Like Tree1Likes
Old 10-13-2013, 09:55 AM   #6106
SS LS1's Avatar
Trader Rating: 23 (100%+)
Craig, or anyone else running the Smokem V7 upgrade.....
I have a 417x that I run in the USGT class on med grip carpet and have been thinking about getting the Smokem V7 kit for. My questions are.......
1) Would the V7 kit work well with the stock 417x chassis? If so should I sick with the stock 417x servo mounts or opt for the Smokem floating servo holder?
2) Or would I be better off with getting the V7 kit and a 417V5 chassis to use with my 417x bulkheads? (much pricier option as I would also need to get the TRF floating servo mount).
So basically I'm wondering if the V7 kit is a worth while upgrade using the stock 417x chassis on carpet?
All opinions are appreciated.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 10-13-2013, 11:52 AM   #6107
The V7 will work with the 417x you just need to add the shims (or get the Sepes bulkhead shims to make a proper non tweak solution.
I don't know if its any better on carpet (I haven't got the V7). I have the Sepes 417 kit, and initial findings is that its great on carpet It has a removable centre post on the mount so I can adjust it by adding a centre screw through the top deck, removing the screw or even removing the post.
The 417 has never felt this consistent on carpet for me, and its also faster into the corner.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 10-13-2013, 12:21 PM   #6108
Marcika's Avatar
NGO8 - thx. what damper do you use, new one (aeration) or the old good trf? how do you assemble it? (I mean full rebound or in line with Jill advise) could you pls pass your set up sheet to try it next time? I am really open however you say is opposite what hudy book says when traction roll exist...:-)
I tried the new damper w/o making the hole in the cup and didnt work at all :-(....
Any other advise? thanks, Marton
Marcika is offline   Reply With Quote
Old 10-13-2013, 01:14 PM   #6109
Marcika's Avatar
one more question regarding dampers - assembling as Jill pro tip -:
the softer the oil the less grip and the harder the oil the more grip? this statement both work on med asphalt and mid-high carpet? thanks
Old 10-14-2013, 09:10 AM   #6110
SS LS1's Avatar
Thanks for your reply Qatmix, 2 questions for you.......
Are you running your stock 417 lower chassis with the Sepes kit?
Did you switch to a floating servo mount? If so which one?
Thanks!
AE SC10 4x4
AE SC10 AE B4.11
Old 10-14-2013, 10:08 AM   #6111
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
I'm using a regular 417 with a 417x chassis, cso servo hook, smoken v7 kit, v5 shocks. V7 kit fits the 417x perfect car has tremendous corner speed.
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 10-14-2013, 02:34 PM   #6112
Typeone's Avatar
Trader Rating: 30 (100%+)
Quick question. I'm running a 92 spur and 49 pinion both 64p which gives me a FD of 3.65 in my 417 for 17.5 blinky, but what's the difference in running similar FD but with a smaller spur and pinion. Should I just use a smaller spur and change out pinions when track layout changes for more speed or acceleration?
TRF101/Tamiya F104-V2/ TRF Tamiya 417/ Smokem FX chassis & V7 conversion/ Speed Passion/ Sweep Racing/ Futaba/ SMC
Typeone is offline   Reply With Quote
Old 10-14-2013, 03:33 PM   #6113
narcotiks's Avatar
Doesn't matter what combination of gears you run or if you run both smaller, if the ratio is the same the performance of the motor will be the same.
Run a smaller spur so you have a range of FDRs you can achieve without changing the spur, just by changing the pinion.
narcotiks is offline   Reply With Quote
Old 10-14-2013, 03:45 PM   #6114
Thanks!
I use it on my 417v5. The Sepes and the smokem both have the chassis pin on the motor mount so you will need to drill a hole in the chassis to fit either (If you have a 417, although it should be fine on a 417x chassis plate)
Also you will need to fit 1mm shims (or the Sepes 1mm bulkhead spacers) on the original and 417x bulkheads.
As to a servo mount, I have used a CSO one on an original 417, also the tamiya one will fit but you will again need to drill a small hole for the mounting peg.
Old 10-14-2013, 04:14 PM   #6115
Mr.juarez's Avatar
No drilled holes needed with the 417x plate. Fits like a gloove
Old 10-14-2013, 04:51 PM   #6116
Typeone's Avatar
Ok thanks ima try 92 and 48 which gives me a FD of 3.73 I kinda need a little more punch cause I got the speed on the straight just need it in the inside of the track.
Old 10-14-2013, 06:47 PM   #6117
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Tim if you need more punch less timing. How much timing do you have in your motor? If you go with less timing leave the gearing the same and see if you get more punch. Then gear up if you need more speed down the straight!
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 10-15-2013, 06:20 AM   #6118
Are the aluminum hop ups from 3 racing, mainly the C hubs, knuckle arms, and rear uprights, worth it? Are the tolerances good?
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 10-15-2013, 06:40 AM   #6119
Mr.juarez's Avatar
I only bought the rear 3racing hubs. They fit really tight so it was binding the arms, but I'm sure a little sanding could have fixed it but I went back to stock since I was heavy
Old 10-15-2013, 02:10 PM   #6120
CraigM's Avatar
Trader Rating: 34 (100%+)
Don't use aluminium suspension parts
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
