Like Tree1Likes
Old 09-24-2013, 11:38 AM   #6016
so i have a stock v5 as well as a fully smokem (chassis, 417v7 convesion, everything) 417x.... opinions on which i should run 17.5 blinky and which mod (between 8.5 and 4.5 depending on the day)?
theagentorange is offline   Reply With Quote
Old 09-24-2013, 08:41 PM   #6017
-jacob-'s Avatar
hello guys,
just picked up a V5... i know that people prefer the V5 for asphalt and i really purchased it to eventually run GT1 in tcs when i do get better... for the winter season tho i would like to run it on carpet... anyone here have anyhting to share to make the V5 works well on carpet is much appreciated...
- Jacob
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 09-25-2013, 10:28 AM   #6018
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by -jacob- View Post
hello guys,
- Jacob
http://www.petitrc.com/reglages/tami...miyaTRF417.htm
Take a look through here. I don't run carpet but see if there are any setups in there.
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 09-25-2013, 03:14 PM   #6019
The v5 works well on carpet, I used the kit shocks 40wt all round, hard front roll bar, soft rear and white springs front with blue rear.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 09-29-2013, 09:57 AM   #6020
Mr.juarez's Avatar
First time running the smokem motor mount and top plate. Another driver and I were really loose all night long. Is anyone else having these issues. I went from hanging with the pack to now just drift mode. I changed droop, springs, tires, sauce and nothing helped.
Old 09-29-2013, 10:17 AM   #6021
vivo quevas's Avatar
Trader Rating: 18 (100%+)
For the first time I was able to match laps with justin but as soon as the sauce wore off in 6 laps My 417v5 with the Smokem conversion was undriveable loose in 17.5 but I was leading for a few laps till the sauce wore off. Justin said he thought I needed to have gone to a softer tire I will try new tires next week.
In GT we had a great race going till a back marker went wide and Turned in on me,after that I was catching you but I hit a dot pressing to catch you. I think I had too soft a tire in this class because the car was good early and fadded near the end. IOne tire was down to the cord on the left front it was 3/16 spot showing cord. It was a fun night of racing 3 race on my GT3 and it is starting to work pretty good I am making a roll center change I hope my TB03 will be ready for prime time!
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 09-29-2013, 11:31 AM   #6022
Mr.juarez's Avatar
That was the only major change I did. I tried 28, 32,34, 36 and nothing helped. I'm gonna pull it off and go out there again later on with stock mount
Old 09-29-2013, 01:53 PM   #6023
-jacob-'s Avatar
Thanks man, this def helped me out...
Thank you will be testing it this Saturday.. really excited
Just finished my V5
Old 09-29-2013, 02:20 PM   #6024
what fan/heatsink setup is that?
Old 09-29-2013, 02:49 PM   #6025
yokemad's Avatar
LRP, pls watch the weight its quite heavy and cause a balance issues...
yokemad is offline   Reply With Quote
Old 09-29-2013, 05:23 PM   #6026
narcotiks's Avatar
Post your setup maybe one of us can help
narcotiks is offline   Reply With Quote
Old 09-30-2013, 12:43 AM   #6027
veecee's Avatar
Trader Rating: 34 (100%+)
Which 417 do you have? 417 and 417X needs 1mm spacers on top of the front & rear bulkheads to lift the upper deck by 1mm. This is illustrated by the pic below on the Smokem website (note the 1mm spacers sandwiched between upper deck and rear bulkheads:
Also no spacers are needed on top of the Smokem centre post.
If you have a 417V5, you do not need any spacers to raise the upper deck. It is a straight bolt-on.
And unless you have loads of grip, you don't need to add the extra 2 screws to bolt the upper deck onto the motor mount and layshaft bulkhead. Just run the middle screw that bolts into the Smokem centre post. Again, check the above pic. This is the default setup that seems to run the best.
If you do the above, the conversion will run as good, if not better, than your standard 417 running identical setups. As narcotiks suggested, post your setup so we can see if we can help.
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
Old 09-30-2013, 05:56 AM   #6028
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
I received my Smokem V7 conversion for my V5 last Wednesday, put it on the car on Thursday and hit the track Saturday morning for the last round of Challenge Cup in Canberra. The layout was almost identical to the one used at the ACT Indoor Titles a few months back, so I think it would be a reasonable comparison.
Overall, my car was at least a lap faster over 5 minutes and my best lap was around 0.7 quicker (lap times were 14-15s). If I get the time, I'll try to do a more complete analysis tomorrow, but my gut feel is that the car carried way more corner speed. Motor, ESC, settings and gearing were identical.
Needless to say, I'm pleasantly surprised
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 09-30-2013, 09:06 AM   #6029
Mr.juarez's Avatar
Yes I did that. Have a regular 417 (none v5) so I added the 1mm spacers front and rear as pictured.
I edited a sheet hopefully I did it right. Its almost still the manual set up.
Old 09-30-2013, 01:48 PM   #6030
Does anyone know if I will be able to run this body on a 417 with standard shocks and towers? It says it works for a 415 so I'm hoping it will work <crossing fingers>.
https://www.tqrcracing.com/shop/prod....asp?p_id=5953
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
