Old 10-15-2013, 02:28 PM   #6121
Typeone's Avatar
Trader Rating: 30 (100%+)
Originally Posted by vivo quevas View Post
Tim if you need more punch less timing. How much timing do you have in your motor? If you go with less timing leave the gearing the same and see if you get more punch. Then gear up if you need more speed down the straight!
Brian I'm running 57* of timing with a FD of 3.65 and the motor is temping about 130/135*, it just didn't feel the same since I first ran it. Also the ear plugs u said I just need to put a little bit in it correct?
TRF101/Tamiya F104-V2/ TRF Tamiya 417/ Smokem FX chassis & V7 conversion/ Speed Passion/ Sweep Racing/ Futaba/ SMC
Typeone is offline   Reply With Quote
Old 10-15-2013, 04:34 PM   #6122
vivo quevas's Avatar
Trader Rating: 18 (100%+)
C
Yes you only need enough to fill the teeth. You have too much timing take it back to 40 or 45 you wil have more punch. 57 is too much it will sound good but it won't run good it took me along time to learn that. Still want to oner time my motors!
I was told yesterday when i talk to TC he said take the timg back to 40 gear4.0 and check lap times an temps . 4.0 for rpm motors 3.7 for torque motors are a good starting point. Only rely on lap times not feel.
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 10-15-2013, 07:08 PM   #6123
Typeone's Avatar
I'll have to try that next time out on the track Brian. I bought the motor from express motor sports and he said that 57* was optimal timing for that motor I got the power I think it's just FD need to gear it differently.
Old 10-15-2013, 07:50 PM   #6124
I bought a motor from John a kill shot.2 month's ago I smoked it so if you got your motor to go at 57* thats awesome Killshot motors have a very narrow window of operation. Take the gearing back to 4.0 and give it a few laps in practice . Go by lap time and see what happens. I have been running a d3.5 and I have the timing on 30* my motor is fast. I am buying a new stator to replace the one I smoked I also bought a new 21.5 Killshot motor this week.
I have been running my D3 21.5 on max timing and geared 3.5 and george has been pulling me 8 feet down the straight. so this week I turned the timing down 5* and going to leave the gearing the same check lap times they should be in the mid to low 15's in practice if they are not I will regroup gear up and go from there.George turned a 14.99 and I turned 15.23 for fast laps in GT last week. I think we are going to turn 14.7/14.9 this week IMHO.
Old 10-16-2013, 10:45 AM   #6125
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
I see this is turning into a motor war huh!!!
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 10-16-2013, 12:05 PM   #6126
hahahahahaha
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 10-16-2013, 01:34 PM   #6127
QUOTE=Mr.juarez;12637170]I see this is turning into a motor war huh!!!
YES
[/QUOTE]
Old 10-16-2013, 08:22 PM   #6128
Mr.juarez's Avatar
YES
[/QUOTE]
That's gonna get ugly and expensive quick!!!!
Old 10-17-2013, 01:14 PM   #6129
SS LS1's Avatar
Trader Rating: 23 (100%+)
What is the lowest FDR you can get using the Smokem 417v7 kit?
Can you get in the low 3's for spec class racing?
Thanks!
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 10-17-2013, 02:18 PM   #6130
Thanks!
I had 88t/53t=3.233 in my car in my V7 yesterday but I had room for 56t= 3.060
so yes there is plenty of room for the ratio you want.
Old 10-17-2013, 04:08 PM   #6131
Typeone's Avatar
Brian is that 88/53 is what ur running in gt3 or 17.5? What motor are u running with that FD?
Old 10-17-2013, 04:33 PM   #6132
This week I was going to run gt3 with my 417 instead of my TB03. I was starting out a 3.57 and check lap tines and temps then gear up from 88x48 =3.57 work toward a 88x53=3.23 a couple a teeth at a time and see what the lap times and temps are.
Old 10-17-2013, 04:51 PM   #6133
Mr.juarez's Avatar
Brian you're running the 417 as gt3 this week? Check your pm at localrc
Old 10-17-2013, 06:03 PM   #6134
SS LS1's Avatar
Thanks!! That's exactly the information I needed to know as I may try the v7 kit in either USGT or VTA spec classes that need a low 3.XX FDR.
Appreciate your help!
AE SC10 4x4
AE SC10 AE B4.11
Old 10-18-2013, 07:49 PM   #6135
Mr.juarez's Avatar
Quick question. I'm upgrading my 417 to the split mount in the front rear only. The one piece block has a 3mm and a 0.7 shim under the block when upside down, on top of the 0.5shim for the block.do I need to add.anything else to make it equal where it was before?
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
