Like Tree1Likes
Old 10-02-2013, 08:08 AM   #6061
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by CraigM View Post
418
Of course, if you got 600+ to blow.....
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 10-02-2013, 09:57 AM   #6062
Does everyone here use the stock Body mount posts for the 417 or are there other options available that offer easier adjustments for different bodies? Or is the option to have multiple sets of body posts for the different bodies one has?
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 10-06-2013, 11:28 PM   #6063
Mr.juarez's Avatar
Narcokits & craig thanks for the help amd time. The car was much better this week compared to last week.
Last weeks results were. .
27 laps in 7:11 best lap 15.8 compared to this weeks
28 laps in 7:06 best lap 15.2 (tq and won main)
I stayed late to make sure it wasn't the fact we changed from night racing to daytime, but the car had even more grip at night than last week with same layout in 70* weather using 36 sorex vs 28 from last week.
Now my next question is. What are the differences in "feel" between the arm hole 1&2 front viseversa in rear as well? I've looked at this years and last years setups list on petite rc and they all vary with #1 front being common and #2 rear. Some are at #2 front and #1 rear.just looking for a more detailed explanation between them two as I would like to try it for next weeks layout
Old 10-07-2013, 12:48 AM   #6064
narcotiks's Avatar
No worries man
You do need to keep consistent with the tyres you use though, as changing compounds will change the way the car feels. You generally need to stiffen things up (harder springs and shock oil) when using softer tyres, and soften things up (thinner oil and softer springs) these are the bigger changes between tyres but other changes may be necessary.
Hole 2 on the arm (closer to centre of car) makes the shock action softer. it's like lowering your shocks in on the shock tower. Basically gives more steering/front grip but can sometimes make the car push if it starts to overload the front tyres too much, in this case hole 1 would give more front grip/steering. Hole 1 is further out from the centre of the car and makes the front shock action stiffer. Pretty much opposite effects of hole 2.
narcotiks is offline   Reply With Quote
Old 10-07-2013, 05:37 AM   #6065
Does anyone know where get a tamiya 417v5 in Australia? Or order the 418
Christian82 is offline   Reply With Quote
Old 10-07-2013, 06:13 AM   #6066
Trader Rating: 17 (100%+)
418
Craig! How you been man?
SANWA / TEAM ORION / PRO-LINE / PRO-SPEC / P1 BRAND / PROTOFORM / ACTIVRC
I'm not a Business man, but I'm the Bizzness man!!!
Sean Williams is offline   Reply With Quote
Old 10-07-2013, 07:15 AM   #6067
vivo quevas's Avatar
Trader Rating: 18 (100%+)
George I think we both made progress on our cars. George is selling himself short he had one of the best races last week I gave him all I had we were 3 ft apart for most of the race an he ended up with a 3 second win. Great job lets do that again .
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 10-07-2013, 10:06 AM   #6068
In step 7 of the manual the directions say to cut off the ends of the Direct Cups (BB26) but this means the Direct Coupling (BB25) can just slide off and onto the Swing Shaft. Does this mean you don't use the coupling or do they actually stay in place without the ends?
Cheers, Jeff
Old 10-07-2013, 11:48 AM   #6069
Nope, dont remove the ends until you want to take them off to replace new ones. As you mention the BB25 part will fall off otherwise.
There will be a new direct coupling out soon for TA06/417/418 which will just fit on and allow you to use the swing shaft protectors.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 10-07-2013, 04:17 PM   #6070
CraigM's Avatar
Trader Rating: 34 (100%+)
Hey Sean! Been awesome, I'll email you
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-07-2013, 05:02 PM   #6071
Figures! I tore my car apart Saturday night to give it a good cleaning and replace a bunch of missing screws when I saw the instruction to cut the ends off.
Oh well lesson #2 learned.
Is it okay to run the car without the Direct Coupling sleeves in place or is this a really bad idea? I have new Direct Cups on order, so no big deal if this is a bad idea.
BTW lesson #1 was to take the car off the track every 30 minutes or so and tighten all the screws on the bottom of the deck. I had the local track to myself Saturday morning and was getting in some good practice when after about 90 minutes the whole front end collapsed. I had lost 5 screws!
Cheers, Jeff
Old 10-07-2013, 09:25 PM   #6072
Mr.juarez's Avatar
Originally Posted by narcotiks View Post
No worries man
Got some reading to do!!
That was an amazing race to watch I bet. I had tears when we were all done with the main. I felt as if I blinked I would have made a mistake.!! That risky moves we made through traffic were crazy
I was contemplating running gt2 this weekend and see how it does. Or if heats are far apart swap motors each heat and mains
Jeff loctite man! !
Old 10-08-2013, 03:27 AM   #6073
C van der Hagen's Avatar
Tired of losing the 1.5mm spacers between topdeck and bulkheads when using the (SRP or raceberry) conversion set? SRP offers 1.5mm spacers blocks that can be glued on the bulkheads, it can also be used without glue and prevent a tweaked chassis.
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 10-08-2013, 09:38 AM   #6074
Jeff loctite man! !
LOL thanks, I do have some, guess I'll put it to use.
Cheers, Jeff
Old 10-08-2013, 10:14 AM   #6075
Mr.juarez's Avatar
I use the crap out of it with stock and titanium screws, however I don't use with my aluminum screws as I learned the hard way with my associated. I recheck them every heat.
Tqrcracing.com has all you need
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
