With Quote
Old 12-10-2013, 08:55 PM   #6255
Super Moderator
Grizzbob's Avatar
Same here, I wasn't really concerned about getting more grip, but I was NOT happy about the original motor mount when using 17.5 motors & small spurs, the 417X mount was by FAR the best way to deal with it....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
