Old 10-01-2013, 04:51 AM   #6046
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Mr.juarez View Post
By front kick up you mean the small .5 front spacer under the block? Yes car has ridiculously front grip even before the smokem parts.
I was running blues front and yellow rears, but someone suggested me to go softer that night so I did in hopes to solve the issue. (Which I didn't wash out as much but it could be that that traction came up a little bit too)
I'm not running sway bars at the moment.
Some also suggested me to try out david jun set up from tamiya as a start up, do you agree?
Yep kick up is that front spacer. I would never run that on our car, it increases weight transfer and castor. Normally we do the opposite by adding shims under the FR block to give anti-dive.
David Jun's setup is basiclaly kit, it should get around ok. I think you'll find just fixing the kick-up, running asphalt springs (HPI silver, ride red) and runnning sway bars will solve your problems
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-01-2013, 06:32 AM   #6047
Velocitygt's Avatar
Heaps of parts for sale cheap!
***TAMIYA 417 PARTS SELLOUT***
Velocitygt is offline   Reply With Quote
Old 10-01-2013, 01:26 PM   #6048
in a used car deal i picked up a bunch of TC springs, can anyone help me identify them? the 4 sets top left are tamiya's, all the others i'm not sure
theagentorange is offline   Reply With Quote
Old 10-01-2013, 01:56 PM   #6049
The white springs with pink, blue, black, green, and orange look like Yokomo.
Not sure about the black ones. They don't look like HPI.
-Mike
Old 10-01-2013, 01:57 PM   #6050
vivo quevas's Avatar
Trader Rating: 17 (100%+)
The bottom springs I believe they are RSD. You can check the spring rate on the RSD web site.
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 10-01-2013, 02:01 PM   #6051
i think i read about someone using them on the 417's, thanks... off to google machine
ahhh. i've heard of people using the yoks.... from a quick rate search.... pink/front-blue/rear be about the same as white/blue tamiyas?
Old 10-01-2013, 04:13 PM   #6052
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by narcotiks View Post
This should hopefully solve your loose problems. I remember you saying you ran on ashpault? This is an asphault setup so yeah.
Tamiya springs dont work well on ashpault and running no sway bars would have caused problems. I cant remember if I added the rear diff oil in the setup but run 2000.
Important to note: front shock mounting position in the arm to hole 1 (you need to flip the arm over)
Oh and upper link position front and rear in hole 1 (middle hole)
Originally Posted by inpuressa View Post
Not having the fronts especially will make the car hook and unpredictable.
I ordered the hpi silvers and some other stuff to try out, thanks for the input. Ill report back
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 10-01-2013, 05:02 PM   #6053
Does this mean you will be building sway bars too???
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 10-01-2013, 05:40 PM   #6054
Mr.juarez's Avatar
Oh noo you didn't! !!!
Rofl!!!!
Old 10-01-2013, 07:01 PM   #6055
So I finally got to run my 417 today at the local track, in addition to my complete and total lack of driving skills the steering arm screw kept coming out. At one point I had to walk the track to find the screw but I lost the shim and the spacer. So my question is do you guys use Loctite on the steering arm screw and if so which strength do you use?
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 10-01-2013, 07:43 PM   #6056
Mr.juarez's Avatar
I did the same mistake.(lost 2 screws and shims) I accidentally put one of the shims that go in the hinge pin blocks instead of one thinner that was supposed to be. When I did that I couldn't tighten the screw all the way or it would bind. After we compared the car to another local one and shimmed it right I can tighten the screw all the way and it turns butter smooth. .
Its a 0.1 & a 0.7 I also added an extra .01 on the top between the arm and screw to get all the play out.
Old 10-01-2013, 08:23 PM   #6057
Thanks, I must have had the wrong shims in. I'll need to get a new Micrometer as the one I have is having issues but I'll try some different combinations.
Cheers, Jeff
Old 10-01-2013, 08:58 PM   #6058
still running the 417x. Wondering if I should upgrade to a 418 or just use the smokem v7 motor mount. I can't see the 418 being that different other than the flex characteristics. What your guys take on it?
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 10-02-2013, 03:25 AM   #6059
CraigM's Avatar
Old 10-02-2013, 04:40 AM   #6060
C van der Hagen's Avatar
SRP conversion
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
