Old 09-18-2013, 06:41 PM   #5986
The fan I got at the local race track was not in a good position as you can see from the first picture. I was worried it would jam into the tire (it only had about 1/4 inch of clearance) so I took it apart so I could switch it to a kind of side mount and bent the bracket to have the lower fan closer to the motor. I'm not sure if I'll keep both fans on or I may cut the one on the back side off. What do you guys think?
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 09-18-2013, 06:54 PM   #5987
Velocitygt's Avatar
Truckload of parts still available!
TAMIYA TRF 417V5 WX Premium Package X 2 - RACE PACKAGE SELLOUT!!
Velocitygt is offline   Reply With Quote
Old 09-19-2013, 01:12 AM   #5988
Marcika's Avatar
Hi,
I am pretty new on this forum, but I tried to read as much as I could :-). I can see everybody tries to be very helpful and very detailed. I just purchased my V5 and ready to assemble, however there are different stories about how to build up. I would like you to get your experience/opinion on the below questions, much appreciated :-)
1. Cement: per instruction you put cement everywhere (lower, upper deck, etc). What do you think on it? Keneth blog says just put on the lower deck, file the edges and leave other parts, if I remember correctly.
2. Gear diff unit II with metal bearing for front: Does anyone have instruction/video link how to assemble diff with putty 75 from Ride? I can see Jill video with oil. however I am not sure about putty filling.
3. new damper: this is very new to me, I only used old TRF dampers so far. Per manual I should make a little hole in the cup. By what tools did you do it and what can go wrong? What should I focus on not to break it.
Many thanks for your reply.
Have a great day.
Marton (Hungary)
Marcika is online now   Reply With Quote
Old 09-19-2013, 02:47 AM   #5989
Here is a build article for the 417v5 with pictures, including a tip on the shocks
http://www.thercracer.com/2013/06/ta...ld-thread.html
To be honest, the manual is fine, everyone has our our own tips. The big one is not to ream out the arms, and try to build the diff with different O-rings and a little green slime.
CA personally I only do the bottom plate and the suspension towers.
I race my V5 on carpet with the shocks provided, they work really well and dont leak, I used to run the std shock with 0 rebound, but these shocks are easier to make 0 rebound if you dont drill the cap.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 09-19-2013, 10:50 AM   #5990
Marcika's Avatar
thanks for the help.
Do you exactly build damper as it is in the link? it appears should work very similar to normal trf damper except no oilsealing inside. Am I correct?
CN - do you round the edge or just simple put cement as it is described in the link.
O-rings, other stuffs for gear diff - where can I buy those? I tried to find it on ebay, with no luck...
thanks, again
Marton
Old 09-19-2013, 12:04 PM   #5991
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Are the suspension mounts the same on the 417 and the 415?
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 09-19-2013, 02:04 PM   #5992
Csaari77's Avatar
Trader Rating: 34 (100%+)
They are close, but not the same. The widths and the letter designations are the same from the 415 style to the 416 style but the profile in the center of the blocks has been changed to accommodate belt clearance. Check out this link:
http://www.petitrc.com/reglages/tami...ckSettings.pdf
It has pretty good illustrations to show the differences.
Are you thinking of running TC with us this winter at Onelug?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 09-19-2013, 04:23 PM   #5993
thanks, again
Marton
Yep I built them as per the link. The shocks work well with my set-up like this and the don't leak. Infact another guy has bought a set to fit on his older TRF as he is impressed with how they stay consistant.
The CA I apply with a cotton bud, it's very easy and it doesn't run. I never round the edge as my car doesn't drag on the surface when cornering.
The Kyosho O-rings are available from any Kyosho stockist, the Tamiya ones are only just released (they are the same, just a different label).
Old 09-19-2013, 04:39 PM   #5994
transplantlife's Avatar
Trader Rating: 43 (98%+)
Any of you guys willing to sell a Raceberry conv interested in the soft chassis or can anyone direct me to Dist here in N America?
Thanks guys!
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 09-20-2013, 01:12 AM   #5995
Marcika's Avatar
Quatmix - thanks for your summary! will try :-)
Old 09-20-2013, 07:52 AM   #5996
Johnn27's Avatar
Trader Rating: 66 (100%+)
Thumbs up
Thanks guys!
I have a new soft chassis raceberry 417 v5 never ran
$620 kit
$250 raceberry conversion
$52 raceberry short shock tower
$65 trf shocks
$985 obo. oh and I am sure I am missing a few things ! It's a good thing I work so much and never get to enjoy this expensive toy!
Johnn27 is offline   Reply With Quote
Old 09-20-2013, 08:37 AM   #5997
Grizzbob, I got the Yokomo Spur gear yesterday and put it in this morning and you're right it's very quiet!
Thanks again for the tip.
Cheers
Cheers, Jeff
Old 09-20-2013, 09:41 AM   #5998
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Velocitygt View Post
I had the impression you sold it as a package? ??
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 09-20-2013, 04:44 PM   #5999
Velocitygt's Avatar
Someone ended up buying just the kits.
Old 09-21-2013, 04:25 AM   #6000
C van der Hagen's Avatar
Special offer for non EU customers: SRP conversion set only $99 (excl. $20 shipping)
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
