Old 11-05-2013, 07:07 PM   #6196
Originally Posted by narcotiks View Post
Could you fill out a setup sheet? They are available on petit rc.
Do you mean corner entry understeer? Also, are is this on carpet or asphalt?
I have a setup sheet filled out at home. I'll post it tonight.
Yes, understeer on corner entry and corner exit.
Sealed asphalt parking lot track. Sprayed with a soda/water mixture on race days.
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 11-06-2013, 02:03 AM   #6197
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by ATLASCOPCO View Post
Put shims in or take out
You can either take shims out of the front bulkhead or add shims to the c-hub
Originally Posted by dizope View Post
How can I get my car to have more initial steering, if that is the proper description? My car pushes on corner entry when on power. And it pushes on corner exit when on power as well.
417v5
Sorex 32
TRF dampers with 32.5
HPI silver springs
5.5 ride height
4.5 droop measured with under the arm
.5 under suspension blocks
b/split b (front)
xb/c rear (2.5 rear toe in)
.5 front toe in per side
roughly 25 degrees of steering throw
Tamiya aluminum servo saver horn using kit springs (link)
shocks are in hole 4
-1.5 front camber
-2.0 rear camber
no wheel spacers
stock sway bars
3k diff oil
front spool
3mm shim under inside front camber link
All other settings per the manual
Airtronics MT-4 with 92524
Tekin 17.5 Gen2 blinky
Tekin RS Gen2
Things I've tried with no real success:
- changed Savox 1251 to 1258
- took sway bars off
- turned the steering expo all the way up
- v5 shocks with Tamiya springs (front 32.5/white) (rear 25/white/yellow)
- stood front shocks up to hole 6
- removed 4 screws (inside) from the top deck
- drag brake between 0 and 30%
A friend has a v5 that has incredible steering with a mostly stock setup (no sway bars) but for the life of me, I can't get mine to turn like his does. I even put his RX in and tried it with his TX (different brand).
The strange thing is I rebuilt the car and went to Tamiya in LA 2 weeks ago for the Speedtech race and the car ran awesome. Ran the next week at home on our sealed parking lot track and it was back to usual; push monster.
Why so narrow? B/B XB/C with no wheel shims is too narrow. C/C XA/E with 0.5mm wheel shims should be the starting setup for all tracks. You've also got about 1mm too much front droop which also causes push on power
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-06-2013, 07:15 AM   #6198
Because that's what came with the kit. And at some point, taking the wheel shims off seemed to help another steering issue so I assumed making it narrower helped. I will get some blocks to widen it up and test this weekend.
In this case, would it be okay to make both changes at once (widen and reduce droop)?
Thanks Craig.
Richard G.
Tamiya...
Old 11-06-2013, 01:05 PM   #6199
CraigM's Avatar
Yep I'd try both changes and tune from there
Question for people: would it help if I post a base set up along with some tuning tips? if so, what 417 version are most people running?
Old 11-06-2013, 01:50 PM   #6200
ATLASCOPCO's Avatar
Increasing the camber link angle (at either end) increases camber gain which provides more traction grip as the car rolls. It's most noticeable from mid corner to exit when the car is rolling the most.
I think the effect of the roll centre change is negligible when we're talking about 0.5mm-1mm difference on the camber link. If I want to change RC I always use shims under the suspension blocks.
Craig
Sorry to be a pain in the ass
So you are saying that it's best to reduce shim size from under the block ???
I do have a 1mm under the. F/f & f/r
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 11-06-2013, 02:09 PM   #6201
Sounds good, I'll swap things around tonight. I have 1XA in 1-piece and separate, which would you recommend?
Richard G.
Tamiya...
Old 11-06-2013, 02:18 PM   #6202
Trader Rating: 31 (100%+)
dizope,
Toe that sucker out too if you want more initial steering. That's probably what you're missing.
ittjv is offline   Reply With Quote
Old 11-06-2013, 02:25 PM   #6203
Marcika's Avatar
craig - would be perfect sharing set up. I run v5 have all type of susp blocks. Now we race at carpet med-high grip, springtime on asphalt low-mid grip. Both track dize is approx a handball field max (13-14mp/lap, carson 12t set). Thanks
Marcika is offline   Reply With Quote
Old 11-06-2013, 02:36 PM   #6204
Originally Posted by ittjv View Post
dizope,
To how much? I'll try that one next.
Richard G.
Tamiya...
Old 11-06-2013, 02:39 PM   #6205
Most setup guides say no more than 1 degree in either direction. I would start by going to 0 at each wheel, then .5 and then 1 degree. Good luck.
Old 11-06-2013, 03:05 PM   #6206
I'm at .5 per side now and I believe I have tried 1 per side but will try again this weekend.
Richard G.
Tamiya...
Old 11-06-2013, 04:42 PM   #6207
nolo148's Avatar
That would be great Iam still running the 417x and I have a hard time getting rid of traction roll in high grip carpet conditions.
nolo148 is offline   Reply With Quote
Old 11-06-2013, 04:50 PM   #6208
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
I run a 417x as well. Tips would be great craig!!
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 11-06-2013, 08:19 PM   #6209
CraigM's Avatar
Craig
I didn't say anything about under the blocks. Your original question is what should you change if you are happy with your setup but you need more mid-exit steering, and I said to increase the angle of the front camber link. You can either remove shims from the bulkhead or add shims on the c-hub
1mm is a lot under the blocks but if your setup works then don't change it
I always run split because it's easier to drive. 1pc can give a bit more rotation/corner speed
Old 11-06-2013, 08:32 PM   #6210
Thanks Craig!!
Richard G.
Tamiya...
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
