Old 11-07-2013, 03:36 AM   #6211
CraigM's Avatar
Trader Rating: 34 (100%+)
http://tchub.wordpress.com/2013/11/0...setup-asphalt/
A bit of a brain dump for now, I'll tidy it up tomorrow. Any other settings to explain or elaborate on let me know
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-07-2013, 07:50 AM   #6212
Looks great, thanks Craig!!!
Can't wait to try this on Saturday.
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 11-07-2013, 10:38 AM   #6213
Marcika's Avatar
thanks for it. I am gonna try it tomorrow on carpet :-)
Marcika is offline   Reply With Quote
Old 11-07-2013, 01:54 PM   #6214
CraigM's Avatar
Carpet is a little different
http://tchub.wordpress.com/2013/11/0...-setup-carpet/
Old 11-07-2013, 06:32 PM   #6215
nolo148's Avatar
When using spilt suspension mounts, how do I know whether it's XA or A?
As well, which suspension blocks are narrow and which suspension blocks are wide?
nolo148 is offline   Reply With Quote
Old 11-07-2013, 06:50 PM   #6216
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
when mounted, inner letters is the setting...
i.e. XA-A A-XA = A
A-XA XA-A = XA
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-08-2013, 10:24 PM   #6217
Trader Rating: 31 (100%+)
Hi All,
Anyone out there know if you run the smokem v7 conversion on a 417x, do you need to shim the bulkheads/top deck if you don't run the center post?
Thanks!
ittjv is offline   Reply With Quote
Old 11-09-2013, 04:45 AM   #6218
Marcika's Avatar
Craig - thx for sharing. One question: if you change stabilizer rod do you have to adjust the lenght of the holders attached to the arms or keep kit lenght for all lenght.? I tried the soft swaybar after the medium and i was not sure worked well. What should be the right lenght or how can it be measured?thx
Old 11-09-2013, 09:07 AM   #6219
veecee's Avatar
Originally Posted by ittjv View Post
Hi All,
Thanks!
Yes you will need to shim the bulkheads by >1mm (eg 1.5mm). This then gives you clearance between the center post and the too deck. But the car generally handles better with the center post connected to the top deck and the layshaft bulkheads disconnected to the upper deck.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 11-09-2013, 04:20 PM   #6220
CraigM's Avatar
I don't think the length matters too much. I just make it so the sway bar is horizontal and then ensure the sway bar is set evenly side to side
Old 11-09-2013, 04:50 PM   #6221
Fredp1's Avatar
It's time to replace the ball studs and cups on the 417x as they are starting to bind.
What's is everyone using to replace the ball studs? The Tamiya ones or is there any other options?
Also with mounting the shocks on the shock tower, I want to replace the ball studs with a stud and nut. Can someone suggest what to use and where to get some?
Fred
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 11-09-2013, 07:58 PM   #6222
nolo148's Avatar
I've had success with Yokomo Pink up front and Yokomo Blue in the back on medium grip carpet in stock, mod might be a different story But I prefer the Yokomo springs over the Tamiya springs on carpet.
Old 11-09-2013, 11:43 PM   #6223
alcyon's Avatar
Default 417 spool choices
guys, got a couple of questions regarding spool for 417. It seems Tamiya spools are out of stock everywhere, I now have 2 choices, one is by spec R and 3racing.
The thing is 3 racings outdrive is plastic, and the spec R seems to be spring steel.
What are your opinions about the outdrives of each of these brands? which one lasts longer ?. Also for the Tamiya 44mm DCJ , is the distance from the dogbone end to the bearing mounting face the same as the regular 44mm CV joint ?
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 11-10-2013, 09:45 AM   #6224
http://www.thercracer.com/2013/11/ta...ght-front.html
I use the new lightweight drive cups, excellent, cheap and you will never have to replace them, just the drive shaft protectors.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 11-14-2013, 05:23 PM   #6225
Craig, long story short, my understeer problem and general inconsistency was caused by my belts being too loose. I now have a tweaked version of your setup in this car and it's handling is simply amazing!! It's the best it's ever been!! Thanks!!
Richard G.
Tamiya...
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
